Excavator shopping
I just had some work done on my property for a big slip that covered our road to the river.
I had a professional operator with me and he estimated we moved 300 tons of dirt, rocks and trees.
We used a John Deere 50 and it did the job nicely.
More rain here today. I feel lucky that we got the work done before the rain, ice and snow started up again.
Plenty more excavator work to be done. I had been thinking of renting one for a week, or month to get er done but now I'm wondering if buying one and taking my time getting the work done with thoughts of selling it in a year or two ...or maybe keep it for the invariable trail work that seems to need done every couple of years.. Sure would be handy.
Two recommendations so far:
No smaller than a 2 ft bucket
32HP or more. (which I think you'd need to run a 2 ft bucket.).
Any words of wisdom on this topic?
bczoom
Super Moderator
I don't have a lot of wisdom but will throw out these tidbits.
I think you can get by with something smaller then that JD 50. A friend of mine has a Bobcat compact (E32?) and it can really do some work.
When you're going to go look at one you're considering purchasing, if at all possible, take an experienced equipment operator with you. My same friend has years of experience and he can tell if it's operating as it should. E.g. when he bought his, he looked at something like 3 or 4 of them but could tell right away whether they had the power and performance the machine should have.
Good Tips Brian. I do plan to take Jack with me. He's been on most makes and knows them well.
I agree the JD 50 is more than I'd need. Plus even well used they are more than I would care to spend. The slip was a bigger job than most. I could have got it done with a smaller hoe but it sure would have taken longer. IF I had one at my disposal I would have waited till things dried up a bit before I would have tackled this job. Jack is due to be called out on a job and who knows when he'd be back and available so we got er done while he was free.
bczoom
Super Moderator
Do you have a backhoe on your tractor? It'll be slower than an excavator but a lot cheaper. If you don't have one, is buying a backhoe for your tractor or a used TLB an option?
Myself, if I can't do the work with the FEL and some kind of blade off the tractor, I borrow or get someone with a TLB to come over. At most, it costs me a case of beer.
I am fortunate enough to have friends with excavators and other heavy construction equipment that'll come over but rarely charge me. Even at $100/hour, the right piece of equipment with a good operator still works out nicely IMHO (as opposed to buying one).
as far as the compact equipment goes I would go Kubota or cat they seem to hold their value better.
I'm a big fan of Kubota. Not seeing a lot of Kubota excavators out there. More CAT, JD and Bobcat.
I'm just tossing around the idea for now. Shopping in the title is accurate but I have not made up my mind to buy anything at this point. I might pass on it all and rent like BC mentioned. That has been my strategy for the past 10 or 12 years but I suspect I've spent 12k or more. So I'm looking for the best long range bang for the buck and ....some fun.
I have considered a back hoe add on for my tractor. I am leery of the 3PH option and would only go sub frame. That runs 8k last I checked. Plus it would need changed out to brush hog weekly or monthly and it would be a shorter BH arm than the excavator. Other draw back is no blade like the excavators have. For trail maintenance the blade is a huge part of the job. Switching BH, to blade to brush hog on the tractor is not a trap I'm willing to fall for. If I decided to sell, selling would be harder also. If I was done and wanted money back from the excavator I think I could sell it easier than a specific BH for my particular tractor.
Just weighing all my options. Thanks for the input.
Bamby
In your case I feel it's important to have sheltered storage for it to preserve both it's reliability and value. If something stored outside is utilized often it's actually far better for it.
bill w
you could get away with a 35 size hoe as long as it has a quick disconnect for the bucket.then just get a cleanout bucket for it.just remember they get real tippy with a bigger bucket.still no issue when you have a blade.imho,cat is best but overpriced,best to look at something from a rental fleet as they have been maintained.john deere or kubota would be best bang for the buck.Bill w
Agree 100% Bamby. I have room in my pole barn. Will have to kick out one of the son in laws boats from winter storage but hey ...., they can get it wrapped. LOL
Interesting Bill. Would you elaborate on the quick disconnect and cleanout bucket please. All new to me. Thanks!!!!!
bczoom
Super Moderator
For the quick disconnect, not sure if they're all the same but on the Bobcat, you pull a cotter pin then knock out the big pin it was holding in place. It takes about a minute to swap buckets.
For the cleanout bucket, I think Bill is referring to the wider buckets that are normally used for cleaning once everything is loose. If you're doing serious digging, you go with a narrow bucket then put the wide bucket on to clean up.
Thanks Brian.
We used the quick disconnect to switch from jack hammer to using a bucket 5 years ago, so got that concept now.
I've never seen those big clean out buckets used. Seen pics of them but that is all new to me. Will learn. Slow but sure.
Thanks guys!!!!
Mill666er
I have a Volvo ECR38 with quick change buckets including 12” and 24” digging buckets and a 36” cleanout bucket and hydraulic thumb. The quick change is a wedge secured by a single 3/4” finger tight bolt. The thumb really increases the capability of the machine and would not buy one without it. I purchased the mini with 1500 hours from a Volvo Rents that was going out of business. The ECR38 is a 7200lb machine with canopy and 27hp Kubota diesel. It gets most things done but is slightly under powered. The cleanout bucket is great for finishing but it will tip the machine if you have it loaded. The thumb allows you to grab a length of I-beam or timber to use as a scrapper to grade/smooth out the hillside above and below the road.
