Go Back   Forums Forums - Off Topic Forum FUN > Off Topic Forums > Open Forum
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 08-08-2007, 01:25 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Default KRYLON paint on plastic? Does it work???
Krylon has a spray paint called FUSION.
It is specifically designed for use on plastic, they claim it does not crack, chip or peel. Does anyone have any experience with this paint? Does it actually hold up? If the plastic flexes slightly does the paint crack or chip?
http://www.krylon.com/main/product_t...roduct_details
__________________
- Ayn Rand
  #2
Old 08-08-2007, 02:15 PM
bczoom's Avatar
bczoom bczoom is offline
Style: T66
Default Re: KRYLON paint on plastic? Does it work???
Mrs. Zoom used some of that paint on some outdoor plastic chairs (those green ones).
They came out very nice and we've had no issues with fading or cracking. It was only done this spring but so far, so good. We would do it again.
  #3
Old 08-08-2007, 02:28 PM
Melensdad's Avatar
Do you think it would hold up well on a plastic gunstock? Krylon makes a color called "Fairytale Pink" in their Fusion product line. It would be a lot easier for me to paint the new AR plastic stocks with a can of spray paint than to use DuraKote. But I don't want to use it if the paint is likely to chip or flake off.
Also, would you recommend that I first spray the stocks with WHITE Krylon Fusion paint before painting them with the PINK paint? I'm curious how opaque the color is when painting over a dark surface with a lighter color.
Any other thoughts?
__________________
- Ayn Rand
  #4
Old 08-08-2007, 02:58 PM
bczoom's Avatar
Style: T66
It's only my opinion but from what I've seen as well as reading about their paint, I would say yes, they're Fusion line would hold up on a gun stock. I don't think it will chip or flake.
I would probably just paint over the black. I think it would cover in one coat. It "might" take 2 coats but what's the difference since you would be painting 2 coats the other way (pink over white).
I don't know what temps this paint can withstand. If it can take a lot of heat, you can try painting the inside of the forward stock (where it meets the barrel) as a paint testing area. If it can't take the heat, don't paint that area...
OK, I just called Krylon since all the aforementioned was my thoughts without any factual backing.
This paint can take a temperature of 120 degrees. More than that and it may start to peal (looking like wrinkly skin). Consider this and barrel temperatures.
What's the stock made out of?
They said to consider doing a test area if the plastic is or has a percentage of either vinyl or polyethylene. The paint "may" not stick to these products.
If it's made of polypropylene, you're fine (and that's what this paint is made for).
  #5
Old 08-08-2007, 03:15 PM
Melensdad's Avatar
Huh. I'm stumped now. I think I will call Olympic Arms to ask!
__________________
- Ayn Rand
  #6
Old 08-08-2007, 03:39 PM
Melensdad's Avatar
I called. I stumped them. They know it as FIBERITE material. I did a websearch on Fiberite. There appears to be a polymer resin based fiberite and an epoxy resin fiberite. I have no clue if OLY uses polymer or epoxy resin fiberite.
Now my brain hurts.
__________________
- Ayn Rand
  #7
Old 08-08-2007, 03:43 PM
bczoom's Avatar
Style: T66
OK, enough analysis.
Is there a smooth portion of the stock where you can do a test?
If I recall correctly, Krylon customer support said if it doesn't dry/adhere in 15-30 minutes, it never will due to the type of plastic. Well, if it doesn't stick, clean it off. If it does stick, you're all set. Call them to confirm. 1-800-4KRYLON
  #8
Old 08-08-2007, 03:45 PM
Melensdad's Avatar
Well since I don't have the gun in hand yet, I'll have to wait for this test.
__________________
- Ayn Rand
  #9
Old 08-13-2007, 04:23 PM
buckle97's Avatar
buckle97 buckle97 is offline
buckle97 is on a distinguished road
I used Krylon Fusion to paint the plastic front bumper on my Dodge Ram just over a year ago. I painted it black and it looked incredible when first applied. It stayed looking like new until about a month ago. It has now faded quite a bit in a very short time. The truck has stayed out in the sun lately more than normal. I plan to just apply a new coat each summer. It really is a quality product.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Should a Preacher (minister, pastor or deacon) be paid? elsmitro Political Debate Forum 77 11-24-2009 02:40 PM
goverment contract work working woman Business 101 Forum 3 07-19-2007 11:37 PM
Work Wisdom Doc Jokes_Forum 0 01-27-2007 06:01 PM
paint removal help working woman Home Improvement Projects, Appliance upgrades, Misc Household items Forum 7 04-07-2006 10:29 PM
Anyone paint their car? beds Cars, Trucks Forum 16 03-13-2006 11:23 PM
