Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #1
Old 01-10-2011, 07:05 PM
meanjean's Avatar
meanjean meanjean is offline
meanjean is on a distinguished road
Default Wider tracks for a Bombardier SW-48????
I wonder if it would be worth the time & effort to widen the foot path of my SW-48? Currently 48" wide overall, the actual track width is about 14" which causes the machine to really dig in. I wonder if I should make them both 24" wide as to make the machine "float" better on deep snow? I could achieve this via two ways: offset the tracks more to one side w/o changing the wheel spacing and installing a wider track to the existing, with wider cleats or, widen the wheel base to accommodate wider tracks. Does anyone have any thoughts or experience on the issue???? Let me know! Thanks.
  #2
Old 01-10-2011, 07:55 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Default Re: Wider tracks for a Bombardier SW-48????
There have been tracks that were widened to help achieve greater flotation. I see no reason why they can't be offset/asymetrical. The reality is that your machine is really heavy so it will dig in with standard tracks. Any width you can add will help but if you don't want to move your sprockets and bogie wheels out your best bet is asymmetrical tracks.
__________________
- Ayn Rand
  #3
Old 01-10-2011, 09:00 PM
Snowtrac Nome's Avatar
you may wan to look at t a set of wide tracks for a bombi just rememder what you pick up in floatation you will loose in tractive frce once you lighten up the foot print
__________________
Don
1962 st-4
KL2ZF
  #4
Old 01-10-2011, 09:36 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Quote:
Look at a BR110 they are just a SW48 with wider tracks (31") we have also put 18" wide all rubber tracks on a SW48 before also
__________________
Have a nice day, NSA kind of like NASA but one less "A"
  #5
Old 01-11-2011, 07:05 AM
meanjean's Avatar
Hmmm. I have no idea as to what a BR 110 might be???? Any insight? I see, from the picture, that the running gear, or wheel assembly has not changed with wider tracks. That was my main concern: changing the center of the weight of the machine. But if the tracks are installed in a wide manner, it dosen't seem that is affecting anything. N'est ce pas???? Thoughts? Let me know and also, about the BR110.
Thanks!!!!!
  #6
Old 01-11-2011, 07:17 AM
meanjean's Avatar
The width is standard on the inside, as the picture of the BR110 shows, but the only difference is the outer track is set further away from the center, and nothing for further support to the bogie wheels. Also seems to be angle iron as cleats and traction medium. Interesting idea. Still, what is a BR110?
  #7
Old 01-11-2011, 07:33 AM
MNoutdoors's Avatar
Well, A BR110 comes from it having a Perkins Turbo diesel engine (110 HP)cab is a SW-48 cab sprocket get changes to a SV252 sprocket ,tires and wheels change to 5.30X12 front wheel is now a rubber torsion axle(like the newer SW-48) the cleats are a standard snow cleat. it pushes snow very well
and yet it does OK in the deeper snow (not powder). axle tube gets changed
to move the sprocket out a little further.
__________________
  #8
Old 01-13-2011, 07:13 AM
meanjean's Avatar
Hey! Thanks for the pictures, by the way. I can see that the sprocket in the front is actually wider that what would have been installed there originally, but the bogie wheels and drive sprocket do seem off center of the tracks. Also, still a narrow band of belting used, not wider? Interesting. I do have a spare running gear from another sw-48, so I may try to remove a track and check out how it can be done. But man, it sure, my machine, digs in to the white stuff instead of floating though.
  #9
Old 01-13-2011, 07:15 AM
meanjean's Avatar
Forgot to ask: is the BR110 your machine?
  #10
Old 01-13-2011, 07:51 AM
MNoutdoors's Avatar
It was, we have had a couple of them ,But made by Bombardier.
__________________
  #11
Old 01-13-2011, 07:55 AM
northeastheavy's Avatar
northeastheavy northeastheavy is offline
northeastheavy is on a distinguished road
If you want a BR110 in a 2 seater, same specs as the BR110, you need a BR60!! I think they are both based on the sw48 you have. I think Boggies BR110 is for sale, mine is not. Great machine!! We just got 2 feet of powder and I had the snow coming up the windshield and it just kept going and going!!!!
My first snowcat was a sw48 like yours!!!! I loved it, but not good in the deep snow and mountains here. The bigger models are heaven if you like the sw48!!!!! More room inside, power and wide tracks for deep snow!!! The br110 and br60 are like a sw48 on steroids!!!!!!! Good luck!!!!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
wider tracks mojo66 Snowcat Adventure & Usage Forum 2 10-25-2010 11:54 AM
Adding rubber to Bombardier D style tracks DynatracGuy Snowcat Restoration & Modification Projects Forum 3 10-22-2009 09:32 PM
Wider tracks or narrower???? NorthernRedneck Snowcat Adventure & Usage Forum 3 11-22-2007 12:41 PM
What happened to NORTHERN TRACKS Bombardier Forums? Melensdad Snowcat History, Articles, Manuals, Brochures & Recollections Forum 17 11-13-2007 11:24 PM
Bombardier Muskeg Tracks jequimby Snowcat Repairs, Parts & Problems Forum 3 05-03-2007 07:03 PM
