Reply
Thread Tools Display Modes
  #21
Old 03-15-2017, 01:21 AM
schmidt schmidt is offline
schmidt is on a distinguished road
Default Re: Snowtrac Drive Sprockets on CAD
Hi Steve,
I would be interested in what I believe is the older style. See photo on this post for Mountain Home Lodge. I may know of someone else who maybe interested too, not sure on the type at this time, but that can easily be confirmed. Can anyone comment on comparing composite to the original brass? Quieter, longevity, wear issues, etc. Thanks, Brad Mountain Home Lodge
  #22
Old 03-15-2017, 08:52 AM
JimVT's Avatar
JimVT JimVT is offline
some really tuff material is available now . if you went with that you may have good success. I only seen one in use and it was worn bad .I have no idea what was used to make it.
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #23
Old 03-18-2017, 10:26 PM
teledawg's Avatar
teledawg teledawg is offline
teledawg is on a distinguished road
Look here: http://www.forumsforums.com/3_9/show...&postcount=123
__________________
1968 Trac Master ST4B #0922
  #24
Old 03-28-2017, 09:40 PM
SnowTrac Hunter's Avatar
SnowTrac Hunter SnowTrac Hunter is offline
SnowTrac Hunter is on a distinguished road
Someone had posted dimensions previously for sprockets. Neils sent me an STP file which I could open with Wedge, but without having a compatible version of AutoCAD I couldn't dimension.
The dimensions that were posted in another thread were incorrect, so I am trying to correct per layout.
Outer Tooth Diameter - 17-1/4" (17.25")
Outer Tooth Radius - 8-5/8" (8.625")
Base Diameter - 15-3/8" (15.375")
Base Radius - 7-11/16" (7.6875")
Tooth Degrees - 90*, 77.1428571*, 51.4285714*, 25.7142857
Circle Circumference - 54.19247"
Tooth Center to Tooth Center - 3-7/8" minus (3.8708")
Tooth Tip Width - 1" (Need to Verify)
Space at Base - 1-1/2" (Need to Verify)
Thickness - 1/2" to 1" UHMW depending on model.
Hope this is helpful. I have an older two band model. I would like to start out with 1/2" and see if it is durable enough before I modify my sprocket to fit thicker UHMW. Prices of UHMW vary depending on location. I purchased a piece of 18" x 10' for $350 in Anchorage, Alaska. You may be able to find cheaper in the Lower 48.
Thanks,
Joe
__________________
Joe Billy
1964 ST4 #446
  #25
Old 03-28-2017, 09:41 PM
14 Tooth Sprocket
__________________
Joe Billy
1964 ST4 #446
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Snowtrac sprockets MNoutdoors ATA (Alaska Track Association) Forum 24 05-18-2018 09:46 PM
Bombardier Drive Sprockets DDR Snowcat Restoration & Modification Projects Forum 3 08-08-2016 10:23 PM
Tucker Drive Sprockets Track Addict Snowcat Classifieds (For Sale / Wanted) Forum 2 12-03-2012 01:38 PM
snowtrac sprockets brianf Snowcat Restoration & Modification Projects Forum 7 09-14-2012 12:03 PM
601 drive sprockets darryl Snowcat Restoration & Modification Projects Forum 3 10-17-2007 05:56 PM
