Go Back   Forums Forums - Off Topic Forum FUN > Off Topic Forums > Open Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 10-10-2012, 07:03 PM
McG-75 McG-75 is offline
Junior Member
McG-75 is on a distinguished road
Default 200 lb propane tank
I am trying to decide if i should rent a 200 lb tank from my supplier for $60/year or buy it outright for $350. How long should I expect my propane tank to last and what maintainance cost might I expect to pay over it's lifespan. It's exposed to the elements, which in the lower Hudson valley of New York State involves a bit of everything but nothing too extreme.
  #2
Old 10-10-2012, 07:22 PM
300 H and H's Avatar
300 H and H 300 H and H is offline
300 H and H will become famous soon enough
Default Re: 200 lb propane tank
My experiance has been that if your rent, you are locked into that supplier. This may not be a good thing depending on their price history relative to the rest of the supliers in your area.....
Tanks last a life time with little maintanence, maybe a paint job each decade or so. I would own them, if you want to shop price...JMHO.
By the way welcome to the forum. You may want to post in the introductions thread.
__________________
Snow trac ST4 #267
  #3
Old 10-10-2012, 07:52 PM
Kane's Avatar
Kane Kane is offline
Silver Member
Kane will become famous soon enoughKane will become famous soon enough
Quote:
Me? I would go ahead and buy the thing for $350, or maybe offer less. Then like Kirk says, your supplier options are open. But be sure to consider the costs to have the tank delivered, give it a fresh paint job and set it up -- costs that a supplier would absorb to get your long term proprietary business.
__________________
All things being equal, bigger bullets tend to work better.
  #4
Old 10-10-2012, 08:15 PM
rlk's Avatar
rlk rlk is offline
rlk is on a distinguished road
Two large national propane dealers that I'm familiar with want you to rent their tanks because then other propane dealers can't sell you propane. Once they have you hooked, they can raise their prices at will because there is no competition.
Like others have said, I had rather own than rent.
Bob
  #5
waybomb's Avatar
waybomb waybomb is offline
Silver Member
waybomb will become famous soon enough
Or you could do some serious shopping and buy one for much less.
__________________
Thanks Fred
NASA says I am not warming the globe, 24 cylinders at a time.
http://s4.photobucket.com/albums/y145/waybomb/
I'd rather be burning gas up at an alarming rate in Plain Vanilla.
  #6
Old 10-10-2012, 09:01 PM
Consider buying a 500 gal while your at it. Some time you can buy it off season for cheap, and have more on hand....500's are more common and my bet is per gallon of storage they are cheaper to buy than the 200 as well...
__________________
Snow trac ST4 #267
  #7
Old 10-10-2012, 09:04 PM
muleman's Avatar
muleman muleman is offline
worn out farmer
muleman is just really nicemuleman is just really nicemuleman is just really nicemuleman is just really nice
There is no rental charge for my tank and they give me a fair price for prompt payment. With your options I would buy it. That price is not bad if they set it for you. I supplied the pipe and they supplied the regulator since my price on the pipe was better than theirs. I deal with a local dealer and they supply my diesel as well.
__________________
"The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government"
  #8
Old 10-10-2012, 09:12 PM
Junior Member
Thanks for the input everyone. I was leaning towards buying it anyway. It doesn't make sense not to. I just was not sure if the tank needed any regular up keep that would add up over the years. A paint job is well within my capabilities.
  #9
Old 10-11-2012, 12:22 AM
Snowtrac Nome's Avatar
the 200 pound tank is an asme tank and will require a re inspection about every 10 years which is a visual inspection externaly you will get no corrosion on teh inside as there is no oxygen inside teh tank keep the rust off the out side and keep it painted it will last you for ever. and yes my company is also the local supplyer for the long term buy it you will be saving money. and ypou arn't locked in to a supplyer
__________________
Don
1962 st-4
KL2ZF
  #10
Old 10-11-2012, 07:29 AM
bczoom's Avatar
bczoom bczoom is offline
Style: T66
I'll pile on with those that say buy, but I'd probably do it a little different.
Instead of a 200 pound tank, I'd go with a pair of 100 pound and get an automatic transfer switch. (I have this setup in a couple places).
When one of the 100's gos empty, the transfer switch automatically switches to the other. I then grab the empty, toss it in the truck and go to whomever has a good propane price at the time.
I picked up the tanks new from Costco for around $100, used from CraigsList for under $50 and the transfer switch was around $60.
  #11
Old 10-12-2012, 01:26 PM
that is a good idea becuse in most cases you can save your self the delivery charge that way.
__________________
Don
1962 st-4
KL2ZF
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How to get rid of a Propane Tank? buckle97 Agriculture & Rural Living Forum 31 03-29-2013 12:03 PM
200 Pound Propane Tank TiredRetired Open Forum 5 01-06-2012 11:13 PM
running on propane????? mbsieg ATV's / RTV's / UTV's / Side-by-Side's Forum 4 01-10-2007 08:10 AM
“Stolen/Missing” propane tank Dutch-NJ Open Forum 3 12-22-2006 08:35 PM
Propane bczoom Campers / Motorhomes Forum 2 10-10-2005 09:52 PM
