Thiokol 2100B -2100C
loggah
I recently bought a older 2100B and was wondering ,i had a 2100C brochure and it said it had a tilt cab. It appears the 2100B cab doesn't tilt. Is that the only difference between the 2 machines. The one i bought has a 300 c.i. gas engine and 4 speed standard.The good part is it came with a lot of extra parts. thanks. Don
loggah
Thats the same brochure i have for a 2100C, o well maybe someone can tell me the difference, thanks for the heads up. Don
Snowy Rivers
I just picked up a 2100B and it has the tilt cab.. HINGE SHOWN in the piccy at the base of the cab right where the cab meets the tub....
Possibly an option ????
Mine had a 391V8 and the C6 tranny.
Hydraulic (Grease)track adjusters
Snowy Rivers
Hmmmmm
Looking at the interior cab shot...the dash stamping that says
THIOKOL
2100?
The control lever that's partially covering the script on the dash makes it tough to see..
THIS BEAST MAY BE A 2100C
Fella told me it was a B
Does not matter to me...
Hope this can help in some way
Snowy Rivers
Spent a few minutes searching online and looking at pictures of the various 2100 packers
I did not find any with the hinge showing on the cab
Possibly the C saw the addition of the tilt cab ?????
Info is skimpy on these beasts
loggah
The pictures above look like like a lot more modern machine. My machine has no hinge. The serial number on mine is #385 according to what is written in the manual. I haven't got the machine home yet,sometime this week . thanks. Don
Snowy Rivers
When I get mine home and off the trailer I will see if I can find the ID plate.
The blade is laying across the axles down the left side and I did not crawl into the cab...and I am not going to use the cab anyway, I had not given it a thought....
Also I did not get anything more than a bill of sale on the machine, so there was no documentation ...."Cat Scraps" was all we got
loggah
The good thing about the one i bought is the whole chassis and blade have been narrowed up to groom snowmobile trails. The tracks are 8'8" wide the blade 9" makes it a bit easier to move.I intend to use it to haul my gathering tank when im making maple syrup. Don
Snowy Rivers
Sounds like fun..
Mine is getting narrowed up to 66" tire C/L to tire C/L
102" MAX width.
A lot of cutting...
loggah
I think thats what mine is also,uses the spryte axle tubes. You just end up with a 2 belt track. most of my sap gathering is on flat ground with a 300 gallon tank. Sometimes we have snow,sometimes we have mud !!!:smile:
vintagebike
The new Thiokol 2100 club?
Looks like 2100s are popping up like Snow Flowers. Ours in McCall, the x- Brundage cat "Streak".9D4F3FE6-FE20-4AB2-9D4B-4D61BEE86EDC.jpeg
sno-drifter
So it looks like red Thiokol is the way to go. I sold both of my Tuckers and got on the band wagon. Starting out slow this time.
loggah
Not you to Scott !!!!! i can't believe you sold any tuckers!:smileywac neither of my old tuckers would haul a sap tank. I did start them up last week. We are finally getting some snow so maybe i will get the tuckers rolling again. The thiokols are definately a better marginal snow,dirt then the old steel pontoon tuckers.:smile: Don
wakeupcall
Scott, I see the Thiokols as being Orange! Could be all the orange kool- aid i have been drinking ! Headed your way to pick up the 2 tuckers, i will take very good care of them. See you soon !:clap:
I have an early b model the cab doesn't tilt, it would take a lot of work to make it that way if I ever removed the cab I might re configure to tilt the wiring harness and hydraulic lines would have to be relocated to make this work.
Snowy Rivers
Was the Tilt cab an option??? or was it a modification added to later units ???
I have sorted through a lot of pictures of 2100's and have not seen a tilt cab.
As I posted earlier, I have not put eyes on the ID tags on my Packer.... but other folks have mentioned that it looks like a later model.
loggah
Don, Then i assume the differance between the B and C models is the tilt cab and relocation of the controls to allow it. I know when i used to work on the 3700's they all had a tilt cab, ,wiring ,and hydraulics all were on the right hand side to allow the cab to tilt. Thanks. Don
olympicorange
…… hello Don,.. sounds like a fun unit,... hopefully you'll have it at the show next week,... hope the snow & sun gods shine down on exit 29 for the weekend,... :thumbup:
loggah
Bruce, We may be going to pick it up tomorrow, probably drop it off at dirt designs. depends on weather. Don
Snowy Rivers
There is a lot of potential in the 2100's
If you do not mind some serious mods to get them narrowed up so you can haul them...
Anything 102" wide or under and you're set..
loggah
Mine being 9' wide on the blade all we have to do is put a wide load sign on the machine , and towing vehicle dont need any special permits.
JimVT
in Washington state if chains are required all oversize loads permits are cancellled
Snowy Rivers
That right there makes towing a Cat troublesome.
At 8'-6" (102") you don't need to worry about such stuff.
Except common sense ....
loggah
Well it is a lot easier then the 155 komatsu or d9 or 275 michigan loader i used to have moved !!!!:smile:14'4" with 2 pilot cars. i guess it depends which state you live in. We can just move down the road with wide load banners up to 10'6" without any other permits.If it is snowing we cant move anything oversize,or holidays.
Snowy Rivers
Oregon is similar.
I was in heavy trucking from 1991 to 2012.
Ran a heavy haul transfer (Slam bang)
I never had to deal with width stuff..... just ran an annual permit for running 105,500 on 8 axles
But what you mentioned sounds about right
loggah
Going to get mine tomorrow,will try and post pictures after i get it up north! i will have to bribe my wife to do that!!:smileywac or maybe trailbuilder will take a few of the move. Seems like i got to get a bunch of stuff moved before next weekend,tuckers,lombard, and tucker trailer.:smile::smile:
Newbie here, just made a deal for a 2100b myself, thought I’d post pics to help with the tilt cab question. Not sure what year mine is, but definitely a tilt cab. Hinges on passenger side and handles on the driver side with a scissor latch behind the cab... looks like one bolt on the driver side user the hood holds it down - I’d imagine one to be at the back but haven’t looked yet. Hoping to get it running this week.
loggah
I see that one does have a hinged cab. Is it a late machine ? mines a 71. Maybe the hinge was a option with a automatic transmission. I know it would be a PITA with a standard and clutch pedal to hinge it. Is that machine a diesel? thought it might be with that muffler setup. Don't look to be in bad shape,good luck.
