utahwilson
Folks, I have decided to sell our trackmaster and trailer (16' 12k GVW). I feel this snowcat deserves a better home or at least someone with the time to work on and use. If you are Lakers fan it's blue/yellow pant job will be a bonus. I will try and post as much information as you need. However, you can always PM if it is not posted here. Price will be $11,000 (firm). This covers the cost of the trailer and the work I had done at Peterson Equipment out of Layton Utah. If you work for Peterson or related then the snowcat will cost you 25k. Currently, the cab is off as I intended to raise the cab. Also, the engine is out as I replaced the rear main seal. At this point since I am selling and most likely new buyer will want to strip it down I have saved you having to pull the engine. All the tires have been replaced and foam filled. I am even including a spare rear tire for your kids to play with since the tires are foam filled. I also, have two extra sprockets courtesy of Alaska. Right front sprocket had a crack and appeared to have been "bandaided". I have included some pictures and copies of the two invoices. Most likely there will be questions and additional posts. When I purchased this out of Las Vegas of all places - I was told the engine had been rebuilt as an 1835CC. Nothing to corroborate that other than it was covered in shinny chrome. Carb is a Weber. Please reply with any questions.
