Reply
Thread Tools Display Modes
  #1
Old 03-06-2017, 12:42 PM
Mill666er's Avatar
Mill666er Mill666er is offline
Mill666er is on a distinguished road
Default 1962 Tucker 443 generator polarizing?
My battery is not charging yet I have 14v on the generator. I had the battery out for a few months on a charger in the off season so I assume I needed to polarize the generator to get it to work but get conflicting methods for doing so on the web. I'm thinking that touching the battery + to the field lug on the regulator is correct for this setup. The bottom relay never closes during high idle but if I manually close it I get charge voltage to the battery. I did remove and clean all connections as well as contacts in the regulator.
__________________
Rob Miller
Winthrop, WA
1962 Tucker 443
1969 Aktiv ST4 #1332
1970's Ridge Runner Trailboss
1981 Tucker 542A-HD
The Following User Says Thank You to Mill666er For This Useful Post:
Pontoon Princess (03-06-2017)
  #2
Old 03-06-2017, 02:26 PM
Snowtrac Nome's Avatar
Default Re: 1962 Tucker 443 generator polarizing?
take the belt off hook up pos and neg to a 12 volt battery watch it spin than put every thing together again if it still fails to charge get a new regulator.
__________________
Don
1962 st-4
KL2ZF
  #3
Old 03-06-2017, 04:34 PM
topwelder44 topwelder44 is offline
topwelder44 is on a distinguished road
get a chevy single wire------I use them all the time
  #4
Old 03-06-2017, 09:12 PM
I don't have much use for a delcotron single wire alternator, but its not hard to hook up the 3 wire model. or even the ford or Chrysler external regulator alternators.
__________________
Don
1962 st-4
KL2ZF
  #5
Old 03-08-2017, 06:22 PM
Mill666er's Avatar
Hooked the battery up to the generator and it spun the correct direction and also told me the bushings were a little dry. Pulled the regulator off and found that the thin shunt wire was broken in a couple different spots. I was able to find a rebuilt regulator on eBay for $27 with free shipping.
__________________
Rob Miller
Winthrop, WA
1962 Tucker 443
1981 Tucker 542A-HD
  #6
Old 03-09-2017, 08:51 AM
zekeusa's Avatar
zekeusa zekeusa is offline
zekeusa is on a distinguished road
I would keep it original. The generator is just like a DC motor. The faster you spin it the more voltage it puts out. That's why you need a voltage regulator. You can test the generator by "motorizing" it. Once in a while you need to polarize it. Any good older "Motor" manual will have how to do it.
__________________
Did you remember my cookies?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoon help and recommendations for 1962 Tucker 443 Mill666er Snowcat Repairs, Parts & Problems Forum 63 03-10-2016 01:32 PM
1962 tucker Sno-Cat 443A for sale C.A. HENDRIXDEFENSE Snowcat Classifieds (For Sale / Wanted) Forum 1 01-17-2015 01:38 PM
1962 TUCKER 443A on E-Pay, Ends 11/10/2012 Mtn-Track Snowcat Classifieds (For Sale / Wanted) Forum 6 11-26-2012 11:47 PM
1962 F-100 Bobcat Cars, Trucks Forum 6 07-25-2007 11:33 PM
