Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > DIY Forums > DIY Electrical Forum
Reply
Thread Tools Display Modes
  #1
Old 04-20-2012, 09:22 AM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Default Wiring a new bathroom
I'm adding a bathroom to our unfinished basement.
I have the framing done and the plumbing all done. Now for the electric. I think I have a good handle on it. Going to run 12/2 wire. I only need 3 switches for lights & fan and the rest outlets.
As I understand it I just need one GFCI outlet and the rest in the string will be protected by that one (I suppose it has to be the first one in the string though). Is this correct?
Any tips you care to offer up before I start pulling the wire. Believe me, I could use them.
__________________
Scott me up Beamy.
Other Fun Forums:
Net Pet Talk + Net Tractor and RTV Talk + Net Cooking Talk
  #2
Old 04-20-2012, 09:38 AM
jim slagle's Avatar
jim slagle jim slagle is offline
Cold Member
jim slagle is on a distinguished road
Default Re: Wiring a new bathroom
Doc, the gfci outlet has two sets of terminals, the first the input from the panel and you attach the other outlets to the second so they are protected.
Jim
__________________
The United States Constitution 1787. All Rights Reserved
Sometimes I'm fast. Most of the time I'm half fast!
Never put off till tomorrow what you can avoid all together!
Friends come and go, but enemies accumulate
FF REQUIRES NO PHYSICAL FITNESS PROGRAM.
EVERYONE GETS ENOUGH EXERCISE JUMPING TO CONCLUSIONS, FLYING
OFF THE HANDLE, RUNNING DOWN THE MODERATORS, KNIFING FRIENDS IN THE
BACK, DODGING RESPONSIBILITY AND PUSHING THEIR LUCK.
  #3
Old 04-20-2012, 10:12 AM
bczoom bczoom is offline
Style: T66
I don't believe the switches need to be on the GFCI. Just the outlets.
A tip that comes to mind. GFCI's are a lot bigger then a standard receptacle. I would consider putting it in a box by itself (as the first in series as already noted). Make sure you use a deep box.
Have you picked your lighting yet? I would consider a dimmer for the light(s) over the mirror. Personally, I can't stand the super bright lights. I'm not putting on make-up or popping zits so I don't want/need/like them that bright.
  #4
jpr62902's Avatar
jpr62902 jpr62902 is offline
Jeanclaude Spam Banhammer
jpr62902 will become famous soon enoughjpr62902 will become famous soon enough
Gerry's the one to ask to be sure, but I think it needs to be a dedicated 20 amp circuit. I also don't believe that the lighting has to be GFCI protected. Finally, there's a minimum distance requirement between the outlet and any water source. Not sure what that is though.
__________________
"I will not eat green eggs and ham. I will not eat them. Sam, I am."
-- Sam
  #5
Old 04-20-2012, 10:17 AM
Big Dog's Avatar
Big Dog Big Dog is offline
Large Member
Big Dog has a spectacular aura aboutBig Dog has a spectacular aura about
Quote:
Jim
First in the string from the panel then anything down stream is protected.
__________________
"No law ever prevented a crime" ...........
The MLR (Men's Locker Room) is now open! PM Big Dog for access ....
  #6
Old 04-20-2012, 10:19 AM
FrancSevin's Avatar
FrancSevin FrancSevin is offline
Silver Member
FrancSevin has a spectacular aura aboutFrancSevin has a spectacular aura about
It may not be in the code but, there is nothing wrong with putting the entire bathroom on a GFI.
Also, in a basement, below ground one should put all circuts on GFI as a matter of safety, not law.
GFI's are cheap. Worth the margin of safety.
Here's a note, don't put them in series. One to a circut or it will drive you nuts.
Codes vary from place to place. Tired retired would have the definitive answers on this.
  #7
Old 04-20-2012, 10:35 AM
Doc's Avatar
Doc Doc is offline
Forum Admin
All outlets will be on one circuit so one GFCI should do. As for the dimmer, I am planning for some indirect 'mood' type lighting near the ceiling. so I had not considered a dimmer. No special wiring for a dimmer is there? Still time to add a dimmer switch to the plan. Thanks guys.
__________________
Scott me up Beamy.
Other Fun Forums:
  #8
Old 04-20-2012, 10:36 AM
Style: T66
Doc,
BTW, they make GFCI circuit breakers. If you're doing a home run back to the box with all new, you can just put a GFCI breaker in the box and be done with it.
  #9
Old 04-20-2012, 10:37 AM
FrancSevin's Avatar
Silver Member
Quote:
Dimmers are easy and come with specific instructions. Note that they use more room in the box than a standard outlet or switch.
Three wires, still black, white and green for ground. Use a permanet closed eye on the ground wire! Crimp the two ground wires together or with sepearate eyes,,,,Screw it to the box.
Wire nuts on the other two wires.
  #10
Old 04-20-2012, 10:40 AM
Style: T66
No special wiring for a dimmer if you're using standard incandescent bulbs.
If you're going with halogen bulbs, there's a couple considerations.
