Go Back   Forums Forums - Off Topic Forum FUN > Off Topic Forums > Photos, Cartoons & Videos Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 05-08-2012, 04:48 PM
fogtender's Avatar
fogtender fogtender is offline
Now a Published Author
fogtender will become famous soon enoughfogtender will become famous soon enough
Default Getting your feet stuck in the mud, or concrete
Ok, not really... The tires were worn out and I had to cut them like that to grind out the steel belting so I could get them off the rims, they are solid tires and don't get flats and are a pain to replace... But I thought they looked funny sitting on the floor. Funny when I posted them else where, people thought they were reall in the concrete!
  #2
Old 05-08-2012, 05:17 PM
muleman's Avatar
muleman muleman is offline
worn out farmer
muleman is just really nicemuleman is just really nicemuleman is just really nicemuleman is just really nice
Default Re: Getting your feet stuck in the mud, or concrete
Solid or foam filled tires are great as long as you are not the sucker changing them. I knew one outfit that just replaced the rim and tire when they got real bad. By that I mean they were painful to run unless you were lifting real heavy stuff. They would end up missing big chunks and it was worse than a flat.
__________________
"The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government"
  #3
Old 05-08-2012, 05:44 PM
bczoom's Avatar
bczoom bczoom is offline
Style: T66
Good one Foggy!!
  #4
Old 05-08-2012, 05:46 PM
squerly's Avatar
squerly squerly is offline
Supported Ben Carson
squerly will become famous soon enoughsquerly will become famous soon enough
lol, you had me going boy!
  #5
Old 05-08-2012, 10:58 PM
fogtender's Avatar
I had them sitting on the floor and they just looked funny so I put them there and took a photo! Got a lot of people thinking that I really pulled them out of the rims!
  #6
Old 05-09-2012, 11:24 AM
fogtender's Avatar
Maybe I'll put the tired by the road and putt a sign up, "Danger! Quicksand"!
  #7
Old 05-09-2012, 11:35 AM
Snowtrac Nome's Avatar
them solid tires are a pain they make a press to break them down i had to send some to anchorage and bj's still bent 1 wheel we replaced them with ttubed tires yes i now have to do an occasional tire repair but i can do it with hammers and bars now
__________________
Don
1962 st-4
KL2ZF
  #8
Old 05-11-2012, 12:56 AM
fogtender's Avatar
Quote:
Yep, the tread was just plain gone, the sidewalks were breaking down and I replaced them with tubes and tires! Much easier unless your in a high flat enviroment! But the solid "any" type tires are a pain! Very few people have the proper equipment or know how to change them. When I was cutting these open to cut the thread, I had all sorts of suggestions on how to do them, but it was clear they were being helpful, but they were truely cluess to what I was doing.
Using soapy water (lots of soap) is the best Lubricant. One "Expert" kept telling me to use WD-40, so I let him try and it just gummed up the blade on the sawsall! But i cut them that way so you can get access to the steel belting, which you cut diaginally with a grinder, once that was done a razor knife will cut the last few inches down to the rim easily!l
  #9
Old 05-24-2012, 11:27 PM
fogtender's Avatar
Can't believe how many people thought this was real!
I guess I shouldn't do serious humor with real photos!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Anyone knowledgable about concrete out there? Adillo303 Open Forum 5 06-05-2011 08:45 PM
Bendable Concrete! Deadly Sushi Open Forum 5 05-10-2009 01:15 PM
How long to keep concrete wet? OhioTC18 Home Improvement Projects, Appliance upgrades, Misc Household items Forum 11 08-06-2008 11:36 PM
WORST SNOWCAT STUCK! post your worst snowcat stuck pics here! Snowcat Operations Snowcat Adventure & Usage Forum 40 04-16-2008 07:15 PM
Sealing concrete jamm Home Improvement Projects, Appliance upgrades, Misc Household items Forum 1 11-04-2007 10:38 PM
