Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Home Improvement Projects, Appliance upgrades, Misc Household items Forum
Reply
Thread Tools Display Modes
  #1
Old 01-07-2015, 08:41 PM
waybomb's Avatar
waybomb waybomb is offline
Silver Member
waybomb will become famous soon enough
Default Jev remodels fireplace, me two, plus a kitchen
So we are selling our current place on the water and have purchased a much larger place on the water.
She wants a fireplace in the bedroom and one in the front room. See the pix - those corners is where they will go.
I am a wimp as well - they will be gas fireplaces with blowers, direct vent. The one in the pic is what will be in the living room, and installed with a similar surround. Both will be the Napoleon Brand. The bedroom will be a 42" with a stainless surround, and the plasma mounted on top.
And the kitchen needs to be turned Euro. Already bought the 48" Gas Jenn Air range and the 48" JennAir Fridge and JennAir dishwasher at the local outlet. They are watching for an ice maker and a 30" micro and an under counter wine cooler. Looks like she wants all drawer bottom cabs and some garage door style and some standard on top. Probably smooth glossy finish. And of course, the plate glass backsplash like the last one.
Same tyoe of set up as the last place with the stainless appliances, just much bigger. This one will most likely get the thick blue corral granite as well.
3875 sq ft
I'll update as we get into it. Still have to move in. It's only 5 doors down from our current place, but moving simply sucks.
__________________
Thanks Fred
NASA says I am not warming the globe, 24 cylinders at a time.
http://s4.photobucket.com/albums/y145/waybomb/
I'd rather be burning gas up at an alarming rate in Plain Vanilla.
  #2
Old 01-07-2015, 09:14 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Default Re: Jev remodels fireplace, me two, plus a kitchen
Good luck with the move. We told Melen that instead of moving we would just leave her everything and she'd be stuck with it. Seems like it is easier to just start over with everything new from new underwear to new TV sets.
__________________
- Ayn Rand
  #3
Old 01-14-2015, 07:15 AM
JEV's Avatar
JEV JEV is offline
Mr. Congeniality
JEV has a spectacular aura aboutJEV has a spectacular aura aboutJEV has a spectacular aura about
Last time we moved was 1992, and my back is still sore. Nice place, too bad the move is so close. Costs as much to have the big stuff moved 10 miles as it does down the street. In my younger days a case of beer and grill full of burgers & brats would get you moved with all your buddies & their trucks. Today we're much smarter, and also have a few more bucks to pay someone else to do it.
__________________
Time to go fishin'
"I'm no gynecologist, but I'd be happy to take a look..."
  #4
Old 01-14-2015, 07:50 AM
waybomb's Avatar
Silver Member
We've been bringing over the little stuff. We will pay the guys to move the furniture though. I ain't breaking my back!
__________________
Thanks Fred
  #5
Old 02-25-2015, 08:54 PM
waybomb's Avatar
Silver Member
Kitchen cabinets are ordered, all appliances bought.
The peninsula is moving up or toward the carpet. You'll see six feet of tile between it and the carpet. That will be down to about 2 feet of tile, and we will be making the edge seen curved, so the tile will move into the carpet area following the curve and allowing for stools. Then after the kitchen is done, a real-wood engineered floor of birds-eye maple is going down. I'll be busy for a few months to say the least. I'll do everything but the wood floor - they only want 3 bucks a foot to install it. Then have to finish sand and varnish, but that would have to be done anyway.
The garage is under the kitchen, and the floor is a bit chilly. And since the old tile will be replaced, and I am going to have to lift the subfloor up to run plumbing and electric to the island, and will need another 220v circuit for the convect micro on the outer wall, I may as well foam the inside of garage ceiling.
While I am in there, I think I have a clear path to the third floor bathroom. I'd like to install the Kohler DTVII system shower, but I need 3/4 hot and cold lines to the valve. If I have a clear path, I'll be roughing those in as well. If i can't get the lines up, then no DTV.
And I want to put heat under the tile in the kitchen.
Anybody done this under-tile heat- what brand did you use and how did it work out?
__________________
Thanks Fred
  #6
Old 02-25-2015, 10:05 PM
300 H and H's Avatar
300 H and H 300 H and H is online now
300 H and H will become famous soon enough
Fred,
If you shoot closed cell foam on the garage ceiling, will you really need the heated floor? That foam is awfully good, and has a high R rating. I bet this alone will change the floor temps alot.
__________________
Snow trac ST4 #267
  #7
Old 02-25-2015, 11:12 PM
JEV's Avatar
JEV JEV is offline
Mr. Congeniality
Quote:
Originally Posted by 300 H and H View Post
Fred,
I agree. The closed cell sprayed foam creates a thermal break to keep the cold on the cold side, and the warm on the warm side. But even with foam installed, if you like to walk around in stocking feet or keep the space cool for other reasons, the radiant heat would still be needed if you like a warm floor.
If you install radiant wires, be certain they are tested as the floor goes down to make certain nothing is damaged. Once the tile is down, it's a PIA, and very expensive, to tear it up to fix any problems. Good luck with it.
__________________
Time to go fishin'
The Following User Says Thank You to JEV For This Useful Post:
waybomb (02-26-2015)
  #8
Old 02-26-2015, 12:54 PM
waybomb's Avatar
Silver Member
We have a small kitchen now, and there are 2 forced air vents that keep the tile toasty. The new kitchen is at least twice as big.
