Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > DIY Forums > DIY Electrical Forum
Reply
Thread Tools Display Modes
  #1
Old 07-13-2012, 07:17 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Default Metal vs Plastic Electrical boxes.
When should you use metal and when is it okay to use plastic electrical boxes?
I think I should use a metal junction box for wiring up 4 switches, but wanted to double check before I do the install. I plan to run one hot wire to the junction box and come out with 4 wires for four switches. Would that be okay and 'up to code' in most places?
__________________
Scott me up Beamy.
Other Fun Forums:
Weekend Mudders + Net Tractor and RTV Talk + Net Cooking Talk
  #2
Old 07-13-2012, 07:27 PM
OhioTC18's Avatar
OhioTC18 OhioTC18 is offline
OhioTC18 is on a distinguished road
Default Re: Metal vs Plastic Electrical boxes.
Plastic is always easier to work with. A 4-gang plastic switch box is about the biggest "commonly available" size you'll find.
A typical 4-gang switch box with 5 cables should be okay. Almost all plastic boxes have the number of conductors allowed printed inside the box.
edit to add......... Metal boxes must be used with a metallic wiring method, but if you're using a plastic jacketed cable such as NM-B cable (commonly called Romex) a plastic box is what I would use.
__________________
Weekend Mudders
  #3
Old 07-13-2012, 07:31 PM
AAUTOFAB1's Avatar
AAUTOFAB1 AAUTOFAB1 is offline
AAUTOFAB1 will become famous soon enoughAAUTOFAB1 will become famous soon enough
Style: VB_Original_Style
ummm,what Gage wire is your home run and what amp breaker are you going to use? maybe a 3 wire home run with 12ga wire going to a 20 amp two poll breaker ?
i only use metal boxes for junctions, but local codes may be different .
__________________
A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government. George Washington
They can pass all the "laws" they want. I WILL NOT COMPLY.
  #4
Old 07-13-2012, 07:36 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
12 ga wire throughout the house. I'm using 12/2.
I plan to use two double swith boxes one stud apart from each other, but one junction box for all the power wires before they jump to the switch boxes (sorry I don't know the right terminology for this stuff). I am useing romex wire so I guess I can use plastic all the way around. Thanks guys!!!
__________________
Scott me up Beamy.
Other Fun Forums:
  #5
Old 07-13-2012, 08:08 PM
OhioTC18's Avatar
I would forget the junction box, but that's just me. Feed into one 2-gang and feed out to the other. Then two switch legs out of both of the 2-gang boxes.
__________________
Weekend Mudders
  #6
Old 07-13-2012, 08:28 PM
FrancSevin's Avatar
FrancSevin FrancSevin is offline
Silver Member
FrancSevin has a spectacular aura aboutFrancSevin has a spectacular aura about
Yeah, skip the junction box if you can. One cannot bury a juntion box in the wall. It has to be accessable. So, if you use one you have to have a surface mounted access cover.
Use deeper plastic boxes for the switches and plugs. Do your distribuion connections behind that appliance and then you aren't covering the wire junctions behind drywall.
I'm pretty sure that is code in most places. And it is just good practice.
Plastic boxesare morethan fine. Just be sure you secure the Romex well to the wallstud and within a few inches of the box. (six inches I think)
  #7
Old 07-13-2012, 08:30 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Quote:
Does anyone have diagrams of what you are talking about. Not sure if junction boxes was the right word vs gang box etc.
My power source is about 20 feet away and I wanted to run one wire to right above where I need the switches and then splice off from there to each switch. Good idea or not?
__________________
Scott me up Beamy.
Other Fun Forums:
  #8
Old 07-13-2012, 08:39 PM
FrancSevin's Avatar
Silver Member
Skip the juctin box and just bring the pwoer wire intothe firs switchbox. go ourfrom there to the light fixture and add jumpers over to the next switch & light wire. Run the black thru the switches and the white straight to the appliance (light fixture) White to white, black to black, ground to ground tying them all together.
It may seem simpler to distribute from a junction box but as I said earlier, that is problematic.
