Check out the map at the link below:
http://www.sacbee.com/1098/v-print/story/1936416.html
Interactive: When will the nation's job markets return to normal?
preese@sacbee.com
Published Wednesday, Jun. 10, 2009
While signs indicate that the worst of the recession may be over, only six metropolitan areas across the country are expected to regain their pre-recession employment levels by the end of 2009, according to projections from IHS Global Insight, a leading economic forecaster. Most of the country - 286 of 325 metro areas covered in the IHS analysis - aren't likely to regain their pre-recession employment levels until at least 2012. This map shows what year economic forecasters say each metro area will return to employment levels seen before the recession.
--Also: Find your area's current unemployment rate
