Reply
Thread Tools Display Modes
  #1
Old 01-30-2018, 12:14 PM
4TrackCat's Avatar
4TrackCat 4TrackCat is offline
4TrackCat is on a distinguished road
Default Tucker roller grease fitting
I'm sure this has been discussed plenty over the years but I haven't been able to find a clear answer.
On the steel track Tuckers, what grease gun tip works the best? The three I have tried from the local auto part store put more grease on the ground then in the bearing.
I'm also finding that the tips I've purchased are soft and smear closed after a few uses.
I manage to get through it, but if someone knows of the right tip I can buy, I'd appreciate it.
__________________
1969 Tucker 544A
1979 Litefoot - sold
  #2
Old 01-30-2018, 12:41 PM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
Default Re: Tucker roller grease fitting
Which version of rollers do you have? zerk? needle hole with check? pipe plug?
  #3
Old 01-30-2018, 01:01 PM
4TrackCat's Avatar
Quote:
I have the needle hole with the check. Prior to greasing, I've gotten in the habit of actuating the checks with a small nail and that seems to help a bit.
__________________
1969 Tucker 544A
  #4
Old 01-30-2018, 01:05 PM
Sno-Surfer's Avatar
Sno-Surfer Sno-Surfer is offline
Sno-Surfer is on a distinguished road
All I can add is that I also notice how the ends of the needle tip will close up after a while. Makes for a real good forearm workout. But once you open it back up I think it works ok. A bit of a pain to hold with pressure on the rollers but I get through it. Mine is just a generic one from Napa.
And by the way, I bought one of those lock on units for the zirk fittings suggested by Cidertom and I am real happy with it. Works like a champ.
The Following User Says Thank You to Sno-Surfer For This Useful Post:
4TrackCat (01-30-2018)
  #5
Old 01-30-2018, 01:14 PM
4TrackCat's Avatar
This is the skinny needle I've been using without much success.
I just received a text from one of the Tucker gods sharing their favorite grease tip. You can see the difference for sure. I may have to find a lathe and try fabricating one similar.
I wonder if Tucker used anything special or just relied on an off the shelf tip? I haven't seen anything like the short one at any of my local shops.
__________________
1969 Tucker 544A
The Following User Says Thank You to 4TrackCat For This Useful Post:
Sno-Surfer (01-30-2018)
  #6
Old 01-30-2018, 01:25 PM
Cidertom's Avatar
I've never tried one, but have seen needle grease tips made with a hard rubber compound. Might be worth a shot if you can find one.
My lathe has needle grease fittings. They are a pain, but any other style would stick out too much.
The Following User Says Thank You to Cidertom For This Useful Post:
  #7
Old 01-30-2018, 02:17 PM
tom's Avatar
tom tom is offline
Any idea who made this tip?
__________________
Tom
1963 Tucker 443-A
  #8
Old 01-30-2018, 02:26 PM
4TrackCat's Avatar
Quote:
No idea...... I've been trying to find it on the interweb but believe it to be a unicorn of sorts.
__________________
1969 Tucker 544A
tom (01-30-2018)
  #9
Old 01-30-2018, 02:36 PM
Bombi1 Bombi1 is offline
Bombi1 is on a distinguished road
http://www.godarmachinery.com/product_p/g33756.htm
This looks like it.
The Following 2 Users Say Thank You to Bombi1 For This Useful Post:
sno-drifter (01-31-2018), tom (01-30-2018)
  #10
Old 01-30-2018, 02:38 PM
4TrackCat's Avatar
Quote:
Originally Posted by Bombi1 View Post
Nice work Bombi1!
I can understand the $9.45 purchase price but just can't bring myself to pay an additional $22.11 to ship it. Call me a cheap bastard, but dang..... $31.36 for a grease fitting??
__________________
1969 Tucker 544A
The Following 2 Users Say Thank You to 4TrackCat For This Useful Post:
Bombi1 (01-30-2018), Sno-Surfer (01-30-2018)
  #11
Old 01-30-2018, 03:36 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Another
https://www.amazon.com/Alemite-Z737-...grease+fitting
__________________
The Tracks you leave today, Will lead you to the future!
