Reply
Thread Tools Display Modes
  #1
Old 02-25-2018, 10:41 PM
rockhead's Avatar
rockhead rockhead is online now
rockhead is on a distinguished road
Default 1450 Rearend issue
There is definitely something goofy in there :-( There is a notable drift to the right that goes away after a half mile, until then it is continual corrections to the left. Vibration ? Yup. Follow with overheating (rearend) with only a few miles in and a few hundred feet climb. Is there much/any faint hope its a band adjustment ? Oh and also a huge bang and the brake pedal does not engage anymore.
__________________
Two tracks good, four tracks bad ! -- George Orwell
  #2
Old 02-26-2018, 12:20 AM
PJL's Avatar
PJL PJL is online now
PJL is on a distinguished road
Default Re: 1450 Rearend issue
Sure sounds like a tight band, which would explain the overheating. First thing I would check. Big bang? Don't know but it sounds bad.
The Following User Says Thank You to PJL For This Useful Post:
rockhead (02-26-2018)
  #3
Old 02-26-2018, 12:37 AM
bobby wilkes bobby wilkes is offline
bobby wilkes is on a distinguished road
maybe tight band and then broke the ears off the band at the end ????
The Following User Says Thank You to bobby wilkes For This Useful Post:
  #4
Old 02-26-2018, 12:56 AM
rockhead's Avatar
Steering still functioned to limp back to the truck, I suspect the bang was something to do with the brake system, not sure if it was an addon, never looked too close. IIRC there is a disc brake on the drive shaft or at the rear end, I suspect there is a hose that could not handle the heat. The brake pedal worked exactly as a non-power brake would be expected to before the bang, after it is just mush.
So that much heat that fast on bad bands, wow, maybe I get luck . . .
__________________
The Following User Says Thank You to rockhead For This Useful Post:
bobby wilkes (02-26-2018)
  #5
Old 02-26-2018, 04:31 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
rock head,
my 1450 has a drum brake at the differential input, I call that the pinion.
My brake made moving my cat very difficult as crud was wadding up under and between the drum and shoes. I cleaned that out and it rolled freely again.
My point, perhaps you have two problems
The Following User Says Thank You to redsqwrl For This Useful Post:
  #6
Old 02-26-2018, 10:28 PM
rockhead's Avatar
Quote:
Originally Posted by redsqwrl View Post
rock head,
Oh its gonna be a happy day when have only two problems
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
need help identifying rearend jeffcardinalfan Military Vehicles Forum 1 04-02-2017 09:29 PM
Looking for help with OC4 rearend for 1404 IMP Treewizzard Snowcat Repairs, Parts & Problems Forum 4 01-30-2015 02:50 AM
Looking at a DMC 1450 Manistee Snowcat Adventure & Usage Forum 11 04-12-2013 08:36 PM
Is this a Immigration issue or just a DUI issue? bczoom Political Debate Forum 4 04-09-2007 01:03 PM
