Reply
Thread Tools Display Modes
  #1
Old 02-13-2017, 09:55 PM
boondocker570 boondocker570 is offline
Junior Member
boondocker570 is on a distinguished road
Default Thiokol 1201b hydraulic question
What type of oil is used in a 1201b Thikol for engine mounted hydraulic system.Taank is under driver's seat belt drive pump.thànk you
  #2
Old 02-14-2017, 12:04 AM
PJL's Avatar
PJL PJL is offline
PJL is on a distinguished road
Default Re: Thiokol 1201b hydraulic question
That system circulates the differential oil. Here is a pretty good thread on it. Snow Cat Pat is an expert on those.
http://www.forumsforums.com/3_9/showthread.php?t=7760
  #3
Old 02-14-2017, 02:32 AM
Alaska Snow Cat's Avatar
Alaska Snow Cat Alaska Snow Cat is offline
Alaska Snow Cat is on a distinguished road
Not necessarily, my Sprite had a under the seat tank and engine driven pump from the factory, no differential involvement. Sounds like Boondocker's might be the same. I used John Deere Hygaurd Hydraulic fluid in both the aux hydraulics and in the differential.
  #4
Old 02-14-2017, 06:45 AM
Junior Member
Thanks guys,Alaska snow cat has the same system as mine ,under seat tank with belt driven pump.Belts are new ,tight and still have a good amount of belt squeal even after running the machine for hours.I can only feather the levers slightly to help avoid this.If I try to operate hydraulics quickly I get all belt squeal.
  #5
Old 02-14-2017, 09:46 AM
Snowcat Pat's Avatar
Snowcat Pat Snowcat Pat is offline
Snowcat Pat is on a distinguished road
I have always used AW32 in stand alone hydraulics in the snowcats. Been told its no good but it has served me well. Probably won't stop your belt squeal though.
-Pat
  #6
Old 02-14-2017, 10:15 AM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
I fought belt squeal until I realized the sheaves were glazed. I blamed every item in the circuit trying new fluid, different valves and mounts for the pump.
my pulleys were shot, my belts would bottom out and no amount of ajax or belt dressing will prevail. new belts worked for a bit then a couple air head moves on the sticks would slip the belts and the rest is history.
  #7
Old 02-14-2017, 01:04 PM
topwelder44 topwelder44 is offline
topwelder44 is on a distinguished road
I agree ---glazed pulleys---u could try a wider belt it might not bottom out in the v---might get you by till the snow melts---check and see if you can go to double pulleys when you change them
  #8
Old 02-14-2017, 01:28 PM
Mine had a wide cog belt installed, squeal proof!
  #9
Old 02-14-2017, 02:21 PM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
Have you tried a powertwist belt? People say they work better and last longer than traditional v belts. No personal experience just and idea?
http://www.fennerdrives.com/powertwist-plus/
__________________
Formerly Blackfin4Bluefin
  #10
Old 02-14-2017, 04:38 PM
Snowtrac Nome's Avatar
the 2 problems you are likely to have is you are using a 7500 series automotive drive belt when you need a 9000 series belt, the 7500 is a 3/8 belt. try a wider belt the other one is a you need is a fractional drive belt it uses a different angle v and is intended for looser operations commonly you see them on equipment like snow blowers and tillers. also 8 gpm is about the largest pump you are going to get away with at 2000 psi with belt drive
__________________
Don
1962 st-4
KL2ZF
  #11
Old 02-14-2017, 11:59 PM
PJL's Avatar
PJL PJL is offline
Quote:
Ahh, didn't know that. Thanks. Mine has the diff oil system.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1201B thiokol spryte MontanaPete1 THIOKOL/LMC/DMC Technical Issues Forum 10 02-05-2017 06:37 PM
WTS THIOKOL 1201B-55 telbert Snowcat Classifieds (For Sale / Wanted) Forum 4 07-16-2016 08:54 PM
WTS THIOKOL 1201B-55 telbert Snowcat Classifieds (For Sale / Wanted) Forum 3 07-05-2015 10:56 PM
looking for a radiator protector for a thiokol 1201b 1201b willys Snowcat Repairs, Parts & Problems Forum 0 12-25-2012 04:31 PM
Thiokol 1201B-41 question scooterd THIOKOL/LMC/DMC Technical Issues Forum 12 03-20-2007 12:04 PM
Copyright © 2002 - 2017 www.ForumsForums.com
