Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Home Improvement Projects, Appliance upgrades, Misc Household items Forum
Reply
Thread Tools Display Modes
  #1
Old 03-14-2011, 07:39 PM
BigAl's Avatar
BigAl BigAl is offline
BigAl will become famous soon enough
Thumbs up PEX plumbing review
Over the years , I have used just about every type of house plumbing that they use . Galv pipe, Copper , PVC and now the newest which is called Pex plumbing . This is rolls of plastic pipe that you crimp the end fitting on with a special tool . The crimping tool cost about $150 . The end fittings can be a little pricey but I installed it where we got down to 25 degrees below many times . It froze the water but nothing broke !!!!
My opinion ????? BUY IT !!! I will never use anything else again !
__________________
Big Al
2B1ASK1
See my Kristi Video here : Kristi KT3 - YouTube
Disclaimer: Read with caution !!
Poster may be Bad Speller at times .
  #2
Old 03-14-2011, 07:50 PM
snow dog's Avatar
snow dog snow dog is offline
Silver Member
snow dog will become famous soon enough
Default Re: PEX plumbing review
The only down side is draining. Many cabins around here are drained for the winter, the ones with copper pipe drain easier than the Pex ones. The pex can have little bellies in the pipe runs.
  #3
Old 03-14-2011, 07:55 PM
tommu56's Avatar
tommu56 tommu56 is offline
tommu56 will become famous soon enough
Quote:
As long as the pipe isn't full it isn't a problem the ice can expand in the belly.
We got a early frost one year and the pipe was full I had had an elbow pushed out of the tube and crimp.
I cut it back and re crimped no big deal because I had enough slack
tom
  #4
Old 03-14-2011, 08:02 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Thanks for the PEX info Al. I have a little plumbing to do and I might try it out. Good to hear that from someone who has used copper and pvc but you prefer PEX.
As for winterizing a cabin or trailer we always got a compressor and blew the lines out. Never had a problem with freeze breaks at all. I've done that in places with PVC and other places with Copper No problem. I figure PEX would be the same in that respect.
__________________
Scott me up Beamy.
Other Fun Forums:
Net Pet Talk + Net Tractor and RTV Talk + Net Cooking Talk
  #5
Old 03-14-2011, 08:09 PM
BigAl's Avatar
Yes you are right and the first year I tried to drain the Pex by opening a outside water bib before winter hit last year . The Pex pipe froze but nothing busted . I was very impressed at how well it handles the cold . I do not even worry about no heat in the barn section as the exposed Pex does not seem brust like copper or PVC .
__________________
Big Al
2B1ASK1
  #6
Old 03-14-2011, 08:39 PM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is offline
Gold Member
EastTexFrank will become famous soon enough
I love the stuff. When we had 2 bathrooms remodeled about 3 years ago I had the whole house redone in Pex. I also had a manifold installed where, if there is a leak somewhere in the system you can shut off the hot or cold water to that particular faucet/shower/toilet and still have water in the rest of the house. I don't think that you could do that easily with anything other than Pex.
Just as an experiment, I had a length of Pex filled with water and capped. I stuck it in the freezer and thawed it out and refroze it every day for a week. Never a problem. It's great stuff.
__________________
ETF
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them. John Wayne as JB Books in "The Shootist".
  #7
Old 03-14-2011, 08:46 PM
muleman's Avatar
muleman muleman is offline
worn out farmer
muleman is just really nicemuleman is just really nicemuleman is just really nicemuleman is just really nice
The only drawback to pex is they have jacked the price of fittings almost 300% in the last 4 years. The pipe and bands for crimping have remained about the same. And you do have to use more hangers than rigid pipe.
__________________
"The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government"
  #8
Old 03-14-2011, 09:07 PM
BRGTold's Avatar
BRGTold BRGTold is offline
BRGTold is on a distinguished road
Pex..will expand ..10 times its size..with know problems..you can run it like pulling wire..its well worth the price of fittings/ends....in labor...
  #9
Old 03-14-2011, 09:16 PM
BigAl's Avatar
Another point to make is that Pex does not require as many fittings creating a smoother less fiction loss flow of water . I only used fittings as I branched off to each water fixture . The saving in labor time and fittings more than makes up for any higher cost of the brass fittings. I did not go with the special pipe angling fastners . I just put a gentle bend in the pipe and secured it with a cheap pipe c clamp . It took me about 4 hours to do all the water pipe in the barn/apartment . I used the red color pipe for hot and blue for cold . It makes plumbing wayyyyyy to easy !!!! All my main lines are 3/4 inch and then 1/2 inch to each point of use . Plenty of water !!!!!!!!!
__________________
Big Al
2B1ASK1
  #10
Old 03-14-2011, 09:32 PM
thcri's Avatar
thcri thcri is offline
Platinum Member
thcri has a spectacular aura aboutthcri has a spectacular aura about
Style: VB_Original_Style
We give our customers the option to go with PEX or copper. Copper is less expensive material wise but more labor intensive. PEX material is more expensive but less labor. They come out to be about the same after install.
Keep in mind though, PEX makes the water taste funny. As for freezing you don't have to worry about the pipe but the fittings can break. If draining I would still run RV fluid in the system.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Joe's Fair Plumbing Act PBinWA Jokes_Forum 1 10-30-2008 06:48 PM
SharkBite plumbing quick-connects bczoom Home Improvement Projects, Appliance upgrades, Misc Household items Forum 9 03-31-2008 01:11 PM
Amercan Standard Plumbing issue Junkman Home Improvement Projects, Appliance upgrades, Misc Household items Forum 2 01-11-2008 01:51 PM
CPVC or Copper for house plumbing? PBinWA Home Improvement Projects, Appliance upgrades, Misc Household items Forum 25 10-30-2006 09:50 AM
