Bobcat
Je Suis Charlie Hebdo
Most USAF vehicles have a registration number on their door and/or license plate. The number is usually in the format YYUNNNNN, with YY the year the vehicle was procured, U being the intended use of the vehicle, and NNNNN being 1-5 digits identifying the serial number of the vehicle (or more correctly the order it was purchased within its 'use' group).
In a recent snocat thread there was a picture showing an old 601 with USAF markings, seen below. This sparked a memory from my time in the USAF and the vehicles I operated in AK, including a Spryte and an Imp. They both used the 'C' designation which I always thought meant 'Cargo'. This seemed to fit well with the old Dodge Carryall at my detachment having the same designation. We also had a station wagon with a 'B' designation. I thought that must have meant something like 'bus' since it was a people-mover.
Well I did a little research tonight and discovered I was close, but not cigar. Here is the straight scoop on the scheme as best as I can determine without being able to locate the definitive USAF TO 36-1-3 which supposedly defines these designations.
Some of this info was taken from USAF TO 36-1-191 TECHNICAL AND MANAGERIAL REFERENCE FOR MOTOR VEHICLE MAINTENANCE and the rest from scouring the net. Credit given to the sources of courses.
Well I did a little research tonight and discovered I was close, but not cigar. Here is the straight scoop on the scheme as best as I can determine without being able to locate the definitive USAF TO 36-1-3 which supposedly defines these designations.Some of this info was taken from USAF TO 36-1-191 TECHNICAL AND MANAGERIAL REFERENCE FOR MOTOR VEHICLE MAINTENANCE and the rest from scouring the net. Credit given to the sources of courses.
