Reply
Thread Tools Display Modes
  #1
Old 04-28-2018, 09:28 PM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
Default ST4 Snow Trac small bogie spare source
While I really appreciate CamOtis's wooden spare, I wanted a spare that was a bit more refined.
I found a near match at SurplusCenter.11x4.10-5 Smooth Tread Wheel Assembly1-4946
It is only a 4 ply, it has only a "plain bearing" AKA steel bushing. It has a 3/4" Bore.
I turned a axle that has the 1/2 bolt bore and a 3/4 OD with a boss at one end. The other end I welded an angle to to make sure the wheel turned on the 3/4 bushing not the unlubricated bolt.
I figure if I blow one of the lower bogies I will swap in the upper one and use the light weight spare in that position. It may not be a long term solution, but at U$24 it was cheap enough to have on hand to get me back to the trailer.
  #2
Old 04-29-2018, 05:54 AM
nikos's Avatar
nikos nikos is offline
nikos is on a distinguished road
Default Re: ST4 Snow Trac small bogie spare source
The only problem with this tyre of bogie wheels is on the bearings.
The plain bearings are not so strong in heavy-duty applications.
Nikos
  #3
Old 04-29-2018, 09:41 AM
JimVT's Avatar
JimVT JimVT is offline
He showed it to me .it is light but being used at the top of the track it may work out ok.
Jim
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #4
Old 04-29-2018, 10:47 AM
Cidertom's Avatar
I intend it to be a limited use spare, not a permanent replacement. It is greased and should hold up long enough to get back to civilization.
The Following User Says Thank You to Cidertom For This Useful Post:
300 H and H (04-30-2018)
  #5
Old 04-29-2018, 02:38 PM
sno-drifter's Avatar
sno-drifter sno-drifter is offline
sno-drifter is on a distinguished road
Why not cut the no bearing shaft out, machine a new one that will use the bearings that the OEM supplied, and weld in. Or better yet, machine it for tapered roller bearings. Maybe that is OEM, forgive my SnoTrack ignorance.
  #6
Old 04-29-2018, 03:04 PM
Cidertom's Avatar
The wheel is not heavy enough for that. The OEM bogies were forklift caster wheels and were made of some fairly heavy stock. This one would not survive long as the wheel disc is too light.
  #7
Old 04-29-2018, 05:31 PM
Gussets.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
In desperate need on snow Trac bogie tires Vwrob Snowcat Repairs, Parts & Problems Forum 2 01-29-2017 03:56 PM
Need two Snow trac bogie wheels Sno-Surfer Snowcat Repairs, Parts & Problems Forum 8 01-29-2014 08:03 PM
WTB-Snow-Trac bogie wheel assy. Reddog Snowcat Repairs, Parts & Problems Forum 3 01-08-2014 06:05 PM
Snow trac ST4 Bogie question redsqwrl Snowcat Repairs, Parts & Problems Forum 4 02-20-2013 02:15 PM
snow trac spare tank found JimVT Snowcat Restoration & Modification Projects Forum 0 11-11-2012 12:54 PM
