Reply
Thread Tools Display Modes
  #1
Old 02-28-2017, 01:06 PM
4TrackCat's Avatar
4TrackCat 4TrackCat is offline
4TrackCat is on a distinguished road
Default 500 series Tucker axle nut size?
Can anyone confirm what size the axle hub nut tool needs to be to remove my pontoon?
1969 Tucker 542 with 1 Ton International axles. I haven't been able to get a measurement and the part stores need to know if it has A/C or not......
I looked at some old international listings on Rock Auto. The old Scout calls for a 2-1/16" nut. Of course, none of the part stores seem to be able to order that size....
Any help would be appreciated.
4TrackCat
__________________
1969 Tucker 544A
1979 Litefoot - sold
  #2
Old 02-28-2017, 01:45 PM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
Default Re: 500 series Tucker axle nut size?
Think the 500 is a bit different. I have a nut on an early taper axle that uses and extension and it is 2" od. I also have tucker long axles that are 7/8-14 and uses 1 5/16 socket.
Attached is the parts breakdown for your rig. They have different part numbers across models but I would bet they are the same part on some items. I think #18 on the end of #13 is what your are after and would guess 1 5/16 for what appears to be that 7/8-14 thread on the extension.
__________________
Formerly Blackfin4Bluefin
The Following User Says Thank You to Track Addict For This Useful Post:
4TrackCat (02-28-2017)
  #3
Old 02-28-2017, 01:47 PM
If the thread above is correct this is your nut: https://www.boltdepot.com/Product-De...?product=14390
__________________
  #4
Old 02-28-2017, 02:18 PM
4TrackCat's Avatar
Great parts list! Thanks
I'm actually looking at #9 and #11. These large nuts are what are keeping me from being able to remove the pontoon. The entire hub needs to come off of the axle while still inside the fiberglass pontoon and drive spool.
__________________
1969 Tucker 544A
  #5
Old 02-28-2017, 02:42 PM
That nut looks closer to this one which is off and early taper axle hub extension . 2" socket.
If you have a harbor freight they have big sets cheap so you have some
Options. I try not to use their tools but the big stuff I use infrequently gets the job done!
__________________
  #6
Old 02-28-2017, 07:28 PM
sno-drifter's Avatar
sno-drifter sno-drifter is offline
sno-drifter is on a distinguished road
4TrackCat
500 series axle 2 1/2 six point
700 series axle 2 9/16 eight point
It is easy to make a socket by bending 1/8 in thick material and welding a broken 1/2 inch drive socket to a plate on top of the bent six point material. You will not be applying big torque to it. Make sure it is deep enough to clear the axle housing.
The Following User Says Thank You to sno-drifter For This Useful Post:
  #7
Old 02-28-2017, 07:31 PM
4TrackCat's Avatar
Perfect found one and for 13 bucks at O'Reilly Auto Parts
__________________
1969 Tucker 544A
  #8
Old 02-28-2017, 07:32 PM
Should have just waited for the pros !
__________________
  #9
Old 02-28-2017, 08:59 PM
4TrackCat's Avatar
Well, the socket I bought was not a good fit. It is stamped and the QC inspector should be fired. It was 2-1/2" but measured well under and would not go on the nut. I found a better quality one that fit but it was 3/4 drive which I am not tooled up with. I welded a 1/2" drive socket on it and it worked well. Pontoon is off!
__________________
1969 Tucker 544A
The Following 3 Users Say Thank You to 4TrackCat For This Useful Post:
Kristi Kt-4 (02-28-2017), Pontoon Princess (02-28-2017), Sno-Surfer (03-01-2017)
  #10
Old 03-01-2017, 12:30 PM
What kind of repair you have going on with the cat?
__________________
  #11
Old 03-01-2017, 12:44 PM
4TrackCat's Avatar
I'll be replacing all 4 metal skid plates with new stainless ones. I'll also be getting some fiberglass repair work done while it's apart. I want to look over all of the metal roller track components and may preventively change out the hub bearings and inner seal.
__________________
1969 Tucker 544A
Pontoon Princess (03-01-2017), Sno-Surfer (03-01-2017), tatman (03-02-2017)
  #12
Old 03-01-2017, 01:36 PM
Sno-Surfer's Avatar
Sno-Surfer Sno-Surfer is offline
Sno-Surfer is on a distinguished road
I'm taking a lot better notes on Tucker repairs now that I have one. But man you all make it look so easy with your big shops with lifts and forklifts etc! I have a driveway and a floor jack (and some Tucker friends and some determination). So far I'm pretty good at changing cotter pins.
I had the top captive rail come off on our trip up Jug Mt which I'm pretty sure was my issue with the track skipping on climbs. That's the piece I found laying in the snow when I stopped. Off to the Tucker Tech academy this Friday to see about fixing it.
Great looking 500 machine you have!
The Following 2 Users Say Thank You to Sno-Surfer For This Useful Post:
4TrackCat (03-01-2017), Pontoon Princess (03-01-2017)
  #13
Old 03-01-2017, 02:06 PM
4TrackCat's Avatar
I picked up that little pallet stacker lift for $40 at an auction. Just may be the best deal I've ever gotten. I use it for just about everything from changing tires to lifting trailer tongues onto trucks to fixing snowcats. Saves my back a lot!
Sent from my Moto G (4) using Tapatalk
__________________
1969 Tucker 544A
The Following 2 Users Say Thank You to 4TrackCat For This Useful Post:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tucker Axle seal Mother Tucker Snowcat Repairs, Parts & Problems Forum 2 01-18-2016 05:24 PM
WTB Tucker Axle Hub/Extension adschemy1 Snowcat Classifieds (For Sale / Wanted) Forum 2 11-17-2014 08:54 PM
Tucker Axle Hubs Track Addict Snowcat Classifieds (For Sale / Wanted) Forum 0 12-06-2012 10:03 AM
axle wanted , 600 series thiokol wrongway Snowcat Classifieds (For Sale / Wanted) Forum 2 01-31-2010 01:11 PM
Tucker 300 Series sno cats ALLEN PARSONS Snowcat Restoration & Modification Projects Forum 0 03-05-2008 04:56 PM
