Reply
Thread Tools Display Modes
  #1
Old 02-09-2017, 07:17 PM
caldonia caldonia is offline
caldonia is on a distinguished road
Default Ram steer
Who can tell me about ram steer? Sounds like a power boost for an old brake steer cat.
  #2
Old 02-09-2017, 07:33 PM
undy undy is offline
undy is on a distinguished road
Default Re: Ram steer
It uses a hydraulic ram to control the turning angle of the drag relative to the cat. Sort of like an articulated farm tractor. You bend it in the middle, and it goes around the corner.
With brake steer, you're braking one track to turn the cat, and then the drag has to follow.
__________________
Bones heal and chicks dig scars.
If I die in my ski boots, I win.
It is better to go skiing and think of God, than go to church and think of sport. Fridjof Nansen
  #3
Old 02-09-2017, 07:35 PM
Great video, shows the hydraulic ram: https://www.youtube.com/watch?v=hinpz5GT8gc
__________________
  #4
Old 02-09-2017, 07:48 PM
Thanks Undy
My drag is a bit less sophisticated.
The Following User Says Thank You to caldonia For This Useful Post:
jim slagle  (02-12-2017)
  #5
Old 02-09-2017, 09:01 PM
Quote:
Don't feel bad. My first one was a 2x4 with some chainlink attached, attached by rope to a snowmobile.
__________________
  #6
Old 02-09-2017, 10:18 PM
Snowtrac Nome's Avatar
actually the steering on most all twin track snow cats isn't brake steer but planetary steering. You drop speed on the inside track by about 20 percent and increase outside speed by 20percent. What folks call a steering brake isn't really that ,but a band locking a planetary drum to drop inside speed pushing power through another set of planetary's in the center differential to give the overdrive to the outside track. This way both tracks are being driven in a turn. This system sucks up a lot of horsepower and the steering bands will slip and heat up loosing their friction if used a lot the oc manual stated to use a short jerking action to make turns and not to slip the band too much or accelerated wear will happen I find on our wind blown hard pack that I have to make plenty wide turns because of band slippage, I actually broke a band last winter.
__________________
Don
1962 st-4
KL2ZF
  #7
Old 02-12-2017, 05:56 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
this is a ram steer from a shop industrial (mogul master) drag.
basically a hydraulic RAM that STEERS you.
balanced ones have the hoses crossed so the machine steers the same in both directions.
if it had one ram it would steer quicker left or right as the volume on the in stroke displaces less fluid.
notice the end has a swivel for pitch.
the round elements seat into pockets for Yaw.
I intend to install an orbital valve and steer my 2100 project like a car, or tucker, ST4 ect...
  #8
Old 02-12-2017, 05:57 PM
redsqwrl's Avatar
Ugh this camera!!!! ever since it hit the floor at Nite owls!!!!
  #9
Old 02-12-2017, 06:02 PM
Kristi Kt-4's Avatar
Kristi Kt-4 Kristi Kt-4 is offline
Kristi Kt-4 is on a distinguished road
Is that a flat deck Tucker I see in the blurry background? HAHA
  #10
Old 02-12-2017, 06:30 PM
redsqwrl's Avatar
perhaps?
now is it chain drive is the question!!!!
  #11
Old 02-12-2017, 08:47 PM
topwelder44 topwelder44 is offline
topwelder44 is on a distinguished road
really don't think you need ram steer-----ram steer is great for smaller cats pulling way to big and heavy drags----years ago clubs would buy bombi cats to groom with and than put ram steer on them ---a bombi was not built to pull a load--so they would burn out brakes---and would loose traction turning because of breaking one track---ram steer keeps both tracks driving all the time-----don't know where you go with your cat ---but taking every other silde slip plate off your tracks will help you turn better---and alternate them inside and outside-----when cutting down pb. tracks I 45 the edges on the cleats it will turn easier and help it not walk out of a track on hard ground---here is a pic. of my trail no ram steer needed---this pic.was using my geo tracker on mattracks I also use a sv200
The Following User Says Thank You to topwelder44 For This Useful Post:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
WTB - want to buy a ram steer setup for a tow behind groomer sleddogracer Snowcat Classifieds (For Sale / Wanted) Forum 4 09-18-2013 08:13 PM
wtb ram steer setup sleddogracer Snowcat Repairs, Parts & Problems Forum 0 09-15-2013 10:14 PM
Ram steer for 252 Thinice Snowcat Repairs, Parts & Problems Forum 7 06-04-2012 12:04 PM
How does this steer? berg Snowcat Restoration & Modification Projects Forum 3 04-17-2012 06:07 PM
Skid steer in trouble @ 10 below MNoutdoors Snowcat Adventure & Usage Forum 15 12-28-2010 01:37 PM
Copyright 2002 - 2017 www.ForumsForums.com
