Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tools & Tractor Implements Forum
Reply
Thread Tools Display Modes
  #1
Old 11-23-2007, 01:15 AM
TOMLESCOEQUIP's Avatar
TOMLESCOEQUIP TOMLESCOEQUIP is offline
Just Plinkin Away the $$
TOMLESCOEQUIP is on a distinguished road
Default PTO SPEED ADAPTER ??
I'm looking for a slide on adapter that will jump my 540 pto up to 1000 rpm. I run a pto generator off my tractor & need 2800 tractor engine rpm to get 540 pto speed.
My tractor has double the HP I need to run the generator, & I'd like to cut the engine speed down to save fuel.
Hubcity still makes one new, but the cost is such that I could buy alot of fuel before I'd recover the cost of a "new' one.
Please let me know if you know of one.
Thanks.........Tom
__________________
Nothing works unless you do !
  #2
Old 11-27-2007, 08:34 AM
RedRocker's Avatar
RedRocker RedRocker is offline
Silver Member
RedRocker will become famous soon enough
Default Re: PTO SPEED ADAPTER ??
My tractor had a plate that prevented the lever from moving to the 1000 rpm slot, it was easy enough to remove on my Kioti. I'm guessing you don't have that option and this post is of no use in solving your problem.
__________________
Lewisville Texas
You can lead liberals to knowledge, but you can't make them think.
  #3
Old 11-27-2007, 10:43 AM
Quote:
RR........I just wish it was so easy !!
Hydro drive, fully independent pto, but not 2 speed.
__________________
  #4
Old 11-27-2007, 11:03 AM
bczoom's Avatar
bczoom bczoom is offline
Style: T66
Tom,
What tractor do you have?
Is getting a different generator an option?
  #5
Old 11-27-2007, 03:02 PM
Quote:
Originally Posted by bczoom View Post
Tom,
New Hollands........TC 33D, and a TC40D, both hydro's & ind. PTO, but 540 only.
My gen is a northern like this: PTO generator although mine is a 10 K max. I never use the max it will put out, it usually runs at 50% load or less.
I hate to replace it........Just built a new trailer for it. I got the gen via a damaged freight settlement from a friend. A couple tin pieces were bent & the guards for the shaft needed replaced, but otherwise it's new.
__________________
  #6
Old 11-27-2007, 03:38 PM
bczoom's Avatar
Style: T66
Hmmm,
So I figure your generator requires about 20 PTO HP.
Are you worried about "brown out" conditions? If you convert to 1000 RPM's and a start-up load bogs the engine down (which could happen you're running at low RPM's), that'll drop your voltage. If electronic components are running and the voltage drops, I've found they turn to toast.
I'll keep my eyes open for an adapter but if my generator was PTO, I'd probably just burn the fuel. It may also be a bit harder to watch the engine RPM's to assure you're pushing out the correct voltage.
  #7
Old 11-27-2007, 03:43 PM
California's Avatar
California California is offline
Charter Member
California is on a distinguished road
The input gearbox I see on that thing is probably 6.5/1 stepup (3600/540).
I wonder if you could replace that gearbox with a lesser ratio cheaper than putting additional gears in front of it.
  #8
Old 11-27-2007, 03:57 PM
I'm not sure what parts would be available to do that. I know on the older winco pto gens, they used chain & sprockets in their adapter boxes, that ran in oil. If it was that type rather than the gear to gear style, it would be easy to split the case & just change out a different size sprocket & change the chain length accordingly.
__________________
  #9
Old 11-27-2007, 04:04 PM
DaveNay's Avatar
DaveNay DaveNay is offline
Klaatu barada nikto
DaveNay is on a distinguished road
Quote:
Either sprocket/chain or direct gear, your best bet would be to call the manufacturer and see what is available.
__________________
Never ascribe to malice, that which can be explained by incompetence.
Napoleon Bonaparte
If God were suddenly condemned to live the life which He has inflicted upon men, He would kill Himself.
Alexandre Dumas
  #10
Old 11-27-2007, 04:50 PM
California's Avatar
Charter Member
Re-reading this thread it occurred to me you would need an even higher ratio, not 'lesser' as I wrote. Maybe 3600/360 (10:1) because your goal is to get the tractor's rpm down. I doubt there is space in the gearbox for a gear that large so a different gearbox that fits would be the only alternative. If such a thing exists it sounds simpler than an external stepup box.
Maybe that purpose-built pto adapter is the cheapest alternative after all. Is it 1000:540?
Or get one more tractor!
  #11
Old 11-27-2007, 10:23 PM
The quote I got from a hub city distributor was almost $ 3K.
(maybe that was just their way of telling me they don't want to bother ordering one for me ?? )
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Vehicle Checks Limited to Speed Traffic at US-Mexican Border Deadly Sushi Political Debate Forum 5 09-09-2007 12:47 AM
At what speed do you actually run your Snowcat?? BigAl Snowcat Adventure & Usage Forum 30 03-09-2007 01:21 AM
speed cameras in wheelie bins daedong Political Debate Forum 7 02-14-2007 10:48 PM
UL Warns of Counterfeit AC Adapter OhioTC18 Computers, Cell Phones & Electronics Forum 0 11-24-2006 08:01 PM
Is double the speed a good estimate? bczoom Boats, Jet Skis and Water Toys Forum 15 10-10-2005 11:21 PM
Copyright 2002 - 2017 www.ForumsForums.com
