1972 Aktiv for sale on BC Auction
It appears to be in good shape.
Here is the auction info:
Prince George
Auction Details:
1972 Tucker Snowtrac ST4 Snow Machine
Vin# BCH1258
Aktiv
Fisher AB
Morgongave Sweeden
Type ST4
Number 1531
Standard transmission
Was declared of having transmission and clutch issues
4 speed
Transmission and drive train condition unknown
Idler wheel on drivers side flat
Interior in poor condition
C/w sun roof
Voltswagenwerk AG Engine
Engine type 126A
Motor# 126-044190
46 hp/3600rpm
Engine size 1584 cm3
Air cooled
Engine cranks over by hand
Batteries missing
Condition of engine unknown
Sold as shown.
Over all condition unknown
It is sort of odd that they would close off the front grill to prevent the engine from cooling???
the engine dosn't cool through th efrot just another way for air to escape i have thaught about doing this with mine as in storms i have wound up with so mugh ice on the carb the throttle sticks and water in the distributor
Jim,
Mine did this as well, but since the addition of the slanted vertical piece I made it has not happened. I tried to replicate the original piece from pics of it I found on this forum. By using this piece above and behind the front air vent (grill) you don't have to block this off to get the same efect. This the way the factory intended it to be as well....JMHO....
What's with the pipe assembly at the base of the windshields on this machine?? anyone have a clue??
Bob im guessing those box's are battery boxes and that pipe must be a conduit to connect the batterys together this iditarod was plenty rough i found i had to suck air off one of the heater boxes to keep the carb from freezing up now i plan to build a heat exchanger on the tail pipe so i can have enough carb heat to keep the carb thawd
Don I was the successfull bider. $ 7,000.00 and a bit, I wanted some one else in my area to have one for company so my first one is for sale. I will rebuild this one for a hoby. Transportation will be expensive but what the hell live is short. Bob.
Trying to negotiate a reasonable transportation price. May be expensive buy I really would like a second one in may area to buddy up with. Will have to see the condition of this one and decide which one to keep. Will be in contact later. Regards, Bob.
