Reply
Thread Tools Display Modes
  #1
Old 02-22-2018, 06:06 PM
Stuart Stuart is offline
Junior Member
Stuart is on a distinguished road
Default 1987 bombardier sw 48 starter
Has anyone taken the starter off a 1987 sw 48 (300 cu in inline ford 6 cylinder) , if so is there an easy way around it . From what I see it appears to be a tight spot to get at and hard to see. Any info will be appreciated .Thanks in advance
  #2
Old 03-03-2018, 08:56 PM
Bobcatbob Bobcatbob is offline
Bobcatbob is on a distinguished road
Default Re: 1987 bombardier sw 48 starter
I would drop the muffler down from the exhaust flange if possible (if the studs and nuts aren’t rusted solid). This will give you a little room to get to the bolt behind the starter (thank god there is only one). I’ve been rebuilding an SW48 and didn’t remove the starter until I pulled the engine....though my exhaust flange studs were completely rusted, ended up cutting them off and using the “blue” wrench.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
26' 1987 Slickcraft 265 SC RSS User Boat Classified Forum 0 04-20-2012 11:44 AM
Bombardier J5 Starter bishop_J5 Snowcat Repairs, Parts & Problems Forum 11 02-14-2009 06:49 PM
1987 Bombardier SV252G - 134hrs TT wannagoflying Snowcat Restoration & Modification Projects Forum 2 12-19-2008 10:32 PM
Bombardier SW 48 starter snowed-in Snowcat Repairs, Parts & Problems Forum 4 02-20-2008 05:05 PM
1987 Tucker on e-bay scooterd Snowcat Repairs, Parts & Problems Forum 1 11-18-2006 02:11 PM
