Reply
Thread Tools Display Modes
  #1
Old 01-23-2017, 12:57 PM
aaron tucker's Avatar
aaron tucker aaron tucker is offline
aaron tucker is on a distinguished road
Default freighter track tension?
how tight should my tracks be on the freighter ? if I pull with some force on the back of the pontoon where there are no rails it pulls out about an inch . is that normal or should I tighten them ?
  #2
Old 01-23-2017, 01:20 PM
Pontoon Princess's Avatar
Pontoon Princess Pontoon Princess is offline
"pontoon piranha"
Pontoon Princess is on a distinguished road
Default Re: freighter track tension?
still okay, and when moving it is greater than that, but would not let it get any looser
  #3
Old 01-25-2017, 02:57 PM
awesome I have the tool to tighten them just dident want to over tighten them . should I try and bend every link alittle or just bend one here and there or just try to do one ?
  #4
Old 01-26-2017, 02:28 PM
bump
  #5
Old 01-26-2017, 07:33 PM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
http://www.goldcordmine.com/manuals/...hru%20900A.pdf
__________________
Formerly Blackfin4Bluefin
The Following 2 Users Say Thank You to Track Addict For This Useful Post:
aaron tucker (01-27-2017), sno-drifter (01-29-2017)
  #6
Old 01-27-2017, 03:02 PM
thanks !
looks like I got some work to do ....
  #7
Old 01-28-2017, 08:37 AM
Tucker Someday Tucker Someday is online now
Tucker Someday is on a distinguished road
Just curious, why do they have you bend the connecting links when the rail on either end of the pontoon is adjustable? Isn't that why you can loosen the rail sections on the ends and adjust them out? I haven't had to do it yet on mine so curious.
  #8
Old 01-28-2017, 08:44 AM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Quote:
Not all pontoons have the adjustable ends
__________________
Have a nice day, NSA kind of like NASA but one less "A"
The Following User Says Thank You to MNoutdoors For This Useful Post:
Tucker Someday (01-28-2017)
  #9
Old 01-29-2017, 11:21 PM
sno-drifter sno-drifter is offline
sno-drifter is on a distinguished road
The first photo shows lifting the track to check for clearance, not adjusting the links center to center distance, as the pontoon shown has adjustable rails.
Be sure to adjust the end rail curves the same distance on each side of the pontoon. Hook your tape measure in the round hole between the outer pontoon bearing and the big drain hole on the outside and the same size hole on the inside. Distance does not have to be the same on each end, just make sure distance is the same side to side on each end. Got it?
The Following User Says Thank You to sno-drifter For This Useful Post:
Tucker Someday (01-29-2017)
  #10
Old 01-30-2017, 11:17 AM
How you address the distance on the early pontoons that had one adjuster?
__________________
  #11
Old 01-30-2017, 06:06 PM
My cat is a 53 and has no track adjusters, just bend the links to tighten . I did one pontoon and was very surprised how fast just alittle bend took the slack out nicely .now I'm just trying to alittle everywhere so its even .
I just got the fuel takes cleaned . the guy at the shop said that he had never seen a sending unit with that big/long of a float . do you think i can rebuild the sending unit for the fuel gauge ?
  #12
Old 01-30-2017, 08:54 PM
What gauge make/style is it? Stewart warner or other brand ? Pic ?
__________________
  #13
Old 01-31-2017, 02:55 PM
well there is 2 . the original tucker cluster and a new after market one .
  #14
Old 02-01-2017, 08:34 AM
You need to figure out the ohm rating in the gauge and get a new fuel sender for it. Most are adjustable but I learned they are also directional depending on what side of the tank yours is mounted.
Summit has them but also a marine option from moeller might work. I used a Stewart warner because that's what my gauges are .
__________________
  #15
Old 02-01-2017, 11:18 AM
DAVENET's Avatar
DAVENET DAVENET is offline
DAVENET is on a distinguished road
Quote:
Scott is referring to the adjusters on each end- both inside and outside of the pontoon being adjusted equally. That way the grouser travels around the ends parallel to the pontoon, not off a few degrees. Not equal distant from pontoon end to end.
  #16
Old 02-01-2017, 11:28 AM
I get that but the earlier ones only had one adjuster so one side will always be different length ?
I always set my adjusters equal as advised .
__________________
  #17
Old 02-01-2017, 01:12 PM
heres what came out of the fuel tanks in the freighter . good thing there aluminum and don't rust or they would have been done for .
  #18
Old 02-01-2017, 02:29 PM
I have never seen or heard of a pontoon with only one adjuster on the entire pontoon. Must be some ones "improvement", not factory. Would like to see a photo.
  #19
Old 02-01-2017, 05:01 PM
You had me thinking it was the legal weed at first but here is what I came up with quickly.
This cab over with the blade I believe has one and this tucker factory restore has only one It is technically factory....
We can hug it out in McCall!
__________________
  #20
Old 02-01-2017, 05:03 PM
cab over one rear front and one front rear?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
IMP track tension hansoni THIOKOL/LMC/DMC Technical Issues Forum 6 03-05-2016 08:19 PM
BOMBI TRACK TENSION threedimnz Snowcat Repairs, Parts & Problems Forum 14 04-29-2011 11:01 PM
Track Tension Bwana_don Snowcat Repairs, Parts & Problems Forum 1 12-22-2010 12:49 PM
1967 J5 Track Tension alongstreet Snowcat Repairs, Parts & Problems Forum 3 11-29-2009 01:26 PM
Thiokol Track Tension 59muskeg Snowcat Repairs, Parts & Problems Forum 1 11-08-2009 11:59 PM
Copyright 2002 - 2017 www.ForumsForums.com
