WTS 1996 PISTENBULLY 160 **SOLD**
horsetrader
I have a PISTENBULLY 160 for sale runs and operates well,turbo diesel, Overall good condition...asking 16500.00..some trades considered..
horsetrader
Re: WTS 1996 PISTENBULLY 160
I do have a tiller for it..It was replaced a year ago..so almost new..I will be without power today until around 4;00 i
horsetrader
I do have the history on the 160, serviced always by pisten bully.. so records shouldn't be a problem, they should have records of parts replaced too..for all this info call me and I'll see what I can do to round it up for you..208 464 1138
Blackfoot Tucker
How many hours on machine . What is the width of machine .
Sled head,
Those are good questions. I know virtually nothing about Pisten Bullys (other than they are hugely expensive new) so I Googled "Pisten Bully 160D specs" and found precious little information. I did see the width with the OP's track setup was 2.8 Meters, which equals a little over 9'; an oversize load. I was not able to find the weight of the machine.
Something else I discovered is the engine is a VM HR 694 HT turbo Diesel. That meant nothing to me, so I Googled that too. It's an Italian Diesel engine made by Vancini Motori (VM). Not a lot of information about that, either. I'm guessing if you need parts it will be a challenge to get them, and price will be a secondary concern.
I have no clue about the drive system.
horsetrader
My tape measure tells me 8 feet 2 inches wide..at the tracks..blade angles from 9 feet to 8 feet..so NOT an over width issue at all..weighs 3600 KG with the blade ...Hit the scales at 8400 POUNDS..It is a Ferrara Diesel engine (Italian copy of a 6BT cummins pretty much) pisten bully can get all parts easy enough
schmidt
You started mention that you do have a tiller for it, is it a Pisten Bully Tiller? Thanks
