snow trac track snow deflector size
JimVT
Someone posted the factory dimensions of the snow deflector that is in the snow trac and I can't find it. Can someone help me out?
I am getting a build up of snow and want to see if mine is the correct size.
Thanks,Jim
alaska120
Mayor McCheese
I have measured the tin deflectors...not the rubber ones. I am in the process of fabricating them. I had to make up the brackets that attach to the boggie wheels as well. I used some flat stock and a torch to bend them up. I'll see if I can make a drawing...
JimVT
we had some warmer weather and the wet snow is sticking on my rubber ones. I did some adjustments to them and I haven't been out yet.
thanks
I have not seen tin deflectors, were they the same size as the rubber ones? I have to make something for my girl, all I have is the remains of the brackets. A drawing with some measuremernts would be great, thank you.
akimp
Did anyone bet the factory dimensions for the snow deflectors. I have some tabs on the bogie wheels I'm assuming were the snow deflectors were attached. Any help will be appreciated.
300 H and H
The tin factory ones I believe Lydon said don't work as well as home made rubber or better yet poly (think kids ride on sledding matt).. we can make..
The snow deflecters made from mudflaps on my Snow Trac throw ALL of the snow, from the inside of the track line as well as the outside, out in a ribbon I can see from in the cab. Those metal factory ones eject the snow from the inside of the track line to the inside of the machine. And they don't really get it all from either side out well to the side of the track line. They aren't wide enough to do a really good job. JMHO...
Nobody ever sent me any dimensions so I guessed, I was lucky and we got it right first time. I used two "Crazy carpets" kids sledges, cheap, can cut with scissors and work really well. I think I have the template in the shop, if interested I can post some photos and details.
Cheers John
akimp
Thank you both for the reply. John if you could post pictures and details that would be a great benefit for all.
No problem, I need a day or two as the girl is still under her summer wraps, although we did have a slight scuff of snow last week!
JimVT
I have seen some extend over the boggie but usually they are half way over.
nikos
Jim
:whistling::whistling::whistling:I dont know if i am the guy with the white one, but my deflector is sharp.:brows:
Any way, I will try to measure the tin deflector (The correct size - factory dimension) on my ST4, BUT it also need measure the brackets, that attached to the boogie wheels.
Please wait. I will make the drawing for you guys in F.F. OK.
Regards Nikos
nikos
Some small problems with the fotos
nikos
PART N1
3D Paper Constuction of the tin Deflector in scale 1:2
photo n1 Top View of both side.
photo n2 Left Side
photo n3 Right Side
photo n4 Left Side
photo n5 Right Side
photo n6 Left Side
photo n7 TOP VIEW DRAWING - Left Side
photo n8 TOP VIEW DRAWING - Right Side
too be continued with Part N2
nikos
I forgot to mention that, both of the drawings (left and right) photo N7 and N8 are in 1:1 scale in centimeter and inches
nikos
PART N2 - The Brackets Drawing
photo N9 - Left Side -
Look at the rear bracket, attached in both sides the axle, instead the front one.
There are two holes on the front and two on the rear bracket.
Photo N10 Under the right side.
The black lines ------- show the points that has been bent the sheet metal
The red lines show the points of the adjusted bracket, under the deflector
nikos
PART N3 -
N11 - The front bracket- Left side
N12 - The rear bracket - left side
N13 - Watch out this photo - Details
The front and the rear bracket - Left side
N14 - The two rear holes on the deflector - Left side
N15 - Te two front holes on the Deflector - Left side
N16 - The boggie wheels - Left side.
N17 - The rear bracket - Right side.
Sorry about the photos but it was night.
Regards Nikos
Here are the snow deflectors I built, I had no pattern so it was a bit of a gamble but they work great and the price was good Be happy to measure them if required.