The Following 4 Users Say Thank You to MNoutdoors For This Useful Post:
4TrackCat (01-30-2018), Bombi1 (01-30-2018), sno-drifter (01-31-2018), tom (01-30-2018)
  #12
Old 01-30-2018, 03:45 PM
4TrackCat's Avatar
Quote:
Originally Posted by MNoutdoors View Post
I just ordered the one on Amazon. It sure looks similar and way less shipping. I'll report back the good, bad and the ugly.
__________________
1969 Tucker 544A
The Following 3 Users Say Thank You to 4TrackCat For This Useful Post:
Bombi1 (01-30-2018), Cidertom (01-30-2018), tom (03-04-2018)
  #13
Old 01-30-2018, 07:11 PM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
Think mine came from tractor supply. Broke and bent a few of the needle ones. Rubber one was similar to people’s view on rubber tracks varying.
Tbe blunt nose one similar to your pic works best and in the they are in the aisle at tractor supply: ? Countryline
__________________
Formerly Blackfin4Bluefin
  #14
Old 01-30-2018, 07:45 PM
I take the above statement back: https://www.toolsource.com/grease-gu...-p-144770.html
Legacy lube link. It quick connects on the end of standard fitting then the coupler slides down to make it solid. Gives you a nice grip to push on.
Little Scottís special sauce and a 12v electric gun 12 tubes and hour done !
Lots of other fails in be box.
__________________
The Following User Says Thank You to Track Addict For This Useful Post:
  #15
Old 01-30-2018, 10:17 PM
Bad link. Try Ebay https://rover.ebay.com/rover/0/0/0?m...2F142270117686
__________________
  #16
Old 01-30-2018, 10:34 PM
tom's Avatar
tom tom is offline
Thanks everyone this has been very helpful!
__________________
Tom
1963 Tucker 443-A
The Following User Says Thank You to tom For This Useful Post:
  #17
Old 02-05-2018, 09:29 AM
sno-drifter's Avatar
sno-drifter sno-drifter is offline
sno-drifter is on a distinguished road
This https://www.ebay.com/itm/142270117686?ul_noapp=true is NOT the fitting you want for Tucker steel pontoon rollers. Stick with the Alemite Z737.
Often a couple of the female grease fittings get distorted from contact with steel etc. In this case the grease will kiss you or squirt in your eye. LIGHTLY touch the offender with a three fluted countersink cutter on your drill. Don't remove any more matl. than necessary to give a good seal. Hopefully you don't have to hit that one again as it is easy to cut through the thin matl of the outer ball check.
  #18
Old 02-05-2018, 09:50 PM
I use this counter sink cutter.
The Following User Says Thank You to sno-drifter For This Useful Post:
4TrackCat (02-05-2018)
  #19
Old 03-04-2018, 12:33 AM
tom's Avatar
tom tom is offline
I tried out the Alamite 737 today and I was amazed at how well it worked. Very little waste and seemed to be the answer to the hard to grease ones. Made greasing the rollers almost fun! Thanks MN Outdoors and Sno-Drifter for the tip..literally!
__________________
Tom
1963 Tucker 443-A
4TrackCat (03-04-2018)
  #20
Old 03-04-2018, 11:31 AM
Here you go orange people.
The Following 3 Users Say Thank You to sno-drifter For This Useful Post:
4TrackCat (03-04-2018), Pontoon Princess (03-04-2018), Sno-Surfer (03-08-2018)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Getting grease to a stubborn roller tom Snowcat Repairs, Parts & Problems Forum 4 01-16-2018 03:27 PM
Bombi BR100 - zerk grease fitting HartsHaven Snowcat Restoration & Modification Projects Forum 10 11-25-2015 07:28 PM
Cordless Grease Gun vs Tucker Steel Track tom Snowcat Repairs, Parts & Problems Forum 9 07-06-2015 12:27 PM
Tucker Roller Grease Track Addict Snowcat Repairs, Parts & Problems Forum 7 06-22-2015 10:58 PM
Tucker trac roller bearings Billy Snowcat Repairs, Parts & Problems Forum 5 10-31-2007 09:00 PM
