Snowcat Repairs, Parts & Problems Forum Snowcat Repairs, Parts Inquiries, Sources, Problems & Advice |
Thread Tools | Display Modes |
#1
excessive grease in the snow trac axles lubes your brake drum good.
i was cleaning them yesterday. i'm putting the blame on my electric grease gun. ![]()
__________________
Jim KF7RiN #185 snow trac 2004 pistenbully canyon |
The Following 3 Users Say Thank You to JimVT For This Useful Post: | ||
#2
But at least the drums won't rust.
The Following 2 Users Say Thank You to PJL For This Useful Post: | ||
Cidertom (03-22-2018), Sno-Surfer (03-22-2018) |
#3
electric grease guns are evil.
personally I would have a word with the trigger. |
The Following 2 Users Say Thank You to redsqwrl For This Useful Post: | ||
DAVENET (03-23-2018), jim slagle (03-22-2018) |
#4
How much work is needed to get to the brake drums? I am afraid that my brake drums may be greased as well so when I get the time I probably will have to clean them too. I know that Lyndon wrote somewhere that working on the brakes was a real hassle so I'm a bit afraid to start with it to be honest...
![]() Do you have any more pictures and could you describe the process a bit more in detail? Any special tools needed? |
#5
![]() Quote:
The hassle is if you need a new master cylinder to power the brakes. Hard to get to, to change out. Also the slave cylinders in mine turned out to be VW bus parts.. Even at their best, brakes on an ST4 two band track is lacking on a steep hill. Just remember if you absolutely have to stop, turn off the key and kill the engine in gear. You will definitely stop! Regards, Kirk
__________________
Snow trac ST4 #267 |
The Following 2 Users Say Thank You to 300 H and H For This Useful Post: | ||
Pontoon Princess (04-17-2018), SweGus (04-17-2018) |
#6
Thanks a lot for the info!
I am cautiously positive that my brake cylinder is ok since the feeling in the brake pedal is ok. It's just that it doesn't make much difference if I'm pressing as hard as I can on the pedal. So I'm really hoping that it's "only" a grease problem. |
#7
Your emergency brake should also slip.
I would try to brake the tracks near the drums. But The best place is just below the drum. Your sprockets could be reversed at the same time. i did mine while it was on my trailer. Everything is elevated and much easier to work on. No pictures were taken but brake cleaner ,rags .be Shure the drum is put on tight . Adjusting the brakes can also be done. Jim
__________________
#8
![]() Quote:
New wheel cylinder and my brakes were back. |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
1958 ST4 Snow Trac Friction Drive | vintagebike | Snowcat Restoration & Modification Projects Forum | 8 | 01-25-2019 04:16 AM |
Snow Trac replacement BRONZE drive sprockets | Melensdad | Snowcat Repairs, Parts & Problems Forum | 195 | 01-16-2018 12:15 PM |
Custom Snow-Trac Rear Drive Sprockets | Alaska Jay | Snowcat Restoration & Modification Projects Forum | 8 | 01-14-2017 07:14 PM |
Source For New Snow Trac/Master Drive Sprockets | teledawg | Snowcat Repairs, Parts & Problems Forum | 13 | 12-21-2010 10:12 PM |
snow trac drive chain tension | John Lumley | Snowcat Repairs, Parts & Problems Forum | 3 | 01-17-2010 10:28 PM |
