Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat History, Articles, Manuals, Brochures & Recollections Forum
Snowcat History, Articles, Manuals, Brochures & Recollections Forum Publications, specifications, production information for snow cats
Reply
Thread Tools Display Modes
  #1
Old 09-30-2014, 08:29 PM
racer15 racer15 is offline
Junior Member
racer15 is on a distinguished road
Default Thiokol 3700 hydromaster
Hey all, I just acquired a (new to me) Thiokol 3700 that will need a little TLC. I'm wondering if anyone here knows where I can obtain a set of manuals for one. Any help would be great. Thanks.
  #2
Old 09-30-2014, 08:52 PM
Snowtrac Nome's Avatar
Default Re: Thiokol 3700 hydromaster
try paul at pbl enterprises
__________________
Don
1962 st-4
KL2ZF
The Following User Says Thank You to Snowtrac Nome For This Useful Post:
racer15 (10-03-2014)
  #3
Old 09-30-2014, 08:54 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
I have a 3700 manual, I'm in 54913
make an offer..... I will dig into it to see if it a later or early manual.
The Following User Says Thank You to redsqwrl For This Useful Post:
  #4
Old 10-01-2014, 12:18 PM
jask jask is offline
jask is on a distinguished road
I think there is one on Ebay as well.
The Following User Says Thank You to jask For This Useful Post:
  #5
Old 10-02-2014, 07:03 PM
Dr. Zaugg Dr. Zaugg is offline
Dr. Zaugg is on a distinguished road
I most likely have a manual. I would need your serial number to give you the right one.
Those have lots of surprises in changes that are not recorded.
Paul
The Following User Says Thank You to Dr. Zaugg For This Useful Post:
  #6
Old 10-03-2014, 02:11 PM
Junior Member
Thanks for the responses guys, I forgot to write down the serial number.(dumb I know) I will remember to get it when I head back up which will be in a week or two. It seems to run just fine, Just needs a lot of TLC. I'm new to the snowcat world but we have a remote off grid cabin in the Sierras that we have used snowmobiles to get to in the past. The snowcat seems like a good fit. Thanks Again.
  #7
Old 10-06-2014, 11:58 AM
Please note that the Allis-Chalmers engine will not start like a gasoline engine when at the cabin. I suggest a small generator powerful enough to run the block heater and you will be fine. ALSO, the maximum speed that engine likes is 2100 RPM. LMC ran it way higher which caused many engine failures. It likes to run between 1900 and 2100 RPM and will serve you very well if you keep within that range.
racer15 (10-06-2014)
  #8
Old 10-06-2014, 02:18 PM
we ran the same A/C engines in 60 k generators for years in the military at 1800 rpm they will run for ever that way. the only down fall is the motor is kind of becoming a dinosaur like my 380 ford the ac motor does have the roosamaster injection pump in it and that will likely be your weak spot add a quart of 2 cycle oil to your #1 fuel and you can double the life of the pump.
__________________
Don
1962 st-4
KL2ZF
  #9
Old 10-07-2014, 04:17 AM
Alaska Snow Cat's Avatar
Alaska Snow Cat Alaska Snow Cat is offline
Alaska Snow Cat is on a distinguished road
I had a Thiokol 3700AC with the Allis Chalmers and it was one of the best diesels I have owned. As I recall the max torque output was at 1700 rpm with a redline at 2100rpm. The old timer I use to talk to at the then LMC factory (Ted?) told me to run it at 1700 and it would last forever, anything above that was just wasting fuel and taking life out of the engine. I looked at a newer DMC 3700AC that was up for auction once and it operated at a higher RPM according to the placards on the dash but I bet as the others have said, it shortened the life. Would't surprise me if the factory just turned up the juice a little to boast a higher HP number.
It was a great cat and the only downside I could think of is it was easy to over stroke the pumps if you were working it hard like cutting hard icy moguls while towing a drag. The central location of the cab plus the mechanical sticks made the operation buttery smooth compared to the brake type steering of my first cats. Certainly sold me on hydrostatics for the type of snowcatting I do.
I am sure I have an old copy of the manual in my files if no one else comes through for you.
Randy
The Following User Says Thank You to Alaska Snow Cat For This Useful Post:
racer15 (10-07-2014)
  #10
Old 10-07-2014, 05:47 AM
Ted Finchum was a wealth of information. I think I even still have his card in my desk.
He was right, there is as much power at 1700 as 1900. anything over that was a waste.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
76' Thiokol 2100B, 86' LMC 3700, Modified Thiokol 2100C "Vancat" Peak Snowcat Classifieds (For Sale / Wanted) Forum 5 11-20-2012 11:09 PM
WTB: Thiokol 3700 TuckerSnoCat Snowcat Classifieds (For Sale / Wanted) Forum 3 12-19-2011 06:53 PM
Thiokol 3700 - wouldn't run - easy fix TuckerSnoCat THIOKOL/LMC/DMC Technical Issues Forum 0 12-12-2011 04:24 AM
Thiokol 3700 Axle Question TuckerSnoCat THIOKOL/LMC/DMC Technical Issues Forum 2 06-10-2011 01:06 AM
Thiokol 3700 series model T9L-345 CA-SNOW THIOKOL/LMC/DMC Technical Issues Forum 10 02-14-2008 07:33 PM
