checked ford and napa for a seal today with no luck. Has anyone solved this leak? I had good part numbers but was told it wasn't being made anymore. Jim
go to a good transmission shop,one that has been around for many years, they should be able to find something that will work, I have had no problems buying most seals and bearings for the bombi,
I exausted most of my options on seal finding. I need to get this fixed .
Can this be filled with aluminum with out the heat doing damage to the tranny? I can gind the speedo shaft shorter and fill the outer part with my welder. The seal may melt some but running cold water should keep some heat down ????
Jim
Have you taken the seal out and shown it to a bearing/seal parts supplier?(not NAPA, gag) I have never not been able to find a seal at the local bearing store and I've worked on some pretty oddball stuff, even in metric. It looks like a standard chevron seal from the pictures to me. Here in Alaska I use Alaska Bearing or BESCO. The aluminum route sounds like a bad idea to me.
No I never took it out. I have gone that way in the past on farm machinery but didn't want a larger hole that couldn't get a seal for. When i get it mobile I'll show it to a couple tranny shops. My aluminum flatbed is 90% done. Jim
