sv200 rebuild
I bought this a couple years ago ----I got it running after years of hackers adding junk made it a mess----it ran and moved and all the crap added to it worked sometimes----so one day I gutted it all out -----it ran better and things worked that didn't work before --head lights/heater/gas guage----but it was still ugly----this cat runs and drives so nice its getting a rebuild
cab going on-----this is about 16 hours of fab time----the cab will flip ahead still to be able to work on motor
roll bar and sides on---will be working on the dog house----I have gutted everything out of the cab that is not needed-----it will have head lights /marker lights/heater/wipers-------------KISS SYSTEM
Blackfoot Tucker
That looks like a really nice setup. A significant improvement in so many ways, yet the integration of the new cab literally looks factory.
I have been working on the dog house---this is the old dog house re installed backwards---I lowered the radiator in the chassis---and lowered the dog house also----the dog house is bolted to the chassis with the access door to the rear of cat----and the frt. of the dog house will be part of the cab floor and flip up with the cab when tilted---and also what is nice about the cab is that it has a huge floor plate that is removable and the frt. part of the dog house will be part of it
with the cab flipped all the way forward I can stand in front of the track ----so between the cab and the track -----so nice not having to lay on a seat reaching into motor area----lol------my pisten bully tilts---- but not this far
redsqwrl
will the blade knock stuff out or your way so you don't lunch the bottom of the doors on various opportunities?
300 H and H
A Chevy cab on a Ford powered rig...… There is just something not right about that LOL...:unsure:
:bolt:
when build this I did think about the lower cab to ground clearance -----but the plow frame ----which looks factory-----sits lower than the cab----but if I had to I can pull the steps off and cut lower doors and I will have 22 inches ground to cab-----top of the tracks are 24 inches
300 H and H
your right it should be all chevy-----lol------
No, it should be a Ford....
GM just tossed out 15,000 workers, and plans to build electric cars in China. :hammer: :hammer:
I know I will never buy a GM product again. To easy to go right around the left wing Obama motors...
I hope we tariff any possibility of profit from the move on GM's part.
Sorry...
unlike all the fake hot rod shows----I have to mock everything up than pull it all apart and do the finish work---tonight I finished the dog house /drilled some hole to run shifter cable and the gas pedal cable----tomorrow I hope to fit gas tank / battery box by the weekend iam hopping to pull motor and get chassis ready for rhino liner than into the paint booth ---and yes iam also the painter----no fake tv show here-------this pic is the frt. of the dog house that is now part of the removable floor pan
when I am not building cats and playing with all my other toyz----I build rescue sled for local fire depts. and donate them
redsqwrl
I fit a 3700 CF cab onto a 2100 chassis. I fully understand the thinking that is going on. did you use the Isuzu cabs hinge system of top weld up your own.
Cool sleds
I used the factory cab hindges that came with the cab---I had to rework the torsion tension ----I have it set so that when I move cab latch/lock down the cab comes up about 1 foot than I open 1 door and it comes up about 3 feet and open other door and it goes up even more
