Reply
Thread Tools Display Modes
  #1
Old 01-22-2018, 12:37 AM
schmidt schmidt is offline
schmidt is on a distinguished road
Default ST4 SnowTrac 600 x 100 Rear Tire
Our foam filled Trelleborg 600 x 100 rear tire has failed due to the foam breaking down. Does anyone have any replacement suggestions? Saw the earlier thread for these tires (see attached). Any comments would be greatly appreciated. Brad, Mountain Home Lodge.
  #2
Old 01-22-2018, 09:58 AM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
Default Re: ST4 SnowTrac 600 x 100 Rear Tire
mnoutdoors has them. price gone up
  #3
Old 01-27-2018, 12:23 AM
Update: This new Alpine Guide tire noted above is working great using a tube and no not going with foam. Mounting the tire to the wheel did take two of us and ensuring the tube did not roll or get pinched. The fit on the ST4 is good, with no problem fitting in the track guides and overall diameter maybe slightly larger then the original 600x100, but no problems.
The Following User Says Thank You to schmidt For This Useful Post:
redsqwrl (01-28-2018)
  #4
Old 04-24-2018, 03:11 PM
OldShopTeacher OldShopTeacher is offline
OldShopTeacher is on a distinguished road
What tubes do these tires use? Thanks.
  #5
Old 04-24-2018, 05:11 PM
Hi, I believe its this tube: http://www.alpineguidetire.com/16-tubes/ You may want to contact them, very helpful. FYI: this is the tire I use on the rear of the ST4 which works well:http://www.alpineguidetire.com/4-50-...now-coach-etc/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
SnowTrac Rear Rim - 5 lug SnowTrac Hunter Snowcat Repairs, Parts & Problems Forum 2 01-12-2018 01:20 PM
1404 Imp flat tire repair in the field &tire pressure rodre THIOKOL/LMC/DMC Technical Issues Forum 0 01-03-2018 10:06 PM
SnowTrac ST4 Small Tire 4.00-4 New Source schmidt Snowcat Repairs, Parts & Problems Forum 5 03-15-2016 08:57 AM
can tire studs be put in any tire? JimVT Cars, Trucks Forum 3 12-24-2013 01:55 PM
Tire off Rim thcri Tractor Forum 12 02-26-2007 09:20 AM
