Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tools & Tractor Implements Forum
Reply
Thread Tools Display Modes
  #41
Old 01-23-2016, 01:31 AM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is online now
Gold Member
EastTexFrank will become famous soon enough
Default Re: Fill-Rite Fuel Transfer Pump help ........
Quote:
Originally Posted by Snowtrac Nome View Post
good info replaced the o-ring with a softer thinner silicone type sucks like monica Lewinsky now
God, I wish that I'd said that!!!!
For TuthillCorp, I've had one of your 110v pumps for the 12 years and it's still going strong. The 12v pump is only a few months old but I expect that it'll see me out. Thanks for a great product ... and customer service.
__________________
ETF
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them. John Wayne as JB Books in "The Shootist".
The Following User Says Thank You to EastTexFrank For This Useful Post:
TuthillCorp (01-23-2016)
  #42
Old 01-23-2016, 01:41 PM
TuthillCorp TuthillCorp is offline
Junior Member
TuthillCorp is on a distinguished road
Thanks for the kind words gents!
Feel free to contact me anytime.
Best Regards,
TuthillCorp
The Following 2 Users Say Thank You to TuthillCorp For This Useful Post:
jim slagle  (01-23-2016), jwstewar (01-25-2016)
  #43
Old 01-31-2016, 07:01 PM
juniormarbles juniormarbles is offline
Junior Member
juniormarbles is on a distinguished road
Default Where to find a Rotor Key for a C1200?
This message is directed to Mr. TuthillCorp, but also others who may be able to help:
I am desperately in need of the rotor key that affixes the rotor to the motor shaft of my Fill-Rite 1200C transfer pump (build date: 18/08).
I have not been able to source just the key, and as all other parts in the pump work perfectly fine and there is no corrosion or debris build-up (less than 1/2 hour total service on the unit), I do not need an expensive rebuild kit. Just a replacement for the fiberboard key I lost!
Can you help? I live in the Portland, OR region.
Thanks, JM
  #44
Old 01-31-2016, 07:11 PM
Junior Member
Default Re: Where to find a Rotor Key for a C1200?
JM,
Thanks for the private message on this issue.
I will be able to help you out!
Best Regards,
TuthillCorp
Thanks, JM
The Following User Says Thank You to TuthillCorp For This Useful Post:
jim slagle  (01-31-2016)
  #45
Old 01-31-2016, 07:49 PM
Junior Member
I am elated! Thank you so much for your help.
It's been a long time since I have received such dedication from any representative of a company! I've followed Mr. Tuthill's previous responses to other Fill-Rite owners' queries, and can only hope that Tuthill's management recognizes what a difference his service makes for the company's image and reputation.
This kind of customer service influences my future buying decisions.
JM
The Following 3 Users Say Thank You to juniormarbles For This Useful Post:
Big Dog  (01-04-2017), jim slagle  (01-31-2016), TuthillCorp (02-05-2016)
  #46
Old 02-05-2016, 04:21 PM
Junior Member
Pump works again, thanks to Mr. Tuthill's superb customer service.
I can heartily recommend the Tuthill company's products, just for the fact alone that its customer service is absolutely tops!
JM
The Following 4 Users Say Thank You to juniormarbles For This Useful Post:
Big Dog  (01-04-2017), jim slagle  (02-05-2016), OhioTC18  (02-05-2016), TuthillCorp (02-05-2016)
  #47
Old 12-31-2016, 09:50 AM
crhabeck crhabeck is offline
Junior Member
crhabeck is on a distinguished road
My 12v pump's rotor spins freely so the fiber key needs to be replaced. How does it come off? The rotor spins freely but does not slide off. Do I need to remove the center screw? If so, how since the motor turns with the screw? CanI get only the fiber key? The pump is a couple of years old but has only been used a total of 45 minutes.
  #48
Old 12-31-2016, 10:44 AM
Junior Member
Thanks for your post on your 12 VDC pump.
I a man a bit confused to your reference of a "center screw". We do not have any screws inside the pump. There should only be the rotor, the vanes (they slide in the slots in the rotor), and the fiber rotor key.
If you can send me a picture of the center screw, that would also help.
You should be able to remove the vanes and slide the rotor off the motor shaft and clean out the broken rotor.
If you private message me with your address, I can get you a new fiber rotor key.
Thanks again for your post.
Best Regards,
TuthillCorp
Big Dog  (01-04-2017), jim slagle  (12-31-2016)
  #49
Old 01-13-2017, 09:24 PM
Junior Member
Hi,
Sorfy about the delay. Mixed up two different items. I do need a new key though.
How do you send a private message?
Thanks
  #50
Old 01-14-2017, 05:18 AM
Junior Member
No problem crhabeck,
I sent you a private message. You can access it by clicking on private messages at the top right of the page in the grey box that says Welcome crhabeck.
Best Regards,
TuthillCorp
  #51
Old 01-14-2017, 03:14 PM
Snowtrac Nome's Avatar
mr tuthill I have a pump had a bad o ring in it I installed a new one from an o ring kit that was the wrong size I cracked my pump housing is it cost effective to order a new pump assembly or is it just good for parts now
__________________
Don
1962 st-4
KL2ZF
  #52
Old 01-15-2017, 07:58 AM
Junior Member
Hello Snowtrac,
Ouch, the pump housing actually cracked? If possible, I would like to see a picture of what cracked.
To answer your question though, we do not provide the pump housing casting. On many of our models, the pump casting is actually part of the motor assembly. Trying to remove it creates an issue with the explosion proof rating of the pump as it compromises the flame paths that we need to build into the pump to get our explosion proof approvals.
So, bottom line, your pump is now good for parts.
Again, I would like to see a picture if you could.
Best Regards,
TuthillCorp
  #53
Old 01-15-2017, 01:52 PM
Quote:
Originally Posted by TuthillCorp View Post
Hello Snowtrac,
Best Regards,
TuthillCorp
going to teller this morning when I get back I will put it up I know of another pump with a bad motor but it is locked up and that crew hasn't been back to town for years I know you don't want to hear it if I can get my hands on that one some day I will replace the motor with mine .
__________________
Don
1962 st-4
KL2ZF
  #54
Old 01-16-2017, 09:07 AM
Junior Member
Hello Snowtrac,
I understand where you are coming from.
Just let me know if you have any further questions!
Best Regards,
TuthillCorp
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fuel Transfer Pump - Brands? 12v DC or 110v AC? bczoom Tools & Tractor Implements Forum 9 10-30-2012 04:29 PM
Which side of vehicle is the fuel fill? bczoom Cars, Trucks Forum 7 07-23-2012 12:40 PM
Fuel transfer begins at Nome muleman Open Forum 2 01-17-2012 03:58 PM
Transfer fuel pumps NCMau Tools & Tractor Implements Forum 1 01-30-2010 01:23 AM
Need a fuel pump for an IMP Bobmog Snowcat Repairs, Parts & Problems Forum 12 09-30-2006 09:04 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
