Reply
Thread Tools Display Modes
  #1
Old 02-14-2017, 01:30 PM
jask jask is offline
jask is on a distinguished road
Default ST17A pivot pin frozen
I have been doing some work on the drive of ST193 and need to remove the ST17A assembly, the pin that it pivots on and that secures it to the frame ( ST3002 ) is rusted in solid!! I have removed the center bolt that secures it.. used a drift and hammer, a drift and sledge, used a blue wrench to heat up the outside and tried as best as I can to soak it with oil. My concern now is that (1) my pounding on the shaft ends might end up peening them wider and causing more problems and (2) that the pivot arms of the ST17A are going to be damaged.
does anybody have experience or ideas to share? otherwise I am going to saw the ST3002 and carrier tube on either side inboard of the ST17A pivot arms to get that out of the way while I really beat the heck out of what will be left of the pivot pin.
  #2
Old 02-15-2017, 12:29 AM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
Default Re: ST17A pivot pin frozen
Can you give a pix (of part or manual)? I can't find that part number in my book.
  #3
Old 02-15-2017, 03:05 PM
Snowtrac Nome's Avatar
I think he is talking about the pin between the spring and eye bolts they can get really froze in and there is no room to work on them
__________________
Don
1962 st-4
KL2ZF
  #4
Old 02-15-2017, 09:59 PM
JimVT's Avatar
JimVT JimVT is offline
this was gone over last month on another snow trac.
it is just a soft bolt the best way is to cut it 3002 with a saw.
jim
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #5
Old 02-17-2017, 01:05 PM
ST17A is the aluminum casting that carries the axle and bronze drive gear.. the pin I am talking about is at the bottom of it and passes through a tube at the very front of the frame allowing the front tension adjustment of the track.
Jim thanks, I did end up cutting it.
The part is on pg 20 ( fig 8 ) of the 1963 full manual and is the part in the lower right corner of the page, it is a smooth length of mild steel shaft that is about 3/4" and is cross drilled in the center to accept a retained bolt that passes through it and the housing it fits inside.
  #6
Old 02-17-2017, 01:48 PM
JimVT's Avatar
when replacing the pin I was just told this morning to get a threaded hex cap type bolt and remove most of the treads. then when you need to remove it can be turned.
my st4 came from the prince Rupert airport,it was used to run up to the radar tower when new.
jim
__________________
Jim KF7RiN
#185 snow trac
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
my tub is frozen luvs Junkman's Corner 24 02-02-2014 12:45 PM
frozen tracks crafttree Snowcat Adventure & Usage Forum 12 10-23-2010 04:54 AM
Frozen Pea Recall pirate_girl Misc Consumers Forum 2 10-17-2010 06:53 PM
Frozen Challenge Junkman Junkman's Corner 0 05-16-2010 12:07 PM
Pivot Trailer? Bobcat Trailers & Tow Vehicles Forum 5 02-09-2009 01:44 PM
Copyright 2002 - 2017 www.ForumsForums.com
