Reply
Thread Tools Display Modes
  #1
Old 03-22-2018, 02:47 PM
JimVT's Avatar
JimVT JimVT is online now
Default snow trac drive axles
excessive grease in the snow trac axles lubes your brake drum good.
i was cleaning them yesterday.
i'm putting the blame on my electric grease gun.
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
The Following 3 Users Say Thank You to JimVT For This Useful Post:
jim slagle  (03-22-2018), nikos (04-19-2018), Sno-Surfer (03-22-2018)
  #2
Old 03-22-2018, 03:08 PM
PJL's Avatar
PJL PJL is offline
Default Re: snow trac drive axles
But at least the drums won't rust.
The Following 2 Users Say Thank You to PJL For This Useful Post:
Cidertom (03-22-2018), Sno-Surfer (03-22-2018)
  #3
Old 03-22-2018, 10:12 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
electric grease guns are evil.
personally I would have a word with the trigger.
The Following 2 Users Say Thank You to redsqwrl For This Useful Post:
DAVENET (03-23-2018), jim slagle  (03-22-2018)
  #4
Old 04-17-2018, 07:53 AM
SweGus's Avatar
SweGus SweGus is offline
SweGus is on a distinguished road
How much work is needed to get to the brake drums? I am afraid that my brake drums may be greased as well so when I get the time I probably will have to clean them too. I know that Lyndon wrote somewhere that working on the brakes was a real hassle so I'm a bit afraid to start with it to be honest...
Do you have any more pictures and could you describe the process a bit more in detail?
Any special tools needed?
  #5
Old 04-17-2018, 08:03 AM
300 H and H's Avatar
Split the tracks, remove the large nut that holds the drums on and remove.
The hassle is if you need a new master cylinder to power the brakes. Hard to get to, to change out. Also the slave cylinders in mine turned out to be VW bus parts..
Even at their best, brakes on an ST4 two band track is lacking on a steep hill. Just remember if you absolutely have to stop, turn off the key and kill the engine in gear. You will definitely stop!
__________________
Snow trac ST4 #267
The Following 2 Users Say Thank You to 300 H and H For This Useful Post:
Pontoon Princess (04-17-2018), SweGus (04-17-2018)
  #6
Old 04-17-2018, 08:46 AM
SweGus's Avatar
Thanks a lot for the info!
I am cautiously positive that my brake cylinder is ok since the feeling in the brake pedal is ok. It's just that it doesn't make much difference if I'm pressing as hard as I can on the pedal. So I'm really hoping that it's "only" a grease problem.
  #7
Old 04-17-2018, 09:03 AM
JimVT's Avatar
Your emergency brake should also slip.
I would try to brake the tracks near the drums. But The best place is just below the drum.
Your sprockets could be reversed at the same time.
i did mine while it was on my trailer. Everything is elevated and much easier to work on.
No pictures were taken but brake cleaner ,rags .be Shure the drum is put on tight . Adjusting the brakes can also be done.
Jim
__________________
Jim KF7RiN
#185 snow trac
  #8
Old 04-18-2018, 07:09 PM
redsqwrl's Avatar
I have discovered a firm pedal, and a frozen (rusted) right side brake cylinder. my pressure was very good the braking was not so good.
New wheel cylinder and my brakes were back.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1958 ST4 Snow Trac Friction Drive vintagebike Snowcat Restoration & Modification Projects Forum 8 01-25-2019 03:16 AM
Snow Trac replacement BRONZE drive sprockets Melensdad Snowcat Repairs, Parts & Problems Forum 195 01-16-2018 11:15 AM
Custom Snow-Trac Rear Drive Sprockets Alaska Jay Snowcat Restoration & Modification Projects Forum 8 01-14-2017 06:14 PM
Source For New Snow Trac/Master Drive Sprockets teledawg Snowcat Repairs, Parts & Problems Forum 13 12-21-2010 09:12 PM
snow trac drive chain tension John Lumley Snowcat Repairs, Parts & Problems Forum 3 01-17-2010 09:28 PM
