Reply
Thread Tools Display Modes
  #41
Old 03-20-2018, 09:49 AM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
Default Re: may have found issue on my rebuild
Intended as humor......
intervention (Picture a bed sheet with that painted on it and four of your snow cat minded friends looking at you):
in regards to the excess heat affect the valve pushrod gap......
"It is thoughts like that that will keep you on the couch."
These VW engines are about the single most abused engine platform on the planet. run it. if its clattering, rev it higher until the fan sound drowns out the tappet noise, when the fan tips squeal back off just a bit.
Prep:
Put a vice grip, a flat and phillips screw driver in your pocket...... throw a set of points somewhere on the dash and a spare belt (must be used) under the seat......
Stoned hippies drove 100's of thousands of miles in these things and still do today.
Therapy over, "get off the couch and back on the saddle, and what ever you do, have no fun."
The Following 6 Users Say Thank You to redsqwrl For This Useful Post:
300 H and H (03-21-2018), Cidertom (03-20-2018), nikos (03-22-2018), PJL (03-21-2018), Pontoon Princess (03-20-2018), Sno-Surfer (03-20-2018)
  #42
Old 03-20-2018, 10:37 AM
Sno-Surfer's Avatar
Sno-Surfer Sno-Surfer is offline
Sno-Surfer is on a distinguished road
Sounds like you might just need to carry a spare and give it another run. Fingers crossed.
The Following User Says Thank You to Sno-Surfer For This Useful Post:
  #43
Old 03-20-2018, 11:46 PM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
Had to order belt(s) in. No one in the gigantic metropolis of Corvallis had one for sale. Talked to two guys who have sand rails with vw power. Both had experienced the shredding under long high speed runs. "live with it, and keep a spare handy". Neither knew of any special race/high speed belt. There may be better belts though, and this summer I will spend some clock cycles on it. Several of the belt mfg's limit the belt speed to 6500/7000 FPM. My math says I'm pushing over 10000 FPM at max sustained speed. Gates has belts rated to 20000 FPM so that may be an option, providing I can get one to fit.
If they come in I will hit the snow (if any) again Sunday. I will NOT give up.
The Following User Says Thank You to Cidertom For This Useful Post:
Sno-Surfer (03-21-2018)
  #44
Old 03-21-2018, 11:10 AM
NorCal's Avatar
NorCal NorCal is offline
NorCal is on a distinguished road
Do not give up....belt is a 9.5x905
__________________
1975 Snow Trac ST4 #1948
1949 Tucker Sno Cat Model 524 Now in Tuckerville!!
Vintage VW's & Snowmobiles
The Following User Says Thank You to NorCal For This Useful Post:
  #45
Old 04-23-2018, 07:20 PM
Cidertom's Avatar
I will end this episode of the rebuild. Achieved Silcox Hut On Mt Hood today.
The Following 7 Users Say Thank You to Cidertom For This Useful Post:
Bombi1 (04-24-2018), jim slagle  (04-23-2018), Logger1965 (04-23-2018), mikemikelle (04-24-2018), PJL (04-23-2018), redsqwrl (04-23-2018), Snowshadow (04-23-2018)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
J5 rebuild sask Snowcat Restoration & Modification Projects Forum 7 01-21-2016 08:40 AM
C4 Rebuild bdpeek Snowcat Restoration & Modification Projects Forum 3 06-17-2011 10:11 AM
OC-12 rebuild Snowcat Operations THIOKOL/LMC/DMC Technical Issues Forum 0 08-14-2007 10:52 AM
Is this a Immigration issue or just a DUI issue? bczoom Political Debate Forum 4 04-09-2007 12:03 PM
