SNOW TRAC WHEELS - help me find parts
nikos
hey Don
It's a practical solution, without much damage, just the inertia of the vehicle immobilizes the vehicle itself.
The Don extensively exploiting the advantage of flat surfaces because these surfaces inertia works in the best way.
Has adapted to the needs of ST4 on environmental conditions and thus no reason to increase the braking system.
And I know that, wy ST4 will be released in the mountain and not on the highways.
Who will see me turning OFF ROADS and see the brake lights when I press the pedal ?.
Possible wild animals, not bears, wolves and deer trained in traffic.
All this in the context of vanity to function properly.
And we become unhappy, angry if a bulb does not light up and wait a week to get a genuine bolt from Canada or Germany to say that we did the right thing.
In nature, however we must be more practical to survive, so they say the rules of survival, to find ways and means to adapt.
If, however, will have been combine practical solutions with the proper use of tools that humans have combined with the technology even better.
Don Thank you for the lesson (practical physics), once applied, and showed us that there are other ways to treat a ride on the ST4.
JimVT
The snow trac is gear low and compression is about all you will need for stopping or slowing. About the only time I use mine is putting it on a trailer or holding on a hill with the engine running.
I forgot you had an ambulance model.
nikos
Hey JimVT
Yes it s an ambulance model,:brows: but tell me something. Whats your opinion?
Where are the differences in the desigh, mechanically, and specifically in the hole operation of the electrical system in companion with the rest of ST4 ?, exept the shape of the tailgate (with no small window), and the 3 or 2 belt schematic.
Especially with the military style snow trac, I know that there are significant differences in overal structure. (Reinforced construction for the needs traction on the front and reinforced components in the chassis for portability transport the ST4 eg Ships or large Military Vans - Vehicles etc).
300 H and H
I kinda feel differently about the bakes on my ST. I have used it to pull kids sledding up the local sledding hill. Invariably one or more kids gets into trouble and looses their grip on the tow rope mid hill. I use the brakes to stop from running backwards over kids, some that are mine! Gotta have them working or I wouldn't do this...
The other day in a friends timber we lost the trail. I thought it went up a very steep hill and decided to try going up.... I spun the tracks about halfway up. Had time to get my foot on the brake peddal, and did. Glad they helped slow me down as I rolled backwards down the hill, right at a tree. They saved me from who knows what kind of damage...
I know that all you have to do is turn the key off and the engine will stop it on most any grade. But my instincts are to use the brake not the key switch. Yup the peddals are small and my feet are big, but I still manage to find the brake peddal when needed. I also remember Lyndon saying most ST's have front end damage from no brakes and hitting things to slow or stop them. I made sure this fall they were alive and well. Replaced master and wheel slave cylinders, no leaks and they are working well after I scotchbrighted the drums and degreased the brake pads. They really work good for now anyway. For me anyway, they have to be in working condition.
It's easy to think you don't need them, untill a situation presents itself that you had not thought of. Then you will wish they work....
Best regards, Kirk
don't get me wrong i have plans to get mine fixed too but i just won't deadline it for that as in most cases i never need them and when i do there is a work around the times i want them most is while decending a hill with one of them heavy loads i'm always pulling a brake would work well to slow me and the load down as it is now i must shift into the verry lowest gear so i don't risk overspeeding the motor and take my time my brake will have to be a hand brake as there is no way to get my feet in there with the boots i wear in the winter
the millitary models differ in that they have two charging systems, some one correct me ifi'm wrong about this next part. i believe that the generator only runs the fan and is un used .the second alternator on top runs the 24 volt charging system my guess is tha it's a split system like the cucv's that the army used with the chassis electrical being 12 voltdrawn from 1 battery, and the starter and radio and ms stuff being 24 volt. the reason for 24 volt starting system is with the higher voltage it takes less amperage to do the same amount of work this way you get better cranking at low temps.
nikos
Kirk said
....for me anyway, they have to be in working condition.
If i do know the trails and the slopes of the mountains in my area, because i walked there, it will be completely different case- situation, when you have weight (Family- friends) in the ST4.
Apart the deceleration of the ST4, that has been in the snow, and because of friction, and many accessories that interfere with movement (Gear, Chains, no good lubrication in the wheels, sled, etc), when letting go the ST4 without pressing the pedal, or the hand break, and find the right condition, (eg not sliding but low speeding downhill) it can run down the hill like a train.
A wild mystery train on tracks:w00t2:
I changed the old ties both the handbrake and footbrake. I did the same for the brake and the cylinder brake. I hope the new material, give me the opportunity to feel confident in the moments that i need them.
