Hey Everyone, I have a 2003 Scot-Trac 2000R Snowcat/UTV with only 93 hours for sale in Salt Lake City UT.
Asking $29,500
This machine can be equipped with either the 26" wide track and 8 or 16 wheels (All are included). All tires are powered giving you 8 or 16 wheel drive. This machine will go almost anywhere in any season!
Machine has been garage kept for the last 6 years.
26" Wide Track
2 Person front cab with bench seats in rear cab.
Enclosed Hard-Sided Rear Cab
56HP Yanmar Diesel Engine
3110lb Standard Build Dry Weight with 8 wheels
Approx 4000lb Dry Weight with tracks
1100lbs Cargo Capacity
1100lbs Max Towing Capacity
16MPH Max Speed
23 Degree Climbing Slope Capacity
23 Degree Side Slope Capacity
23 Degree Descending Slope Capacity
12" Flowing Water Max Depth
30" Still Water Max Depth
Tubular Steel certified Roll Over Protective Structure
Included Accessories -
17 - Low Pressure Ground Tires (For use as 16X16 plus spare)
8 - Hub Extensions (Used for 16X16)
1 - Hub Winch Attachment
20 - Track Tires (8 are brand new - unused, 8 are installed, and 4 spares)
4 - Extra Metal Grousers (2 Left, 2 Right)
Set of 18" Rubber Coated Grousers
This is a very capable machine for all seasons. It is a great snow cat for transporting people & gear in winter time. Also makes for a great UTV for the rest of the year.
Here are some videos showing different uses of Scot-Trac machines...
[ame="http://www.youtube.com/watch?v=ORJeAmEtS0o"]SCOT-TRAC 2000R in action - YouTube[/ame] [ame="http://www.youtube.com/watch?v=aL2Uj9e7JOA"]Scot trac track GLencoe 8x8 - YouTube[/ame] [ame="http://www.youtube.com/watch?v=LH1lcVoS1yI"]Scot Trac ATV - YouTube[/ame]
*All Specs pulled from https://safetyoneinc.com/specsheets/pdf/SALESINF.PDF
Asking $29,500
26" Wide Track
16MPH Max Speed