What type bulbs are you using?
  #11
Old 04-20-2012, 10:41 AM
Style: T66
Quote:
Ummm, isn't that black (in), black (out) and green? The white is wire nutted without going to the switch.
  #12
Old 04-20-2012, 10:48 AM
FrancSevin's Avatar
Silver Member
Quote:
Depends on which way you are going. Power should not be at the fixture unless it is post GFI. Even then, I do not like to do it that way in a bathroom.
White should be spliced white to white, black in to the dimmer and out to black. Green to ground. If the dimmer doesn't have a green lead it has a green lug. Instuctions would be the same.
My bad if my instrctions were not clear. Related to the inclosed instructions I mentioned, it would have made sense.
  #13
Old 04-20-2012, 10:53 AM
jpr62902's Avatar
What considerations?
__________________
-- Sam
  #14
Old 04-20-2012, 11:02 AM
Style: T66
With halogen bulbs, there's a different dimmer so you don't get a hum.
Also, with halogens, you need to make it a point to run them to full power somewhat frequently to keep the bulb life where it should be. A a couple seconds for each minute it was dimmed is adequate. Do it at the end of when it was lit on the dimmer before turning it completely off.
  #15
Old 04-20-2012, 11:07 AM
Doc's Avatar
Doc Doc is offline
Forum Admin
We'll be using standard incandescent bulbs.
__________________
Scott me up Beamy.
Other Fun Forums:
  #16
Old 04-20-2012, 11:27 AM
FrancSevin's Avatar
Silver Member
Now that is a new one. I have Hals in a long halway/video library to the Laundry room downstairs. Mostly kept low. Yet the bulbs burn out often, and I could not fathom why since we have them on low power.
Thanks BZ!
  #17
Old 04-20-2012, 11:40 AM
jpr62902's Avatar
I have 6 20w under-cabinet halogen puck lights on a dimmer. They don't hum at all when dimmed, but that's probably because the wattage is so low?
__________________
-- Sam
  #18
Old 04-20-2012, 01:03 PM
TiredRetired's Avatar
TiredRetired TiredRetired is online now
The Big Kahuna
TiredRetired has a spectacular aura aboutTiredRetired has a spectacular aura about
Actually, all outlets in the basement need to be on GFI in unfinished areas. I usually do not put the lights in a bathroom on GFI because if the GFI trips I would not want to lose my lights. I do not see not having the lights on GFI as a shock hazard.
Outlet in bathroom needs to be GFI. Other outlets downstream can be connected on the load side of that GFI outlet if you so desire. However, if those downstream outlets are not required by code to be GFI it can create a nusance situation.
12/2 romex is your standard 20A rated wire for home. Outer jacket will be colored yellow to ID for inspectors.
Yes, do not put GFI is series.
My kitchen fixture uses a halogen lamp and I have no humming when dimmed using an electronic dimmer.
Do you know what makes them hum? They do not know the words. Sorry, standard industry joke.
Always switch the black wire. Never switch the grounded conductor (white)
Proper terminology. Black & Red = Hot Conductor or current carrying conductor White = Grounded conductor old term neutral Green = Grounding conductor
Yes, you can still get zapped off the white wire. Not to ground but if you get between two white wires say one in each hand and your body acts as the continuation of the circuit. Trust me, that one really hurts.
__________________
Truth is making a comeback.
  #19
Old 04-20-2012, 01:27 PM
FrancSevin's Avatar
Silver Member
Thanks TR. I have put two circits in the Bath, one light fixture a wall sconce is on a separate circut, GFI of course. part of the on-suite's bedroom circut.
This is especialy useful in lower lever (basement) circuts as you seldom have ambient lighting. But, I do it in all bedrooms, al levels.. Not sure it is code but, I have never been called by any inspector on it.
Is it wrong to do that?
  #20
Old 04-20-2012, 06:18 PM
OhioTC18's Avatar
OhioTC18 OhioTC18 is offline
OhioTC18 is on a distinguished road
Doc,
Here's what the code says, if you decide to follow it. You might be in an area that does not adopt that.
The circuit feeding the bathroom receptacle(s) must be 20A
The circuit can be used to feed receptacles in another bathroom in the house
The circuit can be used to feed other equipment in that bathroom but can then go no where else
My personal choice is having the receptacle(s) on a different circuit than the lighting. If it trips while I'm in a steamy shower, I still have lights. I also like to have each bathroom receptacle on a separate circuit. They are now selling 1800 watt hair dryers. That's 15 friggin' amps all by it self. Two bathrooms on the same circuit and two hair dryers just ain't gonna work.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Eatery wants you to have sex in their bathroom? Melensdad Junkman's Corner 1 02-05-2010 08:37 AM
The Drunk and the Bathroom Bamby Jokes_Forum 2 01-16-2009 09:32 AM
Bathroom Rules? Melensdad Open Forum 11 08-01-2008 05:34 PM
Bathroom Floor jim slagle Home Improvement Projects, Appliance upgrades, Misc Household items Forum 1 12-05-2006 01:14 PM
