Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat History, Articles, Manuals, Brochures & Recollections Forum
Snowcat History, Articles, Manuals, Brochures & Recollections Forum Publications, specifications, production information for snow cats
Reply
Thread Tools Display Modes
  #1
Old 07-28-2014, 10:45 AM
Lyndon's Avatar
Lyndon Lyndon is offline
Lyndon is on a distinguished road
Default VW Industrial manual
http://www.thesamba.com/vw/archives/...ers_Manual.pdf
The LINK, or:PDF file
March_1969_VW_Industrial_Owners_Manual.pdf
This manual covers both the 122 engine, which is the "40 HP", industrial 1192 CC, that only actually produces 35 HP, and the later 1584 CC, (1600), 53 HP, 126 Engine.
IF you have a 126 it will have 126 ahead of the serial number right on the block below the pedistal that supports the generator and where you put oil in. Also 126 will be quite visable on the intake maniforld. If your old 126 'bites-the-dust', save the old manifold, it is larger than normal and was only used on a few years of VW Bus. It will fit other 1600's. Being larger it "Breathes" better.
122's also have the number preceeding the serial number. These are not good candidates for rebuilding. Get a 1600.
Snow Trac's Prior to about 1966 have the 122 engine. Snow Trac's, Trac Masters, and Snow Masters after '66 have the 126.
A 126 has a 10 to 1 compression ratio, great for high altitude! But it perfers premium fuel.
Some 1966 machines were reported to have a 1300 version of the 126, which should have sported a 123 number, but I've never seen one. The article by the famous British race car driver who became a writer for one of the Car magatines indicated that his machine had one.
That article is reprinted in this forum, or at least WAS?
__________________
" A Snow Cat Will See you thru times of NO WINCH, better than a WINCH will see you thru Times of NO SNOW CAT!"
The Following 2 Users Say Thank You to Lyndon For This Useful Post:
jask (07-31-2014), KT3survivor (01-07-2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
J5 Operators Manual + Parts Manual SW-64F uppercanada Snowcat Restoration & Modification Projects Forum 27 09-30-2018 06:38 PM
Industrial Snowmobiles snotrans Snowcat Classifieds (For Sale / Wanted) Forum 0 07-06-2011 06:11 PM
Porsche Industrial / ST4 Lyndon Snowcat Restoration & Modification Projects Forum 18 12-27-2008 08:25 PM
VW industrial engines northernopposition Introductions Forum 8 02-26-2007 05:55 PM
Industrial doors bczoom Other Projects Forum 1 11-03-2006 01:20 PM
