I am attempting this baby some time soon....
Ingredients
Soft butter for greasing
6 large eggs, separated
150g caster sugar
50g cocoa powder
Icing and filling
200g plain, dark chocolate, broken into squares
200g icing sugar
200g butter, room temperature
2 tbsp Camp chicory and coffee essence
Decoration
Fresh holly leaves or leaves made from ready-to-roll coloured icing
Icing sugar or desiccated coconut
Method
Preheat the oven to 180°C/Gas 4. Line a 23 x 33cm Swiss roll tin with baking parchment, grease with a little butter and set aside.
Put the egg yolks and sugar in a large bowl and whisk with an electric beater until thick and creamy. Sift the cocoa powder over the egg mixture and whisk in thoroughly. Wash and dry the beaters and whisk the egg whites until stiff but not dry. Fold a third of the egg whites into the cocoa mixture, then gently fold in the rest until evenly distributed. Pour the mixture into the tin and spread gently with a spatula. Bake for 20–25 minutes or until well risen and beginning to shrink away from the sides of the tin.
Remove the cake from the oven, loosen the edges with a round-bladed knife and leave to stand for a few minutes. Place a piece of baking parchment on the work surface, turn the cake onto the parchment and leave it to cool completely – 30–40 minutes.
Meanwhile, make the icing. Melt the chocolate in a heatproof bowl over a pan of simmering water, or in the microwave. Remove from the heat and leave to cool, but do not allow it to set. Put the icing sugar in a food processor, add the butter and blitz until smooth. Add the coffee essence and 2 tablespoons of melted chocolate, then blend until smooth. Make sure the chocolate is cool, or it will melt the butter.
Take just over half the icing mixture out of the processor and put it in a bowl to use for the filling. With the motor running, slowly add the remaining chocolate to the icing mixture in the processor and blend until smooth. This will be used for icing the cake.
When the cake is cool, trim off the crusty edges. Using a palette knife or spatula, spread the filling over the cake, taking it right to the edges. Starting at one of the long sides, gently roll up the sponge, keeping the first roll fairly tight so it forms a good spiral shape. Spread the icing evenly over the cake and drag a fork through it to resemble the ridges on the bark of a tree.
Chill for at least 30 minutes to allow the icing to set. Decorate with sifted icing sugar.