My wife and I never wear shoes in the house, and she likes barefoot. So will
need some heat.
And something to remember - test that wire as the tile goes down - Thanks for the tip!
__________________
Thanks Fred
  #9
Old 02-26-2015, 01:40 PM
Kane's Avatar
Kane Kane is offline
Silver Member
Kane will become famous soon enoughKane will become famous soon enough
Pretty exciting, Waybomb. Just curious; what body of water are you on?
__________________
All things being equal, bigger bullets tend to work better.
  #10
Old 02-26-2015, 06:04 PM
waybomb's Avatar
Silver Member
On the Saint Joseph River, about a mile from Lake Michigan, on Marina Island, In between Anchor's Way Marina and Brian's Marina.
Two 40 foot slips right in front of my place. And then another at the St Joe Isle Yacht Club.
__________________
Thanks Fred
  #11
Old 03-02-2015, 12:32 PM
waybomb's Avatar
Silver Member
Here's a pic of the cabinet plan. I tried scanning but must have screwed up the printer in the move.
__________________
Thanks Fred
The Following User Says Thank You to waybomb For This Useful Post:
Galvatron (03-07-2016)
  #12
Old 03-09-2015, 12:22 PM
waybomb's Avatar
Silver Member
Appliances delivered Friday evening. And the washer and drier too.
The stove and fridge are in the garage until tile work is done and cabinets started.
__________________
Thanks Fred
The Following 2 Users Say Thank You to waybomb For This Useful Post:
Galvatron (03-07-2016), JEV (03-12-2015)
  #13
Old 03-18-2015, 12:50 PM
waybomb's Avatar
Silver Member
Cabinets scheduled to be delivered on the 16th of April.
I gotta get to work on this thing!
I bought another condo in Trenton Michigan with a 40 foot slip, so I can be close to work. That one will be sold in 10 years or so, so it's just going to get new carpet and paint for now. But I am running out of time. Haven't done a damn thing with the boats either this winter. Anybody wanna "work for food"? I have plenty of food and plenty of work!
__________________
Thanks Fred
  #14
Old 04-12-2015, 07:22 AM
waybomb's Avatar
Silver Member
And it begins. Wall cabinets down and the dry bar down. And started installing in the garage.
Today is finish the wall cabinet reinstall in the garage and put some base cabinets in along the short wall.
__________________
Thanks Fred
  #15
Old 04-12-2015, 07:24 AM
waybomb's Avatar
Silver Member
The back door in the garage between the dry bar and the wall cabinets leads to the deck at the dock. So now I'll have storage for liquor and wine and other necessary stuff right there. The old fridge is going down there as well.
__________________
Thanks Fred
  #16
Old 04-12-2015, 09:22 AM
Melensdad's Avatar
I like the idea of re-using the old kitchen cabinets in the garage. You don't want to see how I have my garage organized.
__________________
- Ayn Rand
  #17
Old 04-12-2015, 08:13 PM
waybomb's Avatar
Silver Member
Today's efforts. Demo everything elder but the kitchen sink. Install what I can in the garage. I'll even have a desk in the garage! Next week week be making the rest of the counter of of the island piece.
Won't have much time. The boat is going in on Saturday and the new cabinets arrive on Thursday.
__________________
Thanks Fred
Galvatron (03-07-2016), Melensdad  (04-12-2015)
  #18
Old 04-16-2015, 03:43 PM
waybomb's Avatar
Silver Member
50 boxes of red cabinets came today.
__________________
Thanks Fred
  #19
Old 03-07-2016, 12:26 PM
waybomb's Avatar
Silver Member
It was long summer, with boating and nice weather getting in the way.
Moved the plumbing, added plumbing for the island in the middle, ran a separate 100amp service up to the pantry, added another subfloor, cabinates going in.
The new sink base is great. Everything but the front is Rubbermaid plastic. Great idea. If you've had a sink leak, faucet leak, garbage disposer leak, or dishwasher connection leak, you will appreciate this new idea.
Next is installing the heated floor and slate. Then the counter tops.
The cabinet with the openings gets a built in cappuccino machine, a micro/convection, and a warming drawer. The bar opening gets a wine cooler. All the appliance are Jenn-Air except for the cappuccino machine
Also, the duct work for the hood gets hidden behind stainless trim.
__________________
Thanks Fred
Galvatron (03-07-2016), jim slagle  (03-07-2016)
  #20
Old 03-08-2016, 05:48 AM
squerly's Avatar
squerly squerly is offline
Supported Ben Carson
squerly will become famous soon enoughsquerly will become famous soon enough
Holy crap Waybomb, that's a nice setup ! Someone picked the right 6 numbers or something?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fireplace update for "She-who-must-be-obeyed" JEV Home Improvement Projects, Appliance upgrades, Misc Household items Forum 24 01-15-2015 03:25 AM
Vent-less fireplace? DaveNay Home Improvement Projects, Appliance upgrades, Misc Household items Forum 25 02-03-2010 05:27 PM
Fireplace Grates BoneheadNW Misc Consumers Forum 7 01-11-2009 12:46 PM
Installing a fireplace insert JimR Home Improvement Projects, Appliance upgrades, Misc Household items Forum 5 11-25-2007 11:42 PM
