Reply
Thread Tools Display Modes
  #1
Old 04-14-2018, 12:11 AM
vintagebike vintagebike is online now
vintagebike is on a distinguished road
Default 1958 Snow Transmission
Did the early Snow Trac use a 211 VW bus transmission with the flipped ring gear as used with the portal type reduction gears? 1963 Snow Trac parts book shows part #211 300 039.
  #2
Old 04-14-2018, 10:24 AM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
Default Re: 1958 Snow Transmission
From what I've learned, yes. Until the drop box bus went away. then they used the normal bus and reversed the gear to achieve the same effect.
The Following User Says Thank You to Cidertom For This Useful Post:
vintagebike (04-14-2018)
  #3
Old 04-14-2018, 02:10 PM
Thanks. So...now planning on a Rancho built tunnel case transaxle with 3.44 ring and pinion, an Ecotec 2.4 with about 200 mild horses and new tracks and guide wheels with re-engineered sprockets and disc brakes to hopefully reach that magical 30mph mark at least once.
The Following 4 Users Say Thank You to vintagebike For This Useful Post:
cabinboy (04-14-2018), louis (04-14-2018), PJL (04-15-2018), Sno-Surfer (04-14-2018)
  #4
Old 04-15-2018, 01:10 AM
Lyndon's Avatar
Lyndon Lyndon is offline
Lyndon is on a distinguished road
111 is "Bug", 211 VW prefix to the part number is "Bus & Transporter"
See: http://www.forumsforums.com/3_9/showthread.php?t=3825
__________________
" A Snow Cat Will See you thru times of NO WINCH, better than a WINCH will see you thru Times of NO SNOW CAT!"
The Following User Says Thank You to Lyndon For This Useful Post:
vintagebike (04-15-2018)
  #5
Old 04-15-2018, 01:43 AM
Thanks, Hope to have it well on the way next time you are in Idaho. Steve
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1958 ST4 Snow Trac Friction Drive vintagebike Snowcat Restoration & Modification Projects Forum 7 07-13-2017 11:43 AM
WTS: 1958 Snow-Trac Raven Snowcat Classifieds (For Sale / Wanted) Forum 20 03-18-2012 11:29 PM
WTS 1958 TUCKER SNOW-KITTEN MODEL 222 OILCHICK Snowcat Classifieds (For Sale / Wanted) Forum 3 11-25-2011 12:17 PM
snow trac transmission Snowtrac Nome Snowcat Repairs, Parts & Problems Forum 46 12-28-2010 10:37 PM
Snow Master Transmission vtmtnbob Snowcat Repairs, Parts & Problems Forum 1 02-26-2010 08:56 PM
Copyright © 2002 - 2018 www.ForumsForums.com