I will try to test them in the first exit.
best regards Nikos
JimVT
Hey JimVT
I cannot give a good opinion on the two models.I never had one with the wide doors. I only one time needed a larger door and that was last weekend when the generator seen in one of the rear sleds was 1/2 inch to wide to fit inside. I also have differnt style tracks.
Is that you in the picture?
this was my heavyest tow load so far.
nikos
hey guys
Here some pics from the electric restoration.
It took nearly a week of work to replace the damaged cables and place the new lines for the lights and switches, new battery, new cables, fuses etc.
Inside the console ST4 is the technician, Just working.
Outside I check the contacts for the rear lights (brakes light, tail lamp, and direction indicator).
I believe that all is OK. :w00t2:
In the end I have to place the number plate Lamp, and the original tank after I have cleaned from slag and dirt with the help of thick chain, oil, water and acid.
LAST Friday evening I filled the tank and the engine began- start, to see how the electrical system work (battery, coil, etc.) We are ready for the fist RIDE::clap:
nikos
Αll instruments- electrical equipment on the console was in operation (temperature, tachometer speedometer, switches, the instrument of gasoline tanks, heater), also the interior lights of the cabin.
Console of ST4
1 Heater - micro Switch
2 Windshield Wiper Switch
3. Starter Switch
4 Revolution counter rpm
5 Fuel gauge (External tank – is running)
6 Fuel gauge (Original tank - out of servise)
7 Speedometer
8 Head lamp
9 Horn Switch
10 Choke control
11 Throttle Control
12 Ignition lock
13 Side Direction indicator switch
14 Oil Temperature Gauge
15 Oil presure control lamp + Charging Control Lamp
16 Headlamp Switch
17 Counter of working hours
18 Plug
19 Head light Switch
20 Head tail light switch
21 Fuse Box N2
22 Speaker (I use it for CD player)
muleman
Well done on this restore. You should have enough snow to run for a while. Now get out there and have some fun. See what breaks or needs tweeking next summer.:wow::wow::wow::wow::wow::wow:
nikos
ELVIS HAS LEFT THE BUILDING:wow:
The first walk around the area. The snow was wet. It was a fantastic ride. After 4 months in the garage, the feeling was very special.
Its times that you can not describe them as the stress to go all right, to operate properly, the tracks, oil, engine, electrical power is dominant.
Its times when anxiety about the success of the goal does not make you be glad, or enjoy your creature. The greatness of the creative in restoration.
The ride was about 5 miles. During this time I placed 3rd and 4th gear .. It had to work very long. The engine sounded very good.
At first everything crackling, but then was better.
The first breaths.
The first smell of the engine. The first frozen flakes of snow .... and is only beginning.:w00t2:
nikos
Hi guys
March 31 - 1st April .
The snows have melted at low levels in Florina, and we can meet- find over the 1400 m, in large quantities. I believe in thin tops of the skicenter, the snow will last until April -May.Throughout this period up to green fields the snow rides with the ST4 was a very interesting experience. It was Something else.
The walks around the area was at a low altitude of 600 meters because I have not yet found a suitable trailer to move to higher levels.
So the rides were both the day and especially at night,were the snow was harder.Throughout this period there was no mechanical problem and everything was ok.
The only thing I missed, were some parts of the track, a couple of drivers.
I visit the local workshop to make -construct about 10 drivers to have for spare.
So after that fun, I went back to the garage (ten days ago) for a last act.
The end It will a bit strange - an upside down act in the overall project of the restoration. :whistling:
Some pictures for the events.
the best regards Nikos
louis
Hi Nikos,
You did a great job with your snowtrack restauration ; i've been to Greece a couple times back in 1998 working on Bombardier CL215 Water bomber; i have visited Athens and worked at a military base in Tanagra and Elefsina; it was very hot there (100+ degrees). Never saw snow overthere :ermm:
nikos
The metamorphosis (camo) has began.
Ιs the last act, and then i will move with Trailer the snow trac for the final destination. My garage.
muleman
Looks good. When you say cammo, are you meaning like a winter troop transport design? Love the step you are using also!:clap:
nikos
A week ago.
I was thinking to put a third gray shade ( spots) between the two basic colors, the white 70 % and the black 30%.
But It needs more time and more surface coverage. I have been delayed, and i must leave the shed, to provide hangar space for the big trucks which come in for maintenance.
300 H and H
First class Nikos!!
You are going to have a very very nice ST4 when you are done. My compliments Sir!
