Reply
Thread Tools Display Modes
  #21
Old 01-29-2017, 12:26 AM
Cidertom's Avatar
Cidertom Cidertom is online now
Cidertom is on a distinguished road
Default Re: Variator Wear ??
With that damage, and the general state of "what else has?" if it were mine, the power package would be out of the chassis. I found it easier to pull the front off the trac and pull everything out that way. Others have pulled out the top, dropped out the bottom. Clean it all, and see what else is broken.
Besides, you want a fresh start anyway. Yep it's a pain, but you're better finding it in the shop than the field. Trust me, BTDT.
Here to advise, or just commiserate.
CT
  #22
Old 01-29-2017, 12:38 AM
JimVT's Avatar
JimVT JimVT is offline
I would talk to christer motlind christer@klovsjo.com
he may has some parts.
jim
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #23
Old 01-29-2017, 01:49 AM
Lyndon's Avatar
Lyndon Lyndon is online now
Lyndon is on a distinguished road
This is just a "Long-winded" opinion but: When I go 20 miles out in to areas where no one else is, in a 30 to 50 year old snow cat, I try and make the machine reliable so that I can get back home in one piece, and so that I don't have to abandon a machine where it might get vandalized. If you live in Nome, like Don, this becomes more serious. But even for the "Week-end warrior" it's nice to go out and explore around, instead of spending you time fixing a broke-down machine. That being said, I would recommend pulling the Engine, Transaxel/Variator and seeing what else the previous owners broke/lost/damaged and fix it all.
Twice in Alaska I encountered people that had been offered a ride in a 'Track-Rig' to go hunting. Their response was something to the effect: "Uh,... No thanks, I'd rather Hunt, than spend my time fixing the track rig"
Your Brakes, and Fuel system are sure to need attention. Good time to deal with the starter too as they are very difficult to access.
If the machine breaks down it's difficult to Tow, and one needs a bigger snow cat to tow it, that or a helicopter, and they tend to be prohibitively expensive.
Go thru the Tracks, and the Wheels.
Remember: You can not call "Triple A" and expect to get roadside assistance on the side of Mt. Rainier!
I know you won't be on Mt. Rainier anytime soon, but you may have a similar place to play.
Lyndon
__________________
" A Snow Cat Will See you thru times of NO WINCH, better than a WINCH will see you thru Times of NO SNOW CAT!"
The Following 6 Users Say Thank You to Lyndon For This Useful Post:
300 H and H (01-29-2017), jim slagle  (02-12-2017), nikos (02-13-2017), NorCal (02-06-2017), Northcoast (02-05-2017), Snowcat Pat (01-29-2017)
  #24
Old 01-29-2017, 10:30 AM
oilline oilline is offline
Junior Member
oilline is on a distinguished road
To be honest I was suprised at what good condition everything seems to be in part from the bearing breaking down. Everything came apart nicely, no frozen bushes or pins. There was a general lack of grease and the grease hoses were broken off
I will strip the whole lot in the summer, but for now I just want to get it functioning again as I have other projects on the go and a non steering Snowtrac can't just be pushed around the garage .
I ll get the opposite side bearing cap off to measure up to make one.
Hope I can get the tower off in situ . All the debris from the top bearing shouldn't of got past the bottom bearing so I don't need to worry about bits of metal in the bottom end
  #25
Old 01-29-2017, 07:07 PM
Junior Member
Tower off no problem. All the debris from the collapsed bearing was contained in the tower above the bottom bearing. Oil seal diameter for top bearing a bit chewed up. Will see if it's salvageable when I get the old outer bearing race out. Don't know how I'm getting it out though. Can't get a puller on it, can't knock out from the back. Will then see about repairing the broken mounting flange. Would like a replacement tower really if anybody has a spare. Ultimately I could make a new tower if all else fails.
  #26
Old 02-05-2017, 08:34 AM
Junior Member
ST2016A oil seal diameter ground down to 33mm to remove the damage caused by loose ball bearings getting mashed around in there. Not all the damage removed but enough to get an oil seal on
Making of a ST13A
Not a good picture but note the damage below the bearing diameter where the remains of the old bearing made a bit of a mess.
Boring out to remove the damage and fit a sleeve to get back to 52mm diameter
The Following 2 Users Say Thank You to oilline For This Useful Post:
300 H and H (02-12-2017), nikos (02-06-2017)
  #27
Old 02-05-2017, 09:44 PM
Cidertom's Avatar
Nice work. I've had to make several parts so far. Very glad I have lathe and mill. And know how to use them.
TEW
  #28
Old 02-12-2017, 04:24 PM
Junior Member
All back together now and good as new.
Repairs to the variator tower
Sleeve fitted and recess milled for grease port
Top face milled flat
Bearing cap completed
All assembled before fitting
300 H and H (02-12-2017), nikos (02-13-2017)
  #29
Old 02-12-2017, 05:39 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
like most folks here, somebody has some skills!
nice work
The Following User Says Thank You to redsqwrl For This Useful Post:
DAVENET (02-13-2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Variator Lyndon Snowcat Repairs, Parts & Problems Forum 38 01-03-2016 03:41 PM
? about the variator dave_dj1 Snowcat Restoration & Modification Projects Forum 4 12-07-2011 04:03 AM
St4 variator FishingAk49 Snowcat Repairs, Parts & Problems Forum 2 11-01-2011 11:02 PM
What is a ST4 variator worth? jasper Snowcat Repairs, Parts & Problems Forum 1 09-09-2009 11:58 AM
variator adjustments clhsmith Snowcat Repairs, Parts & Problems Forum 3 01-20-2008 10:31 PM
Copyright 2002 - 2017 www.ForumsForums.com
