| Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications |
Thread Tools | Display Modes |
#21
nice work on the cab
__________________
Don 1962 st-4 KL2ZF Snow trac's Rule and Krustys Drool |
#22
What a great job, Will be like a new $100k machine when you are done!
What Isuzu diesel did you use. Was it an older mechanical unit? What model Isuzu did it come out of. Need a engine and trans for the J-8. I hear they fit well. Figured one in the 130hp to 175hp would be plenty power. May only need a 4cyl Isuzu for that hp. Trying to find out what is best to look for??? Any help is much appreciated!!!! |
#23
Quote:
J5 Bombardier |
#24
Thanks!!! The 4cyl turbo sounds great!!! Much appreciated!! Again, your Muskeg is real nice!!!! Be done for this winter?????
#25
Quote:
Hopefully the Muskeg will be finished this winter . The painting is what I dislike the most, even punching belt holes is preffered to that job. Once that's done I 'll enjoy doing the hydraulic and electrics. J5 Bombardier
#26
J5B, if you need a hand rebuilding the tracks...on weekends, just PM me. I hate bodywork/paint too....hahaha
Excellent job so far, you are a master fabricator by far!
__________________
benz9 ![]() |
#27
Quote:
J5 Bombardier |
#28
(got a mental picture of a big head that won't fit in the new cab)We all do what we can I guess, just some of us have more experience. As I read your thread about running the engine on a test bed to check for leaks, I was thinking, hmmmm, I should have done that (I didn't remove the engine this year). The very next day, I find a leak in one of the valve covers (fixed by tightening up the screw) and the fuel pump just pissing gazoline into the bottom of the hull. It's a tight fit to get that pump out once the manifold is in place. Used some chemical gasket and it did the trick. Just happy it's happening now and not when it's cold. The best to you, J5B, hope it's done for the winter. BTW, if you don't have your hole punches, I saw a set at Princess Auto for under 3$. You get what you pay for, but at that price, might as well pick up 2????
__________________
benz9 ![]() |
#29
Just about finished painting,I have to paint the outside of the doors and the dash and that should be about it. Thought I would concentrate on some suspension work,replaced two axles on the rear beams today and started sorting out my solid and air wheels.
J5 Bombardier |
#30
Looks great !!! I'm happy to see everything coming together
__________________
Live Free or Die |
#31
You just might make it for the snow, Mr. J5B. Even the air filter is yellow...yup it's a nice color!
__________________
benz9 ![]() |
#32
It's been a little damp for outside painting, so I put my dash together and installed it temporarily to get it out of my way.
J5 Bombardier |
#33
That's fancy
![]() ![]() It that an air brake button top left ? What's the light for ? What kind of steering ? Are the 3 verticle slots an air vent ? Tell us more
__________________
Live Free or Die |
#34
Hi Pixie
Top left of dash-Pto lever for pump running off trans, to the right data plate , lights- hi beam, misc warning, horizontal slots for defroster[louvres to cover]. Vertical slots for hydraulic valve levers[to be covered by aluminum plate]. Steering(what's that ?) Oh yeah, hydraulic stick- to be alot like the muskeg steering pics you sent me a long time ago ! J5 Bombardier |
#35
Wow, that's a lot of dials, buttons, and levers. Very nice indeed, Especially the CD/Radio.
__________________
benz9 ![]() |
#36
Beautiful work !!!! You are a Master !!!
__________________
Big Al 2B1ASK1 Disclaimer: Read with caution !! Poster may be Bad Speller at times .
#37
ditto what my buddy Big Al said excelent craftsmanship you should be proud of your work.
__________________
#38
this is a nice unit you have put a lot of work in to it
#39
A little update on the Muskeg rebuild, dealing with the undercarriage. Replaced two axles on the front beams, rebuilt the grease adjusters,built up the worn rear beams and rear axle saddles (to get rid of the excess play) on the sliders.New wheel seals and replaced 12 out of 32 bearings,16 seal spacers made up and some of the air rims I had were small bearing style which I switched the center hub to large bearing style.
Tires are a mix of old and new style solids on the front and rear and the centers are air . Plan on adjusting the bearings and installing the grease caps next,then take off the rails for the last time and get these suckers installed ! J5 Bombardier
#40
Nice paint job on the wheels !
Must be nice to work on the wheels without having to get them on/off underneath the machine. How did you replace the small axle centers ?
__________________
Live Free or Die |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Little Red Thingy Rebuild | boggie | Snowcat Restoration & Modification Projects Forum | 15 | 12-31-2007 08:55 PM |
| OC-12 rebuild | Snowcat Operations | THIOKOL/LMC/DMC Technical Issues Forum | 0 | 08-14-2007 10:52 AM |
| Muskeg Transplant | J5 Bombardier | Snowcat Restoration & Modification Projects Forum | 5 | 06-18-2007 09:40 PM |
| Bombardier Muskeg Tracks | jequimby | Snowcat Repairs, Parts & Problems Forum | 3 | 05-03-2007 07:03 PM |
| IMP Master cylinder rebuild kits?? | Teeoster | THIOKOL/LMC/DMC Technical Issues Forum | 3 | 04-29-2007 03:47 AM |
