Reply
Thread Tools Display Modes
  #1
Old 02-07-2018, 04:11 PM
Whipper Whipper is offline
Junior Member
Whipper is on a distinguished road
Default St4 snow-trac boat gas tank
I have removed my fuel tank from inside the cab. Does anyone know the biggest size boat tank that will fit outside on the fender next to the hood? Size,brand, mounting? Thx for any help..Jim
__________________
Instagram Resort_61
  #2
Old 02-07-2018, 09:22 PM
300 H and H's Avatar
300 H and H 300 H and H is offline
300 H and H will become famous soon enough
Default Re: St4 snow-trac boat gas tank
Mine has a 12 gallon on it. I discovered the manufacturer is out of business, as they were bought out by a competitor. The name escapes me at the moment..
The Company who bought them out still makes a 12 gallon that is with in 1/2" of the same size as the tank I have.. It is also about the same capacity of the original tank in the cab.
I have been considering going back to a fabricated steel tank in the cab. I don't like that much weight out on the fender, as you can see the bow it has caused over the years, from being a bit to heavy. A smaller tank, of course would be lighter when full. 8X12= 96 lbs. of fuel roughly... Quite a bit of weight..
Mine is mounted behind the right hand headlight, in a tight fitting aluminum tray some one made to fit tightly to the tank. It is also in the basket some one built on each side of mine..
https://www.youtube.com/watch?v=Qtd_WXprL4A
Look at the 50 second mark to see mine.
__________________
Snow trac ST4 #267
The Following User Says Thank You to 300 H and H For This Useful Post:
Whipper (02-03-2019)
  #3
Old 02-08-2018, 04:03 AM
nikos's Avatar
nikos nikos is offline
nikos is on a distinguished road
Whipper
  #4
Old 02-08-2018, 07:43 AM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
moellermarine.com
__________________
Formerly Blackfin4Bluefin
The Following 2 Users Say Thank You to Track Addict For This Useful Post:
300 H and H (02-08-2018), Whipper (02-03-2019)
  #5
Old 02-08-2018, 10:07 AM
JimVT's Avatar
JimVT JimVT is offline
Default Re: St4 snow-trac boat gas tank claimm
Quote:
Originally Posted by nikos View Post
Whipper
12 gallon and he claims to see over it. but i would go with two of the 5 or 6 gal if going that way.
he'll be at mccall
this may not be the largest but the largest i seen. a member snowtrac nome has one setup for going a long distance. pm him.
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
The Following User Says Thank You to JimVT For This Useful Post:
  #6
Old 02-08-2018, 07:52 PM
couchloafer's Avatar
couchloafer couchloafer is offline
couchloafer is on a distinguished road
10" x 33" 11 gallon http://www.aluminumgastanks.net/
The Following 2 Users Say Thank You to couchloafer For This Useful Post:
nikos (02-09-2018), Whipper (02-03-2019)
  #7
Old 02-08-2018, 08:03 PM
Snowtrac Nome's Avatar
I believe mine is a 15 gallon tank fits on the front fender in front of the windshield
__________________
Don
1962 st-4
KL2ZF
The Following User Says Thank You to Snowtrac Nome For This Useful Post:
  #8
Old 02-09-2018, 05:12 AM
nikos's Avatar
Quote:
he'll be at mccall
11 Gallon tank , in front of the windshield, on the right side of the fender.
Also i can carry extra fuel with 2 Jerry Can = 2 X 11 gallon. 22 gallon = 80 liters.
I am not going in long distances so the jerrycan is only to carry fuel, only for the main tank.
But if i decide to make a long distance ......Ride, i make sure that i have only the necessary.
Nikos
The Following User Says Thank You to nikos For This Useful Post:
  #9
Old 02-09-2018, 10:05 AM
JimVT's Avatar
then the results is this.
__________________
Jim KF7RiN
#185 snow trac
The Following 2 Users Say Thank You to JimVT For This Useful Post:
Northcoast (02-09-2018), Whipper (02-03-2019)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
snow trac spare tank found JimVT Snowcat Restoration & Modification Projects Forum 0 11-11-2012 12:54 PM
snow trac gas tank sender clhsmith Snowcat Restoration & Modification Projects Forum 4 10-11-2009 02:35 PM
Snow Trac Anti Tank Vehicle Paul Ramsden Snowcat History, Articles, Manuals, Brochures & Recollections Forum 19 01-13-2008 08:53 PM
Snow Trac : Fuel Tank Repair & Installation Snowcat Operations Snowcat Restoration & Modification Projects Forum 4 01-29-2006 10:44 PM
Snow Trac fuel tank option Snowcat Operations Snowcat Restoration & Modification Projects Forum 3 01-15-2006 02:06 AM
