Reply
Thread Tools Display Modes
  #1
Old 03-07-2017, 08:50 PM
vintagebike vintagebike is offline
vintagebike is on a distinguished road
Default 1958 Sprocket Drive ST4 ReConstruction Started
I got the new HiTorque 12volt/6 gear starter installed today. Spins great and with new plugs and plug connectors runs great. I'm not sure what parts move around when under way. Will anything hit the battery cable lug with the starter set up this way? Looks like, after the experts saw ours at McCallin' 2017, I will need new sprockets. It's been pretty quiet about having new ones available after all the talk and hubbub last year.
  #2
Old 03-07-2017, 09:07 PM
Sno-Surfer's Avatar
Sno-Surfer Sno-Surfer is offline
Sno-Surfer is on a distinguished road
Default Re: 1958 Sprocket Drive ST4 ReConstruction Started
Well shoot, I had a set of sprockets in my truck when I was there. I think they were the right style for yours too. I thought I'd check with the snow trac owners to see if anyone needed a set but didn't get around to it.
  #3
Old 03-08-2017, 08:50 AM
JimVT's Avatar
JimVT JimVT is offline
reversing the bolt on your steering from the other way will help some. I've had no issues with my cables.
jim
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #4
Old 03-08-2017, 11:23 AM
NorCal's Avatar
NorCal NorCal is offline
NorCal is on a distinguished road
Where did you buy that starter? I think I am going to need one, mine spins slow when it gets hot.
Looking forward to see progress on your friction drive 58, Is that the oldest one in the US?
__________________
1975 Snow Trac ST4 #1948
1949 Tucker Sno Cat Model 524 Now in Tuckerville!!
Vintage VW's & Snowmobiles
  #5
Old 03-08-2017, 12:28 PM
CB Performance in California was the best retail deal I could find -#IMI-105. I asked for and got a 10% discount for Presidents' Day. Maybe wait till St. Patrick's Day? My Friction Drive might not just be the oldest one but the only one still with the original friction drive here in North America? I know of at least one older than mine still in Sweden.
  #6
Old 03-13-2017, 01:28 AM
JimVT's Avatar
Quote:
Attachment 89985
Attachment 89986
Attachment 89987
I checked the clearance on mine today and it was about 3/4 inch now .one photo shows the pin before it reversed it. The wire and the steering linkage is tight so I think i'm ok.
thanks for pointing this out.
__________________
Jim KF7RiN
#185 snow trac
  #7
Old 03-13-2017, 02:24 AM
Default Need a part
Does anyone have a spare flat head through pin for connecting the steering shaft as shown in Jim's first photo- the one he turned around? Looks like mine has a shade tree fix using a bolt and two nuts that may give me some problems with my new starter.
  #8
Old 03-13-2017, 07:23 AM
300 H and H's Avatar
300 H and H 300 H and H is offline
300 H and H will become famous soon enough
Default Re: Need a part
What size of bolt did they put in?
Know anyone with a turning lathe? If not, I could make you one. Of course I need an address to send it. PM me if you can't find something that works for you there.
__________________
Snow trac ST4 #267
  #9
Old 03-13-2017, 11:32 AM
JimVT's Avatar
if you can read my broken caliper. If any longer you may not get it in. I beveled the end on mine
this is part 17 in our manual ST 3001
__________________
Jim KF7RiN
#185 snow trac
The Following User Says Thank You to JimVT For This Useful Post:
300 H and H (03-13-2017)
  #10
Old 03-13-2017, 11:37 AM
NorCal's Avatar
Did you have to cut the mounting "ears" off the new starter like factory and use the little clips to mount it? Its looks like you got it to bolt into the factory holes on tranny.
__________________
  #11
Old 03-13-2017, 11:52 AM
JimVT's Avatar
no cutting on the newer starter . it has a base that turns and you use the factory vw mounting holes. I would check your clearance on both ends of your
steering linkage 25 ST 1045 after installing. Also be sure you use the matching starter gear that fits your flywheel ring gear.
__________________
Jim KF7RiN
#185 snow trac
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
J5 Drive sprocket movement aaron89 Snowcat Restoration & Modification Projects Forum 3 09-05-2016 06:59 PM
j5 drive sprocket welderwade Snowcat Repairs, Parts & Problems Forum 6 09-10-2014 09:06 PM
J5 Bombardier Drive Sprocket sheppy Snowcat Repairs, Parts & Problems Forum 6 09-28-2013 05:16 PM
Drive Sprocket ST4 barj Snowcat Restoration & Modification Projects Forum 17 06-28-2010 09:59 PM
Drive Sprocket Rebuild IMP Snowcat Repairs, Parts & Problems Forum 15 12-06-2007 03:17 PM
