Reply
Thread Tools Display Modes
  #1
Old 10-04-2018, 09:26 AM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Default Fuel additive
I’ve started using the fuel additive made by this company AR6200 https://www.archoil.com/
and I have had great success with it. Very concentrated 1ml per gallon on stored fuel and old fuel.
They also make a friction reducer oil additive. Which uses nano technologies
(WS-2) https://en.m.wikipedia.org/wiki/Tungsten_disulfide but I’ve been purchasing WS-2 from another manufacture in Canada and adding to Gear oils for some time.But not in differentials with steering, about 1gram per quart. I have used the WS-2 in engines that had poor performance and have seen improvements
__________________
Have a nice day, NSA kind of like NASA but one less "A"
The Following 7 Users Say Thank You to MNoutdoors For This Useful Post:
bobby wilkes (10-14-2018), jim slagle  (10-04-2018), lorner (11-08-2018), night-owl (10-12-2018), redsqwrl (10-04-2018), rockhead (10-04-2018), Snowshadow (10-04-2018)
  #2
Old 10-04-2018, 10:41 AM
andyv916's Avatar
andyv916 andyv916 is offline
Junior Member
andyv916 is on a distinguished road
Default Re: Fuel additive
I use a similar product in all my gas powered toys , makes for a happy carburetor .
The Following User Says Thank You to andyv916 For This Useful Post:
  #3
Old 10-04-2018, 11:48 AM
JimVT's Avatar
JimVT JimVT is offline
going to start up my diesel cat soon. its been parked with a full tank.
jim
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
The Following User Says Thank You to JimVT For This Useful Post:
  #4
Old 10-04-2018, 01:39 PM
Blackfoot Tucker Blackfoot Tucker is offline
Blackfoot Tucker is on a distinguished road
Interesting...and thanks for the suggestion. I'm going to try it. There's a fairly popular youtube personality (Billy Hewitt) who specializes in Ford PowerStoke engines, and he highly recommends the stuff:
https://www.youtube.com/watch?v=uE812Iw354o
What hits home to me is last December snowcat buddy Scott and I were driving my older Ford 7.3 PowerStroke when the turbo bearings failed. Fortunately we stopped before running the truck out of oil. It was a dark and moonless night so I couldn't see exactly the volume of smoke we were putting out, however it was Huge! (If you think back to the smoke screens put out by US Navy ships in WWII movies you'll get an idea.)
The Following User Says Thank You to Blackfoot Tucker For This Useful Post:
  #5
Old 10-05-2018, 09:56 AM
topwelder44 topwelder44 is online now
topwelder44 is on a distinguished road
I use diesel power service in all my motors---gas and diesel------this past spring my big digger had a stuck injector ---I used sea foam in the fuel and it worked ----I mix cooking oil in with my diesel and use the power service all the time---another thing I have been doing on my gas engines when they r going to sit for a long time is drain the fuel and add a lot of 2 stroke oil in the tank and run the motor till it runs out of gas it seams to give the inside of the carb an oil coating ----in the fall I add gas and everything has been starting up with no trouble
  #6
Old 10-11-2018, 03:57 PM
Snowtrac Nome's Avatar
Snowtrac Nome Snowtrac Nome is online now
the arch oil in diesel engines with a hui system and it does work as advertised. I highly recommend a dose of the stiction eliminator if you own a power joke diesel
__________________
Don
1962 st-4
KL2ZF
The Following 2 Users Say Thank You to Snowtrac Nome For This Useful Post:
jim slagle  (10-11-2018), redsqwrl (10-14-2018)
  #7
Old 10-16-2018, 12:07 PM
NorCal's Avatar
NorCal NorCal is offline
NorCal is on a distinguished road
I just ordered some Archoil last night before I read this post for my 97 Powerstroke. We shall see gonna do an oil change this weekend. Nothing but good reviews.
__________________
1975 Snow Trac ST4 #1948
1949 Tucker Sno Cat Model 524 Now in Tuckerville!!
Vintage VW's & Snowmobiles
The Following User Says Thank You to NorCal For This Useful Post:
jim slagle  (10-16-2018)
  #8
Old 11-08-2018, 06:12 AM
lorner's Avatar
lorner lorner is offline
Junior Member
lorner is on a distinguished road
Quote:
Originally Posted by MNoutdoors View Post
Iíve started using the fuel additive made by this company AR6200 https://www.archoil.com/
(WS-2) https://en.m.wikipedia.org/wiki/Tungsten_disulfide but Iíve been purchasing WS-2 from another manufacture in Canada and adding to Gear oils for some time.But not in differentials with steering, about 1gram per quart. I have used the WS-2 in engines that had poor performance and have seen improvements
why don't you use it in diffs with steering? is it recommended not to? and what is the name of the product that is made in Canada?
  #9
Old 11-08-2018, 08:03 AM
MNoutdoors's Avatar
Quote:
Because it is a friction reducer, it would take away from The steerable friction produced by the steering band.
We buy the raw powder product WS-2 Tungsten Disulfide and add it to our Gear
Lubes and oil. 1gram per quart, you can by it by the pound (453 grams ) if you buy make sure it’s the fine grind.(.6 micron )www.lowerfriction.com
__________________
The Following User Says Thank You to MNoutdoors For This Useful Post:
lorner (11-08-2018)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Imp fuel pressure Bobmog Snowcat Repairs, Parts & Problems Forum 2 02-19-2013 08:17 PM
RCW 46.10.530 Fuel tax Kristi KT7 Snowcat Adventure & Usage Forum 1 12-20-2012 08:46 PM
Jet Fuel pirate_girl Jokes_Forum 1 02-25-2011 11:58 AM
Why Fuel Prices are so High - A Breakdown of Fuel Prices Cityboy Open Forum 29 05-23-2008 02:09 PM
Once fuel has started to gel bczoom Oil, Lubricants, Engines & Misc Forum 4 10-03-2006 11:31 AM
Copyright © 2002 - 2018 www.ForumsForums.com