  #9
Old 07-13-2012, 08:50 PM
OhioTC18's Avatar
Franc pretty much said what I was was talking about. It's not all that easy to draw it out on here, maybe I can do one in MS Paint tomorrow morning
__________________
Weekend Mudders
  #10
Old 07-13-2012, 08:57 PM
TiredRetired's Avatar
TiredRetired TiredRetired is offline
The Old Salt
TiredRetired has a spectacular aura aboutTiredRetired has a spectacular aura about
You can use plastic for 4 gang if you can find one. Electrical Wholesaler should have them. Otherwise just use the gangables. Go with the deep ones.
One hot wire to feed the four switches should be OK.
Metal boxes are required if running MC cable. Maybe they have an approved plastic box for MC that would have metal straps to continue the ground continuity between the KO's but it would prolly be more money than what it is worth.
Plastic boxes and romex are made for each other.
Always, always use a metal box for a ceiling fan.
Don't get bit.
__________________
I'd Rather Be Russian Then A Democrat.
  #11
Old 07-13-2012, 08:59 PM
The Old Salt
Yup. What Ohio & Franc said. I just noticed these posts.
__________________
  #12
Old 07-13-2012, 09:01 PM
OhioTC18's Avatar
Quote:
There are several plastic boxes listed for use with a ceiling fan and are safe to use for that application.
__________________
Weekend Mudders
  #13
Old 07-13-2012, 09:05 PM
The Old Salt
Really? Well there you go. All my years in the trade I stayed away from wiring houses like the plague except my own. Now that I retire from the trade I just learned something. My next trip to the wholesalers for my remodeling project I will check it out. Thanx!
__________________
  #14
Old 07-13-2012, 09:08 PM
OhioTC18's Avatar
I've used 3 in my house and one in my son's house.
__________________
Weekend Mudders
  #15
Old 07-13-2012, 09:11 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Like this:
__________________
Scott me up Beamy.
Other Fun Forums:
  #16
Old 07-13-2012, 09:14 PM
The Old Salt
Yup, you got it.
__________________
  #17
Old 07-13-2012, 09:18 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
I found that diagram elsewhere but it fits.
I would have four switches but from what you all have said four is ok, just as three would be.
Thanks all.
__________________
Scott me up Beamy.
Other Fun Forums:
  #18
Old 07-13-2012, 09:23 PM
The Old Salt
Thanks all.
From what I can see of your intentions you will not have enough load to even come close to maxing out a 20A branch circuit. 4 switches will be fine on one circuit. A good guideline is not to max a circuit out more than 80% of it's rated capacity. In other words, 16A max on the 20A circuit. This allows a safety margin. It is not in the NEC, however, so it is not the law, just a good common sense practice to keep things kosher.
__________________
  #19
Old 07-13-2012, 09:25 PM
OhioTC18's Avatar
Yes that would work but still looks like you use a junction box. If you want to and it's accessible then by all means do that.
__________________
Weekend Mudders
  #20
muleman's Avatar
muleman muleman is offline
worn out farmer
muleman is just really nicemuleman is just really nicemuleman is just really nicemuleman is just really nice
If you don't already have the wire you can use 14-2 for all the switched circuits. Run 12 to the first supply. 14 is a hell of a lot easier to work with and will handle anything a single pole switch will unless it is a 20 amp commercial switch. You should Buchannon splice all your grounds so they are tight.
__________________
"The strongest reason for the people to retain the right to bear arms is, as a last resort, to protect themselves against tyranny in government"
Reply
Tags
metal electrical boxes
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OC-12 LEAK BETWEEN GEAR BOXES. dennytodd Snowcat Repairs, Parts & Problems Forum 11 10-21-2013 07:31 AM
Why men have big tool boxes Cowboy Junkman's Corner 1 11-17-2010 07:21 AM
Metal Halide, Pulse Start Metal Halide, High Pressure Sodium etc. Dargo Other Projects Forum 12 06-09-2008 01:16 PM
Satellite Reciever boxes on Ebay? Elsewhere? Melensdad Entertainment Forum (TV, Movies, Books, Music & Celebrity gossip) 7 07-30-2006 05:05 PM
Why Condoms Come In Boxes Of 3, 6, AND 12 Big Dog Jokes_Forum 5 10-27-2005 10:18 AM
