Reply
Thread Tools Display Modes
  #1
Old 02-04-2017, 11:07 AM
Backyardski's Avatar
Backyardski Backyardski is offline
Mumbler
Backyardski is on a distinguished road
Default BR-60 differential fluid
Good morning,
I'm headed to the John Deere dealer today (way closer than cat or amsoil dealer) for some hyguard, gotta do something with that lonely machine. I've put 3 hrs on it this year, two years in a row without decent snow, hoping for some February and March blizzards.....
Is 30 wt the correct oil? Prinoth mechanic said atf but I've read otherwise here.
Thanks!
  #2
Old 02-04-2017, 12:43 PM
Mumbler
Default Re: BR-60 differential fluid
Well I just found out there is hygard and low viscosity hygard, got the regular, 5 gal $60
  #3
Old 02-04-2017, 02:28 PM
Mumbler
Here's the hy gard specs page in case anyone is interested
https://t.jdparts.deere.com/partsmkt...nHydraulic.htm
The Following 3 Users Say Thank You to Backyardski For This Useful Post:
PJL (02-04-2017), Snowcat Pat (02-04-2017), wannagoflying (02-05-2017)
  #4
Old 02-05-2017, 08:32 PM
KickerM's Avatar
KickerM KickerM is offline
KickerM is on a distinguished road
From what I've been told, I use anything with a CAT TO-4 Spec, I see JD Hygard is a CAT TO-2 Spec.
Shell Spirax S4 CX 30wt is $57 per 5 gals
CAT TO-4 30 wt is $87 per 5gals
CAT TO-4 30 wt (Store Brand) is $76 per 5 Gals
Heres the link to Cats statement plus if your read farther on it gives the details on how to test your own oil to make sure it meets TO-4 Specs
https://parts.cat.com/wcs-static/pdfs/TO4+06-23-06.pdf
Hope this helps and keep on trackin!
__________________
Cowboy Logic: Bad decisions usually make good stories!
1964 Thikol 1202 CrewCab "Sold"
1972 Bombardier SV250S
1987 LMC 3700 CF
1998 M923A2 5-Ton
The Following User Says Thank You to KickerM For This Useful Post:
Backyardski (02-05-2017)
  #5
Old 02-05-2017, 10:11 PM
Mumbler
Holy balls, that's some technical info there. I think my wife would take issue if I tried the oil in the blender test or had oil samples in the freezer. Hmmm, going to use the hy gard this time since I have it, gotta be better than the water oil mix that was in there....
I'll make the trip to Caterpillar next time
  #6
Old 02-24-2017, 01:55 AM
labradorshooter's Avatar
labradorshooter labradorshooter is offline
Junior Member
labradorshooter is on a distinguished road
I use ultramar to-4 oil in my br100 and I like it. I use 10W because its common for the temp to dip below -30 here during dec,jan and Feb and I only use the machine for short periods doing light work. for long hauls or warmer temps id use the 30w.
Reply
Tags
bombardier dif. fluid
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Imp Hyd fluid airdale Snowcat Repairs, Parts & Problems Forum 2 12-05-2012 01:43 AM
1973 SV200 Differential Fluid? snowbird Snowcat Repairs, Parts & Problems Forum 7 11-13-2011 09:32 AM
What is wrong with RV fluid thcri Open Forum 3 10-09-2011 06:28 PM
bombi differential fluid JimVT Snowcat Repairs, Parts & Problems Forum 3 11-21-2009 10:34 PM
Low headlight fluid BadAttitude Open Forum 4 12-02-2005 11:07 AM
Copyright 2002 - 2017 www.ForumsForums.com