I have no complaints with the machine and do all of my own service work. The only complaint is that Volvo will not direct sell parts to me online as a private owner and require me to go to a authorized dealer which went out of business and the reason I have the machine.
Nice machine. I agree the thumb would be indispensable. I never considered it for smoothing out a trail but for clearing areas that I need cleared it would sure be handy.
That is the same size machine I hope to find. I'm surprised a Volvo has a Kubota engine. I assumed Volvo made their own engines. I've seen plenty of boats with Volvo/Penta engines. Those are gas engines though.
XeVfTEUtaAqJHTqq
Master of Distraction
Yeah, just get a good name brand machine, take good care of it and you will do fine when you decide to sell it (if you ever decide to sell it).
NorthernRedneck
Those mini excavators are handy. Our campground owner has one. We're always borrowing it to dig holes and move dirt in our campsites when needed.
Canadian eh!!!
Mill666er
Sheesh, not sure where I came up with Kubota, it is Yanmar 27hp.
I got a little seat time in a Kubota x71-3. 2007 model. 2100 hours. Only used for septic work (LOL, like only driven by little ole lady to church).
Excavator would not start. They had replaced the glow plug button and it simply would not start. Sprayed a little ether in and it fired right up. Sounded okay. Worked it through the motions. Not bad. Seemed small to me. 18" bucket. Basic blade. It looked like the unit had sat outside most of it's life. Kinda rough in my estimation. 16.5k.
At least I got some seat time. No rush here, I'm simply trying to educate myself and understand the market.
It's that time of year again. I start dreaming of excavators.
Just saw a Used KUBOTA KX121-3R4 $23,500.00
Over 4k hours. I doubt I would even consider this one except it's on Neil Messicks lot. I've written asking Neil for more details but in the meantime .....how many hours can you expect out of one of these machines before major work needs done?
mla2ofus
Get the thumb attachment. It as handy as,well, your thumb. and if you do and it already has a thumb look at the area of the stick the thumb hits when it retracts for cracks, excessive wear.
doc I ran one like that they are pretty handy the one I used had the thumb and 2 quick attach buckets 4 k is nothing for those machines I work on stuff all the time with 30 to 40 k on the hour meter.
XeVfTEUtaAqJHTqq
You will want the thumb. I used a similar (newer) model last summer. That is a good sized machine. Big enough to get lots of things done.
Lookie what followed me home!!!! :D
Neil never got back with me but I found this 2017 Kubota KX033-4 with only 530 hours for about the same price as Messicks had on theirs. It is 10 years newer with a lot less hours plus it has the thumb, and quick attach for buckets. Just a 24" bucket came with it.
Rained all day here but brought her home from northeast Ohio. 4 hour drive.
Ready for some seat time now.
Jim_S
:thumb:
Have fun!
Jim_S
Meant to ask.
Why is it all alone at the end of the barn? It would be much happier alongside your Kubota tractor.
Is it in isolation in case it has the corona virus? :bolt:
:th_lmao:
Yep, it is in quarantine for 30 days. :yum:
Actually that was the least full stall, so I moved the 3PH rake and slid in the excavator. A 12ft utility trailer is next to it and the kids boats are in the other 3 stalls. Tractor gets the primo spot in the fully enclosed pole barn.
jwstewar
If you don't mind, what did that set you back? I'm gonna be shopping soon for some type of either excavator or backhoe. I'm tired of not being able to clean the ditch out when it needs it or I need to bury a goat...or a body. :)
Bamby
:thumbup: Nice looking unit and with just a bit of care it will likely outlive either of us. Did they provide service records? If or maybe even because I'd change out the fuel, air and hydraulic filters and grab a grease gun and familiarize myself where each and every fitting is on the machine to keep slop and wear at bay....
:yum: Hopefully no bodies.
I got what appeared to be a good deal on it. The fellow that owned it needed to sell now. It was a rental unit most of it's life. The guy I bought it from was the 2nd owner and had it for less than a year. He priced it for a quick sale, and I got lucky and called first. He had other calls but would not show it since he knew I was driving 4 hours to look at it last Sunday. I paid $24,500 for it.
Yep, I plan to do all that. No service records. I called my local Kubota dealer and gave them the serial number to ensure it was not on the stolen list and to see if they could tell me what service had been performed on it. It was not on the stolen list but he could not see what service (if any) had been done by any Kubota dealer.
The previous owner had tons of heavy duty equipment, so I suspect he took good care of it but I cannot be sure. This is smaller than the KX121-3 that Messicks had for $1000 less. That unit was 40hp, had over 4k hours and was 10 years older. I will rent if the occasion comes up where I need a really big excavator but I'm guessing this KX033-4 will be perfect for 99% of the work I want to accomplish.
Since the BX033-4 is a 2017 with what I consider low hours I should be able to recover most of my investment if the time comes that I need to sell it.
