here are some more pics I think I figured it out
forgot this picture of the clip on the other side of the starter.
<snip>
The original pindal (spelling ?) hitch frame was all bent up so I cut it out and put in a 2 inch receiver tube, this I felt gave me more options for towing, it sounds like from what I have been reading that if I ever did run across one of those Kristi things it would be stopped, unable to move and need a tow.
Its really an amazing system, it only requires about 1% of the engine's horsepower to operate the steering so it is a very efficient system. Basically it is a proportional steering system that directs more or less power to one track while directly proportionally more to the opposing track. So when the steering wheel is centered, 50% of the power is sent to each track, but as you start to turn to the right, more power is directed to the left track and proportionally less power is sent to the right track. It is totally different from a "brake steer" or a hydraulic steering machine, which are commonly used systems on 2 track snowcats.Pardon my stupidty, But just how dos the streering work on on this rig.
It Looks like you a doing a great job on her.
No, there is no braking at all. That is the genius of the system and that is why it does not rob the engine of horsepower. Most snowcats require far more horsepower to run because most rob the engine every time you try to steer. The Snow Trac is so different from these systems because the main steering mechanism does not require track braking or inefficient hydraulics to move power from one track to the other.Do you still have to brake the opposeing track. I must find some photos of this system.
Now you went and done did it, pal! You've been taken off the K.R.I.S.T.I. rescue list. When you're hoofing it back to the parking lot, we're just going to putter on by while sipping our hot chocolate and staring at you out the window of our cozy little cats.
Well Bob, that warm cozy feeling you'll have is the later stages of hypothermia (with hallucinations) , but hopefully we will get you into the snowtrac to warm up before it's to late.
Here are some more current photos. We took the tranny and variator out and tore them down. We came across a couple of bad bearings. We are waiting for one of the bearings and should be able to start putting this back together pretty soon. Engine compartment has been cleaned and is ready to be painted. The brakes were non functional but we got new parts and cleaned some up and are ready to go back on. We need some wisdom on the track drive sprockets. They are worn to a point, they are about an inch long. Is there any life left in these? The engine wasn't in it when we got it but is being rebuilt and should be done this week. We weren't sure what size it was but after it was torn down it was discovered to be a 1600cc with fairly new pistons ,rings etc. the only thing we replaced were valves and valve guides.
We are going to replace the tracks and got a track schematic from "teledawg" Any info on that process would be helpful.
After I took out the old plywood on the floor it measured about 5/8 in. thick. I couldn't find any 5/8 marine plywood. Also the edges on the bottom were notched about 1/8 for the angle iron it sat on. The angle iron sat on top of the frame so the notch let the plywood sit down on the frame. I could find 1/2 or 3/4 marine plywood so I opted for the 1/2 and put some 1/8 hmw plastic for a filler were this part would sit on the frame. The first picture is a poor picture of the angle iron that runs the length of the floor on each side of the cabin. The second picture is the bottom side of the plywood with the plastic screwed on. I counter sunk the heads and used 1/2 wood screws. The last picture is why you don't want your christmas tree to catch fire in your house. I let my son use a propane torch to get it started and this was the result in a matter of seconds (sorry I couldn't get it to turn upright).