Cann't wait to see the paint job finished....I like the snow cammo theme.
the only snow cammo we need around here is all white and in the fall when we hunt red and yellow fit in nice with the dieing veggitation
nikos
dds has given me a great idea to use it in the future in the Snow Trac .:yum::yum::yum:
As an artist ι must discover - invent a special color (like the toys HOT WHEELS) with hot and cold water.:wow:
So that when it snows the color start change - become red. When the temperature begins to rise and the snow melt , the color must change in camouflage.:clap:
The summer when the sun is above and the girls are pretty, the color of the Snow trac must change in the colors of our hart. The paradise of colors.:w00t2: like this VW
nikos
Hey guys
It doesn't matter if the fields are green and the flowers bloom.
it doesnt matter if the spring arrived.
The summer season is a stage adaptation for the big return of winter.
I hope all this time until the winter time, to be a creative and productive for everyone in the Forum.:smile:
I almost finished but I left a some unfinished details (logo-mirrors), and also I need to add some items into the cabin.
The maintenance will be enhanced incremental as needs arise, in summertime.
The result with camouflage paint, satisfy me, and I believe in this level maintenance made so far in the ST4, I can check out for years the damage and be to quiet for a problem that may arise. There will always be solutions.
Besides, thats why friends are for. :smile:
Ι would like to thanks, all known - unknown friends in the forum for the valuable informations they shared with me and helped me to utilize all the tools of knowledge (Photos and experiences and skills) to reach the goal.
I feel really grateful for the help that I had received and the joy I feel for the final result.
This whole ordeal and the effort, made me feel a different man, more productive, more creative and especially practical in solving problems.
Soon I will send some photos (New thread) from an abandoned Ratrak (Next Mission) who will need help to work on snowy mountains.
the best regards NIKOS......................................to be continued
Nikos it looks good and i'm not even a big fan of cammo but it does look good and is distinctly yours but you have to watch out for the hecklers they gave me a bad time about the white rims on my snow trac
JimVT
I have always wanted to be seen in mine on the trail. We have lots of tight corners and fast snowmobilers. If it wasn't for that a camo would be my choice.
I agree with don ,It looks good.
nikos
Hi guys
It's summer time and in the free time I try to advance - improve the overall picture of the snow TRAC by adding materials which make the difference.
a) I First placed a new signs in the ST4
b) I registered a new version drive licence in case the vehicle
moves around in the asphalt road, especially on a Saturday and Sunday.
Daily I can move freely, in gravel roads, trails, and the plains, without any
problem.
c) I have until to December (six months) Road safety - protection.
I have the right to take issuing ( Road safety ) only during the winter months,
when the snow trac there will not circulate the remaining time.
d) I did record the club of the Hellinic Federation for the Military vehicles which are
antiques. (Thats why I had to do the try, to transform the ST4 in camouflage, only
to justify in Hellinic tax authorities, the purchase of the "Military" vehicle.)
e) I placed on the rear two new reflectors,
New rivets - bolts to support the two rear doors.
Stronger lock for each case.
Alongside i visit the local metal working machinery, and made a new pair of snow deflector similar to what was in the ST4.
Along the way, I feel that i can utilize the authentic snow deflectors, and i proceeded to restore them. I placed them in a small press - vise and in 30 min they had the previous form.
I preferred to utilize the original pair of snow Deflectors and now I have a new pair in the store.
If anyone interested I can supply new snow Deflectors along with pair metallic bases mounting on the boogie wheels.
Lynton puts - says in his books - bible: The snow is not as soft as it looks.
Don about the white rims in my ST4.
I think that the colors in the rims do not play an important decorative role. I noticed from the pictures in the forum that all the rims (Red - yellow, black, green etc) in ST4 in the winter, is covered with a lot snow.:biggrin:
So i had the same color in my rims, in the winter, the same in the summer.:yum:
I look like a white (Wild) sheep in green fields:yum::yum::yum:
300 H and H
Nikos,
You now have one of the best looking Snow Tracs here on the forum!!!!
I hope you enjoy it very much in the comming years, and many of those !!
Very, Very NICE!!
there you go kirk some one else with evinrude white wheels youu ain't giving him a bad time
muleman
That looks great Nikos. Real cool design of the camo should blend in real well in the winter. Just don't get stuck or they won't find you without a beacon light. :biggrin:The countdown to next winter has begun.:wow::wow:
300 H and H
Hey but....dds,
He as winter cammo not factory red.....Beside I have a feeling the "boat is comming in" with some thing for you, and someday I'll be sayin the same to you.....
It's summer for crying out loud. Buy a can of black paint and black those wheels while you still can!
JimVT
Are you going with some kind of ambulance markings on it?
you never have shown us a picture with both doors open.
Jim
