THIOKOL/LMC/DMC Technical Issues Forum Technical repair issues & questions for Thiokol/DMC/LMC |
Thread Tools | Display Modes |
#1
i have a 76 spryte with an oc-12, the hydraulics have their own tank separate from the differential.
i was wondering what everyone is running, i would like to run Agco brand permatran oil because i run it in all my tractors and the one tractor has wet brakes so in my mind it should be fine but just looking to see what more experienced minds have to say and just see what people have ran whether good or bad thanks! |
#2
Did you find out what is the correct oil to use in the OC-12 rear end? I don't see and replies. Let me know. I was thinking of using tractor r/o oil?
#3
ya i spoke with nancy at spryte improvement out of idaho and was told i should run caterpiller to-4 oil 30 wt since i dont have hydraulics tyed into the rear end
#4
There are several companies that make the TO-4
Here is one http://www.smittysinc.net/Hyd-SuperTracTO-4.htm Lucas also makes it
__________________
What ever happened to the good old days |
The Following User Says Thank You to MNoutdoors For This Useful Post: | ||
cin51773 (07-16-2013) |
#5
Is it synthetic oil? Also, do I use the same oil in the drop boxes? Or gear oil?
#6
on mine the drop boxes share the same fluid
#7
My machine also shares the fluid from center, to side/side. I replaced it last week. What did you use for oil?
#8
napa brand to-4 30wt oil
#9
I've been running power shift to-4 amzoil in the little bombie I have behind my house it seems to be a lot more responsive since I changed the fluid
__________________
Don 1962 st-4 KL2ZF Snow trac's Rule and Krustys Drool |
#10
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
changing sv250 hydraulics | Smiler | Snowcat Restoration & Modification Projects Forum | 2 | 02-06-2010 11:15 PM |
Bombi Hydraulics | boondocker570 | Snowcat Repairs, Parts & Problems Forum | 4 | 02-04-2010 02:37 PM |
Cooler for hydraulics? | snowbird | Snowcat Repairs, Parts & Problems Forum | 6 | 01-18-2010 02:00 PM |
Thiokol hydraulics!970 sprite needed | JustDarin | Snowcat Restoration & Modification Projects Forum | 3 | 02-21-2008 11:49 AM |
Snow Master Hydraulics | Melensdad | Snowcat Restoration & Modification Projects Forum | 4 | 04-10-2006 10:22 AM |
