kickdown cable on transmission LMC
hansoni
I'm trying to get a handle on the way our 1500 shifts, it's got a torqueflight trans. doing some research I'm finding out the kickdown linkage and adjustment is crucial to getting it to shift right. As it is now it shifts very quickly into 3rd and does not shift down to second applying pressure at the gas pedal even when climbing a hill.
I have made small adjustments the length of the rod that is hooked up to the carb via what looks like a custom made linkage with several holes with no change...
Here's an article out of a hot rod forum that says this about the lever coming out of the trans
Somewhere in this range of the lever’s arc, you can feel a slight resistance from the lever’s internal spring. This is where the line pressure begins to rise, ultimately causing a downshift. Properly dialing in the lever’s range of motion is critical to shift performance and transmission longevity. Says Jason: “For the first half of its travel range, there is very little resistance and the lever does nothing. At the halfway point, you can feel where it starts to hit the valve inside the trans, and that’s the position the lever must be in at idle.”
So it also goes on to say that at WOT this linkage should push the lever all the way. Figuring this is why all the holes in the carb linkage adjusting the amount of throw.
I would be curious to see any pics from other machines both of the lever position at idle and of the carb linkage setting to compare. Our machine has the AMC 258 with the torqueflight, weber carb
Does anyone have any expertise with these? Any Mopar hot rodders?
Thanks in advance.
redsqwrl
speaking as a torque flite 727 connoisseur in IH scouts.... All I can offer is good luck.
I found the setting (mechanical position of the actuator) at the carb will effect the force on the rod. Ahead of center it is late, after center it is later but way to quick.
somewhere in the peak of the arc at the carb linkage is the key to setting it.
IH scout linkages had a slot that the throttle linkage worked in. the weight of the spring also factored in.
It has been years since I did an automatic to a proper shift point, I went to stick shifts and now play with snow cats instead of scouts.
at one point while truck pulling, I had a pedal bike brake handle and cable to the trans to initiate the shift when the #$%^ I wanted it.!
I feel your pain and wish I had the knowledge to type out the answer. but the torque flite trans kick down is on the list of poorly engineered Detroit wonders of america
PEDWA for short.
Snowcat Pat
May be useful.
-Pat
Snowcat Pat
Pics,
Snowcat Pat
A few more,
-Pat
hansoni
Thank you Pat as always for your efforts.
After several hours of research I headed to camp to get to the bottom of this.
These first few pics are how the linkage was set up. At the carb the rod was adjusted all the way at the bottom for the max throw, the collar stop not touching the trans rod, and the trans lever all the way forward.
My research led me to believe that indeed the warm idle position for the trans lever position should be set just as some resistance is felt as it hits the valve inside. In the original setting the trans lever was all the way forward say at 10 o'clock or so noon being the front of the machine. I found resistance at about 9 o'clock or so. Then after moving the connection at the the carb linkage from the furthest away to the closest to the carb for less throw, testing to be sure at WOT the trans lever was pushed all the way rearward with no binding. Making sure the collar was adjusted in the right position as according to all the info I could find the trans lever should move as soon as throttle is applied.
This final setting is in the three last pics.
After a short trip on a flat surface the trans shifted well, running through the gears as it should, shifting smoothly and at approx the right RPM.
Then the real test was up a fairly steep incline, approaching in top gear, starting to go up, slight pressure on pedal and shifted down to second smoothly, holding second through the climb.
So as far as I can tell so far a great success. Time will tell if we should need to make any small adjustments but I feel it's pretty close.
I hope this helps any other 1500 owners out there.
Cheers
